I need your help replacing my gas cap. I spent an hour at the local auto parts store and couldn't fine the right replacement. Any idea on a part number or suitable replacement.
Thanks for the help.
Mk4? If so Stant 10832
This solved that problem for me. Keep the key in the gas cap while you fuel up.
Roy
Thanks for the response, it's actually an MK3. I don't believe the Stant 10832 would work.
I appreciate the help.
Des
If Mrk3 then it should be 1993 Mustang
Here you go. 1982-1998 Mustang Fuel Cap.
https://www.rockauto.com/en/moreinfo...t=5900&jsn=486
I bought one at Advance, as said a Fox gas cap. Had to do a little modification to the top since it was too tall for the Leman to shut all the way. Been good for 3 years now.
