PTFE fuel line question
My question: Is there a way to run PTFE fuel lines when the in-tank fuel pump and the fuel filter have barbed fittings? I suppose the crux of the question is if there is a way to connect a PTFE AN fitting to a barbed fitting. I've run multiple searches without success.
My engine is a Mike Forte-built 363 SBF with a Sniper II EFI, and I’m using a Forte-supplied Holley in-tank pump (Part # 12-345) along with a 14 micron WIX filter (#33243) that Mike supplied. Both the fuel pump and filter have barbed(pushlock?) fittings.
If possible, I’d like to run braided PTFE line from the tank to the filter to the hard lines, and from the hard lines to the Sniper. The return line would be braided PTFE line from the pressure regulator to the hard line and from the hard line to the tank. (I'm aware that I'll need PTFE AN fittings.) I would ground the filter. But so far I can’t figure out how to attach PTFE braided line to the barbed fittings on the pump and filter.
I may be able to swap out the fittings in the fuel pump for AN fittings but that still leaves the filter. Should I just buy a different filter that has AN fittings?
Am I overthinking this? Should/can I just use hose such as Earl's Vapor Guard on the tank side of the hard lines and PTFE braided hose on the engine side of the hard lines?
Thanks in advance for your help.
Geoff
Geoff Harlow
Build School: 12/8/17 - 12/10/17
Complete Kit - delivered April 21, 2023
Dart 363 by Forte, IRS, Pwr Steering
You can buy push-lock (or quick connect) to AN adapter fittings.
I just removed the barbed fittings and went with a standard -AN male flare coupler fitting.
Post Thanks / Like - 1 Thanks, 1 Likes
Go with the -6 ORB to AN fittings on the pump. Ditch the filter for a cylindrical or canister filter with AN or NPT fittings. That's only a $20 generic filter.
Then you can run whatever lines you like.
Roadster delivered 8/27/23
Chevrolet Performance LS3
Ditto what Jeff says. Here's the filter I went with. It's a late 90's GM truck filter. Inexpensive, very effective, and you can pick it up at most stores. This one happened to come with AN6 fittings.
https://www.vaporworx.com/shop/produ...-an6-adapters/
I would only use the specific PTFE fittings for the lines you have. As others have said, ditch the cheap filter and get one with AN fittings, preferably one you can service.
I did the same as fman. Not a huge financial burden and you know it's going to work.
Thanks to all for the comments/advice! The picture is my head is finally in focus.
Geoff Harlow
