Hey Y'All,
I just got my Forte' TKX spacer kit -- well made and simple (just how I like it), and it matches my planned height of my stacked-up spacer washers (mockup only)
Craig C
Hey Y'All,
Craig C
Hey Y'All,
Believe it or not, I used up all of my 25' roll of off-brand Stainless Steel annealed 3/16" tubing while bending and flaring the hardline for my rear brakes. This would've been the final, largest piece. Since my flares split and I had already bent the whole line to shape, I decided to get some more tubing, and keep this piece for scrap extra...
I decided this time to get straight sections from Holley (Earl's branded). After trying my first flare, success! Then I cut that off and tried another -- success! I'm sensing a pattern here
It's still early days to celebrate, and since I also decided to change my bulkhead "stick-out" dimension at the bottom of my floorpan, I really don't have much to show this update. Here's a picture of that 1st flare attempt on the Earl's line anyway...
Happy Building!
Craig C
Hey Y'All,
I got my "production-intent" Craig-Brake bracket cut, bent, filed, and fitted to the trans tunnel frame tubing. Recall that my 1st bracket was set up for the shifter in the forward position. I wanted to try it in the rearward position (about 3" rearward from the forward position), and so far it fits well and I like the layout. There's only so much room for all the stuff so my design (as of right now) is not conducive to a single bracket for both positions. I'll have to think more on that...
I'm planning to use nut-certs on the right-side main tunnel tubing so that the passenger-side cockpit panel isn't affected, and likely thru-bolt holes on the diagonal tubing (since there's room for that).
Here's a picture with the initial hole cut for the shifter Craig-Brake production-intent3.jpg
I'm debating whether to simply enlarge the hole or add a dimple-die flare to this hole (since the rubber boot is touching). I'm leaning towards the dimple-die for strength and coolness factor, but am worried that the bending in the shop press might warp the flatness of the bracket bottom. I ordered some dimple-dies from Eastwood since they appeared to be on sale and will experiment on a scrap piece of my 14ga steel sometime this week
Happy Building!
Craig C
Hey Y'All,
I went ahead and purchased a dimple-die set from Eastwood and decided to practice on a test panel. The instructions said that the quality of the pilot hole essentially dictates the final result...
Knowing that I just have big-box-store hole saws that aren't concentric, I decided to cut a slightly smaller hole and file and sand it out to get a good fit into the die. Furthermore, I've seen panels warp from deforming the metal this way, so I wanted to try it out on the practice panel. Here's the setup of the die and panel in the press dimple-die press setup.jpg
Here's right after fully seating the die against the practice panel practice panel completely pressed.jpg and the final result practice panel result with die set.jpg
Looks good! Onto the real thing...
Craig C
Hey Y'All,
Fresh from my scrap panel dimpling success, I prepped the real panel and proceeded to add a dimple to allow for shift boot clearance. The test fit looked good, so the next step was to cut, file, and drill out the slots and holes necessary to mount the Lokar handbrake assembly to my bracket. Here's a picture dimpled and slotted.jpg
Since the shifter was moved to the rearward position, there was slightly less room overall than on my prototype piece. Still have decent clearance to the bracketry and the clevis, but it is close enough to the shifter boot rubber for me to pay attention to it once I start the go-cart phase. I'm pretty glad I used the solid engine mounts too, since any drivetrain torque reaction makes that clearance even smaller. Here's an underside picture handbrake fits close to shifter housing.jpg
Lastly, here's a picture of it bolted together. handbrake bolted to bracket.jpg Those extra washers are just temporary spacers. I've got an extra coil-over spacer that I'll probably cut-down to fit at the back two bolts...
Next, drilling and bolting into the frame tubes...
Happy Building!
