Results 1 to 5 of 5
Thread: Clutch Stop Usefulness? I Made One But Adjusting....
    Senior Member F500guy's Avatar
    Aug 2022
    Portland, Oregon
    So, in my build thread I made a clutch stop because the throw out bearing manual said I should have 1 to prevent over travel. So, I can not measure the bearing movement, so next best thing is to adjust it so I do not constantly max out the travel of the master cylinder. Any thoughts on this?
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    What throw out bearing do you have? Tilton are pretty specific in their instructions on how to adjust the stop for their throw out bearings.
    https://tiltonracing.com/wp-content/...-HRB-print.pdf
    Aug 2022
    Portland, Oregon
    I have the mcleod. I read that and it looks like it should be about the same, thanks for pointing that out.
    I think I'd adjust the pedal stop so the clutch will disengage and the pedal will move maybe 3/8" further. Then I'd rig a stick to keep the pedal touching the stop while you look at the MC and slave cylinders to see where the pistons are to assure that neither is too close to the end of the bore.
    Heart of Dixie, Alabama
    You can buy an elevator bolt or rob an adjustable leg from a bed frame, old washer or refrig. for the stop.
    I mounted mine in the foot box floor, double nutted it and adjust to hit the back of the clutch pedal or arm.
    I also used large fender washers to add support to the sheet metal.
