Likes Likes:  5
Results 1 to 13 of 13
Thread: Stuck in Springfield, IL!! Help for clutch problem?
    split time between South Florida and Western North Carolina
    Saturday, MAY 4 - Hey is anyone near Springfield, IL with grinding tools and a jack? I have an exterior clutch slave cylinder which is not disengaging the clutch...thus I'm unable to put the car into ANY gear, can't drive it at all. Rode a tow truck flatbed to hotel in Springfield this evening. I THINK I know how to fix it after consulting with Mark Dougherty. I need a floor jack and jack stand/s, and a Dremel-type grinder or something more powerful to grind some clutch fork clearance into the QuikTIme bellhousing.
    Aardvark and I are on our Route 66 Charity fundraising trip, going smooth and fun so far. This temporary setback came on a Saturday evening, hate to bother anyone on a Sunday!
    Anyone available nearby? Text me at 561-252-9555 or respond here with contact info. Thanks!
    John Phillips, Jupiter FL and Waynesville, NC
    Built 4 Roadsters, one of each Mark series
    Rebuilt Challenge Racer
    Customer and FFR Fan since 1996
    To the top. John needs some help from anyone who is in the area. He's identified the problem and now just needs some assist with tools to execute a fix.
    PLEASE!
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    bump
    Current BOM
    Mar 2021
    SE WI Kettle Moraine
    I am not close enough to help with eyes or hands, but IMO the root cause here may be easier or harder to rectify. Metal part interference is unlikely to develop during 1200 miles of a road trip.
    A clutch lever/fork or pivot may have failed, a malfunction typical on Subarus (818).
    Next suspect would be the throw-out bearing or clutch actuation levers.
    jim
    Keeping this visible.
    Suggest posting on the other site, if not done. Hate seeing a roadster trip get side lined.
    good luck,
    Woodstock ,Illinois
    John needs a hand!
    Senior Member DW66's Avatar
    Jan 2020
    Plymouth Mass
    I can't believe someone hasn't stepped up yet. I certainly would but I'm a little far away...
    MK4 Complete kit FFR9939. Gen 1 Coyote, Tremec 3650, IRS 3.31 ratio, Breeze radiator stuff, Breeze cubby and battery mount, North Race Cars heat and A/C, RT drop trunk kit, Replica Parts radiator aluminum and brake booster spacer, FFR soft top.
  9. Likes john42 liked this post
  10. #9
    Just heard from John. He found a guy with a lift and appropriate tools and the issue has been rectified. They’re hitting the road again…wish them luck!
    https://c3on66.org/
    Good to hear
  12. #11
    Good to hear
    They’ll be heading your direction Rich!
    Today is an overcast misty day.
  14. #13
    Made it to Tulsa, no tornado or storm problems. Clutch actuation repairs are perfect, love the shift again. Tomorrow meeting some old friends at Pop's in Arcadia, OK, and hope to make some new ones. Come on out if you are nearby, we're gonna be there about 11:30. Check the BLOG page at our website for more detail of how things are going www.c3on66.org/blog/