Craig C
Hey Y'All,
Hope you had a Nice Easter weekend! I took advantage of the extra day off from work to measure hole locations for drilling and installing my Craig-Brake bracket panel onto the trans tunnel frame tubes. There's not a lot of room to get the holes drilled correctly -- fortunately, I had a right-angle drill attachment that worked out well. I also made sure to pre-punch for the holes, drilled pilot holes, and used 3 different step-bits to get the final result where I wanted it. I only had to get out the Dremel tool to correct 2 out of the 6 pilot holes...
I also decided to use "low-profile" nutserts, since I wasn't sure the standard ones would fit my bracket (accounting for all the stack-up). The nutserts installed well with a wrench-style tool and look great. Here's a picture trans tunnel low profile nutserts2.jpg. My only other concern was the twist-out torque for these nutserts. There really is a dramatic installed height difference between the low-profile and standard. I hope it'll be OK. I think my design is solid with mostly orthogonal loads on the fasteners, but time will tell. I used 1/4-20 nutserts and bolts with lockwashers.
Here's a picture of the bracket bolted-in bracket bolted into place.jpg and of the whole assembly before being sent off to the powder coater final mock-up before powder coating.jpg
Happy Building!
Craig C
Hey Y'All,
I got my Craig-Brake panels back from the powder-coater and he did a great job (as always). It's a satin finish (not sure the code number) and while it doesn't exactly match the factory finish, it is good enough for me! Here's a picture Craig-Brake brackets after powder coating.jpg
Next up...prep for powertrain removal...
Happy Building!
Craig C
Hey Y'All,
Now that I know how my Craig-Brake will fit with my powertrain, it's time to remove the engine/transmission to get back to other tasks...
But before I do, I wanted to get some pictures of the headers mocked into place so I can visualize where I'd like to add heat shielding to my engine-bay-side foot-box panels. Here's some pictures so that I can come back to them for visual reference when I build the heat shields later:
driver's side header installed to visualize where the heat shield will go1.jpg driver's side header installed to visualize where the heat shield will go2.jpg driver's side header installed to visualize where the heat shield will go3.jpg driver's side header installed to visualize where the heat shield will go4.jpg passenger side headers to see where the heat shield goes1.jpg passenger side headers to see where the heat shield goes2.jpg
Wow! What a pick-me-up seeing the headers in place (even if it is just temporary)
Happy Building!
Craig C
Hey Y'All,
Fresh from my success at installing nut-serts (or riv-nuts) for my Craig-Brake, it was time to get back to other tasks...
This one required planning a little where and how to locate my gas tank and IRS vents. I'd thought about how to do this months ago, but never got around to drilling and installing the nut-serts for this task. Finally did so this weekend.
Here's the installed nut-serts on that lower horizontal 1" tube just in front of the gas tank gas tank and irs breather prep1.jpg
Here's the vent assemblies and raw bracket for the charcoal canister installed gas tank and irs breather prep2.jpg
And lastly a picture of the installed charcoal canister for the gas tank vent gas tank and irs breather prep3.jpg
Sorry, I don't have the part number. If you're interested, it's from a Moto Guzzi V11Sport circa 2000. I liked it because it was a nice cylindrical shape and thus pretty easy to make a bracket for it. I plan to add heat shrink tubing to the large hose clamps to cushion it a bit and give it a finished look. I'll also get the bracket powder-coated later...
Happy Building!
Craig C
Hey Y'All,
I spent the weekend visualizing and measuring where to precisely locate my Breeze battery tray. The instructions mention that the main 4" frame tube in front is not always parallel to the X-tubes for the front suspension. My frame was only off by about an eighth of an inch, so I proceeded to install it per the instructions, but since the fore-aft dimension was pretty tight, I did not use any washer spacers. Here's a pictorial history:
And after setting to the proper height -- mostly dictated by the existing holes and where they aligned to the 4" main frame tube. The X-tube tray holes did not align to my frame, but were pretty close. The difference being that this was likely designed for the square x-tubes, but for the round X-tubes, it's pretty close. As you might already know from my build thread, I like a little more precision, so I located new holes (equi-distant side to side and evenly spaced for 5 holes, and aligned to the centerline of the x-tube). Here's what that ended up looking like:
battery tray located, drilled, and clecoed into place1.jpg battery tray located, drilled, and clecoed into place2.jpg battery tray located, drilled, and clecoed into place3.jpg
Happy with the holes, I tapped the front ones for 10-24 button heads, and the rear ones were 1/4-20 (per the instructions)...lock-washers and hardware are stainless
Lastly, I bought a 2yr battery and checked the fit...I think it'll work
battery tray with battery installed1.jpg Dead animal view...looks like the tie-down bolts are clear of the scrub line, too ! battery tray with battery installed2.jpg
Happy building!
