Thread: Coyote install- where to attach hooks?
    Oct 2022
    Hi,
    Got my new Gen 3 Coyote and about to install it into my Coupe.
    I have this engine hook mechanism (below), but where should it attach?
    Does it attach to the same place where the engine is attached to the cradle for shipping (also below)?
    I don't want to drop it!
    Dec 2022
    You need to either buy or make brackets off the two mount locations. See photos
  3. Thanks ChrisNicholls thanked for this post
    Oct 2022
    Thank you, very clearly indicated in your photos!
    I'll have to figure out the bolt size.
    Wish me luck.
    Senior Member dbo_texas's Avatar
    Feb 2018
    Austin, TX
    Bolt size is M14 on the Gen 2...I would assume it didn't change on Gen 3 but you won't know until you try it. I bought these M14x45 bolts from AMAZON and they worked, but fair warning - one of the bolts gets trapped by the header tube, at least on the Roadster install. Not sure if it is different for the Coupe. Due to the length of the bolt I couldn't back it out to get the bracket off. I ended up having to cut the bolt with an oscillating multi-tool but the angle was weird and I ended up burning through 2 of the bits which cost me about $35 So shorten that bolt by at least 20mm before you install it.
    Bracket mount locations:
    Darryl [dbo_texas]
    Prescott, AZ
    I used these brackets to lift my Gen2 Coyote. The brackets come with the correct mounting bolts.
    https://tdmotion.com/product/coyote-...lift-brackets/
    They could be an issue on the PS rear attachment point depending on your firewall clearance. My application is a 70 Mustang, a different animal.
    Indy Shu's Avatar
    Indianapolis, IN
    Chris,
    I used the same brackets as you but I did some bending on each of them to make them fit a little tighter to the engine. Not much extra room at those spots.
    Good luck!
    Gen 3 Coupe #334 received 11/4/21. Coyote, IRS, TKX, Wilwoods
    '02 GT donor, 4.6 sohc, Received #5488 on 5/29/06. 3-link, ps, pb. Hoosier Cobra member (Hoosiercobra.com)
    Mar 2021
    Or make your life easier and just get one of these.
    https://www.ebay.com/itm/27636560566...d48747c6d56d2c
    You have to take the intake off, but that takes all of 20 minutes. Makes Coyote installs a LOT easier!
    RR