Craig C
Hey Y'All,
I finally got around to making my rear brake hardline that goes from the footbox floor to the driver's side rear frame area. I had some trepidation (since my early exposure to flaring quality issues), but the job wasn't so bad with good quality hardlines and patience and measuring. I did make a couple of mistakes, but powered thru and I'm happy with the results
If I didn't mention in previous posts, I used a Ridgid tubing bender and a flaring tool from Eastwood. The connection hardware is Earl's and I added a stainless steel spiral-wound gravel guard, since I just don't like the low-mount routing (although lots of previous builders don't have road debris issues with this "traditional" routing). I got the hardline mounts from a vendor that Mike B recommended. I really liked the curved back-side surface that fits very well on the 4" main tubes
Here's the rear views that shows the bend design and routing I chose:
rear brake main hardline1.jpg rear brake main hardline2.jpg rear brake main hardline3.jpg rear brake main hardline4.jpg
The routing allows for removal (if it comes to that)
Next, here's some pictures of the main straight section. Of note here is the gravel guard and how the mounts all lined up well even though I had one aligned with the flat outrigger tube, while the rest were on the 4" main tube at a different mounting angle. I also lucked out that I didn't have to drill any new hole under the driver's side footbox floor panel. I simply reamed out the 1/8" rivet hole and tapped for an 8-32 button head The last picture shows that I did have to approach the bulkhead connector at a slight angle (it was about 7 deg)
rear brake main hardline5.jpg rear brake main hardline6.jpg rear brake main hardline7.jpg
Up next, planning my fuel lines...
Happy Building!
Craig C
Last edited by cc2Arider; 04-21-2024 at 06:06 PM. Reason: removed duplicate picture
I’ve enjoyed threading your posts and appreciate the pictures. Thank you.
Ashaw65,
Thanks for looking thru my thread and the compliment
I wish I had an update for this past week that included some pictures, but instead, I spent some quality time with my Club Members who put together a nice annual meeting event
Then, I had to do some chainsaw work on some downed tree limbs. Losing out on garage time has me extra motivated to get back to it this week!
Hopefully, I'll have some worthwhile post this week...
Happy Building!
Craig C
Hey Y'All,
Since Spring has "sprung" here, I've had less time to work in the garage as I had gotten accustomed to over the Winter, so this post isn't that inspiring. I've been working on designing and locating several miscellaneous brackets that we all have to deal with...
First up is my plan for the hydraulic reservoirs. I intend to "sandwich" a pair of Al angle pieces around the 3/4" front top tube. My intention is to provide more support than a flat piece while providing some additional heat shielding from the header heat below. Here's some crude mock-up pictures: hyd res bracket mockup1.jpg and hyd res bracket mockup2.jpg
While I'm figuring that, I still need to locate my spin-on fuel filter. It's a Trick Flow unit that others have used and it came with its own Al angle bracket. It took me a while to play with the geometry, but I got it where I want it and it just took me to add some Al spacers so I could use the bracket that was already designed for it. The arrangement should direct the forces where I want them. Here's some mock-up pictures: fuel filter bracket mockup1.jpg and fuel filter bracket mockup2.jpg and fuel filter bracket mockup3.jpg
Lastly, I had heard other Builders mention that a support bracket under the outside front corner of the supplied fuse-panel bracket would be a good idea, so I thought about it and came up with this bent piece of Al sheet (~1/8" thick). Here's a couple of mock-up pictures: looking down from the top fuse panel bracket mockup1.jpg and a better side view here fuse panel bracket mockup2.jpg
Hopefully, I'll carve out some more quality time in the garage this upcoming week to wrap these up
Until then, Happy Building!
Craig C.
Hey Y'All,
It's good to be working in the garage again! This weekend I finalized the location and mounting choices for my canister-style fuel filter. This one's a Trick Flow unit, but there are other similar ones, too (Aeromotive, etc)
As others have done, I chose to locate the filter mounting bracket on the Passenger-side rear horizontal frame tube near the upper coil-over tabs. I stubbornly wanted to use the bracket that came with the filter, but you could easily cut a similar bracket from Al angle stock to use instead. The existing holes in the bracket are 5/16", so I used that same size nut-sert.
Here's the frame drilled out to accept the nut-serts fuel filter bracket frame holes drilled.jpg Here's the nut-serts installed fuel filter bracket frame nut-serts.jpg
Here's a gasket/rubber damper I made from an unused riding mower tire tube fuel filter bracket gasket damper.jpg. Since the nut-serts have a small installed height (that is not flush with the surface), I wanted something that would support the bracket against the frame better and damp any vibrations on the bracket and filter assembly. I used a spare brass plumbing attachment as the hole punch. It worked pretty well
Here's the result fuel filter bracket installed1.jpg I'll use wavy washers or proper lock washers for the final install.
So here's the proof that I did my homework on the best overall location: easy to access all fittings from underneath the trunk panel, and relatively out-of-the-way of anything else
looking back view fuel filter installed ports looking back.jpg looking forward view fuel filter installed ports looking forward.jpg looking from the right rear wheel/tire towards the driver's side view fuel filter installed ports looking left.jpg and finally looking down from the trunk floor fuel filter installed ports looking down.jpg
It's rewarding that all my consternation/OCD resulted in solving all the problems I could think of -- I'm happy with the result!
Happy building!
Craig C
Hey Y'All,
I hope your Memorial Day was as reflective as mine was
I wrapped up a task that turned into a goal -- get the fuel hardlines designed, routed, and fastened (at least for mock-up) by the end of this weekend. It was an intense goal for me because I ended up using a lot of geometry and Trigonometry and I didn't want to make mistakes! I figured minimum bending distances, critical offsets, coupler dimensions, access, etc. In the end, I got frustrated because I ran out of talent, or patience, or both I may decide to start over after I examine my work in a few days...
I started in the back near the fuel filter. Here's some pictures fuel hardlines near filter.jpg. Notice the swoopy bends. I had to do this because the minimum bending distance was a little wider than the 2" rear frame tubing. More views from the right rear wheel area fuel hardlines from right rear wheel view.jpg fuel hardlines from right rear wheel view2.jpg So far, so good...
Then, I wanted the maximum ground clearance, so I resorted to Trigonometry to calculate offsets. Here's an undercar view fuel hardlines underside frame detail.jpg
At this point, I was feeling really good about my work...then today, I ran out of talent, or patience, or both when I tried routing the fuel hardlines into the engine bay. I chose to route along the 3/4" diagonal frame tube so that it would be well supported, and reasonably protected from impact and heat sources. Others have done this, too. My hat's off to those who did this well because there's a lot of geometry to think thru!
My 1st attempt turned out pretty well on the feed line. I resorted to practicing on a spare hardline and this was a wise move! The return line was more complex because the angles just weren't computing in my head. Once again, the minimum distance between bends made for a "swoopy" shape. In the end, I resorted to "massaging" the fit a little. It's not my best work, but here's some pictures fuel hardlines engine bay detail.jpg fuel hardlines engine bay detail2.jpg
Here's a wide view of the whole right side for perspective fuel hardlines right side overalll view.jpg
I let my desire to complete a goal run headlong into my nit-picks about unapologetic workmanship...this was quite the reflective weekend!
Craig C
I'd be proud to have them on my car. That's some really nice work.
Nige
Gen1 Coyote / TKO600 / IRS
very nice work. where did you get those line separators that are radiused to the 4" frame? or did you CNC your own?
Many THANKS to my BroBro, Nigel, and Chewy for the compliments and encouragement It helped a lot! I went out to look at my work this AM, and it wasn't objectionable...I'll keep it.
Chewy,
The line separators were from a vendor that Mike B recommended. Yes, they are radiused on the back. This was a selling point for me since they're pretty stout for the purpose. I was going to mention this in my post, but had a difficult time getting everything documented before my connection got interrupted (sometimes this happens for my posts). I'll look in my email receipts to get you a contact...
Craig C
Hi Chewy,
I owed you a response for the special line separators I used. I'm not sure if this violates the Vendor policy or not, but you can contact Rick at Lodestone BilletWorks. As I recall he is a builder, who knows our products well
Craig C
Hey Y'All,
I tidied up some fuel hardline details this past week...
First up: cut and add gravel guard to the areas that might see that type of thing fuel hardlines with gravel guard1.jpg fuel hardlines with gravel guard2.jpg fuel hardlines with gravel guard3.jpg
Next up, locate, drill, prep for the engine bay separator mount. I used a nutsert on the 1" diagonal support tube. Here's a progression of pictures: fuel hardlines engine bay separator1.jpg fuel hardlines engine bay separator2.jpg
Next up, see if I can install them with the footbox panels in place. No. Too long, but not unexpected. There's only so much maneuvering with such a complicated shape. I ended up installing the feedline into the engine bay 1st, so that meant I needed to trim the area near the filter. I already knew that I needed a minimum of 7" between the filter and the feedline, so that's where I cut it. Next, the return line needed more length near the filter, so I trimmed it back in the engine bay side. Both lines suitably trimmed, I could get them both into place with the passenger-side footbox panels in place fuel hardlines engine bay detail3.jpg
Everything fit pretty well, but I did have a tight fit at the trailing edge of the passenger footbox floor, so I'm planning to add an adhesive-backed stainless steel shim (cut to fit), so it doesn't wear on my nice panel powdercoating Here's where I'll add that later fuel hardlines passenger footbox detail.jpg
Happy Building!
Craig C
Hey Y'All,
Since I relocated my handbrake to the top of the transmission tunnel, I had a big panel hole that needed to be covered. I made a simple panel many months ago, but finally decided to make it removable
There's probably not much point in it, but I did notice with my transmission mocked into place that the oil fill plug is right there! Also a switch plug is located near there, too. Since the transmission is shifted to the passenger side a little, and has less side clearance to the panel, I figured, "Why not add an access panel?"
The difficult part was that I had already drilled the rivet holes kinda close to the panel's open edge. The "usual" nut serts would be too big in diameter. So I found an alternative in McMaster Carr. I could get some pretty small diameter ones, that would still fit a 6-32 screw size. Not too bad!
These are made for "soft" metals, and don't squish or deform themselves. Instead it has grooves that bite into and slightly deform the holes of the parent panel metal.
Here are the part numbers for the special nutserts and the installation tool passenger side transmission access panel tools.jpg
Here's the panel after drilling, adding some silicone, and pressing them into place: top side passenger side transmission access hole prep1.jpg bottom side passenger side transmission access hole prep2.jpg
Next, I needed to align the patch panel and precisely drill holes for the 6-32 stainless button heads (with lock washers). Here's the result: top passenger side transmission access panel1.jpg back passenger side transmission access panel2.jpg
Here's an edge view so you can see how low-profile they are passenger side transmission access panel3.jpg
Until next time...Happy Building!
Craig C
