Well the shipping date for my Ford Performance Short Block came and went. Looks like they have revised the ship date to Feb 5 2024. So I'm trying to find things I can continue to do without a drive train.
For Starters I closed all the gaps in the foot boxes with some 3M Strip - Caulk I've had on the shelf for ages. It's pretty much made for this purpose so I hope it holds up.
Probably could have smoothed it out better but the Koolmats going to cover it up anyway.
Next I put in 3/4 of the Breeze Koolmat kit. I have to wait on the last driver's side foot box and driver's side tunnel wall, but I got the rest of the pieces in. I hope the material does a really good job because I didn't save a ton of time as most pieces needed trimming to get them to fit.
Other Items I think I can work on while waiting for the Drive train are:
1.) The fresh air vents for the foot boxs
2.) Get the radiator setup ready. As I have both the Breeze Hinge kit and lower support, plus fan/shroud with Controller, there is going to be some time needed there.
3.) Soon I should have my Dash covered and then can install and wire all the gauges and switches.
4.) Mock up the seat tracks
5.) Create a wiring cover for the trunk lid
6.) Install the parking break
Maybe this will keep me busy until Feb. Any other ideas?
Mark IV, 302 Based 347, TKx, Four link w/3.55, coil overs, PS, 4wheel Willwood. Dark Blue w Black/Red stripes, Saddle Interior, Blacked out chrome.
Kit Ordered 4/18/2022
Kit Delivered 2/20/2023
I picked up most of the interior today from the upholstery shop, Knish Kustomz in Kilkerny, MN. An amazing shops that does a lot of small and big builds every year, including a few SEMA projects.
https://www.facebook.com/KnishKustom...GPY9LGvmvkJDn8
https://www.instagram.com/knishkustomz/
Another of Knish's cars was a much more customized Mark IV.
https://thefactoryfiveforum.com/show...EBzE_VagbVhxQY
https://www.ffcars.com/threads/pleas...r-8352.634090/
https://www.ffcars.com/attachments/c...18-jpg.326178/
Anyway I am so happy at well it came out. I didn't go full custom but I wanted to do a saddle interior rather than the standard black and I am stoked to see everything together (probably in a year or so)
Latter once I get the drive train put in I'll get the tunnel cover done too, but with a double stick up the center and single stitching along the corners. I like quilting but having looked at some back draft cars feel it can be over done. Will have to pick out some dark tan or brown carpet to compliment the great job Knish did.
Exciting week this week. Though I didn't get any shop time in.
First after an 18 month wait my short block from Ford Performance Parts came. Which allowed me to borrow and drive our facilities fork lift. Which is always fun - though it's been 25 years since I've needed to drive one. Doesn't look like a motor now but it will in the next couple months. Need to get my hoist out to the shop next.
Next the machine shop called and my steering boss is complete. I had them machine it so an NRG slim quick release can be mounted to it. Turned out pretty good.
Ooh!! Very very nice block. And ordering it directly for Dearborn, MI is cool too.
Well the last couple of weeks have been pretty slow. Mostly just working on some wiring odds and ends and getting the dash ready. Once that is done I'll turn my attention to the engine build.
I spent a couple hours putting most of the components in the dash. Then I could not wait to see it mocked up on the car.
Another day I wire up the headlight switch, heater fan switch, heater cut off servo control, and the dash side connector for the foot box fans/radiator manual fan/Line Lock.
I'm using a 1965 Mustang Headlight Switch. I got a pigtail from Midlife wiring harnesses (he restores Mustang Harness and resells them http://midlifeharness.com/) and replaced the RF harness connector with it.
It took a few wiring Diagrams to hopefully have sorted it out
Here are the connectors for the Fan Switch all wired up. Again wired into the RF Harness - at least for the heater power lead.
and finally the very exciting connector for Footbox vents/line lock/radiator fan override - the other side will get put together once I get the switch gaurds powder coated and the accessory switch panel together.
https://mattglaeser.smugmug.com/Home...er/i-7tgVHvv/A
Today I did 90% of the harness to gauges/dash wiring. Still need to sort out the hazard switch and dimmer switch. I also need to run the GPS speed sensor wiring and the Speedhut oil pressure sensor. Since it needs 3 leads and the RF harness only has 2 I'll just run it and tape off the RF wires.
Well after a lot of back and forth and some re-wiring I finished the dash wiring. Not much to see but the pic below the add on switches are now wired. Not shown is I dieted the harness of the sensor wires in the engine bay and replaced them with the Speedhut leads. Also I wired and rewired the ignition switch.
Now that the wiring in the car is mostly done (minus the Sniper/Hyper Spark/Engine bay) we're moving on to building the motor.
As mentioned in the above link the short block from Ford Racing Final came in December. This last week we unwrapped the turkey and got it mounted to the engine stand. We had to clean and test the engine hoist since it has just been sitting in the corner of the garage for over a decade without being used. Still worked fine so that was nice. But of course we needed to run to the store to get some additional bolts and washers.
We also had planned to do the timing component install but I misplaced the assembly lube. I was surprised to find that none of the Napas, O'Reilys, or AutoZones had any. I finally found an Advanced Auto with a single bottle. So we'll get back to the assembly this week as I ran out of time on Sunday.
Here are some unbocking photos. My friend said we should have gone full Gen Z and done a youtube unboxing.
I thought it looked like a turkey or ham in the frozen food section.
Well now that it's time to work drive train it's time to update the task board.
5 tasks carried over. Which is better the last time I cleared the board.
Ok most of the new tasks are on the board, I'll keep adding to it for a bit.
Not much progress to report at the moment. Because I decided to build a short block up rather purchase a completed engine I'm learning slowly what does and does come in the various kits you buy (short block, top end kit, bolt kits, gasket kits, etc). I'm also learning there are few more differences between a 1969 302 and 5.0 based 347. Mostly I'm just missing things. Like the spider tray and lifter retainers, random bolts and nuts, etc. Since I'm busy at work right now I only have a few hours to work on the project each week and I find that I spend more than 1/2 that time figure out the next step, what is missing, and how to get it. That said, like everything else in this build, the next build would/will go much faster based on my learnings(probably should dream of the next project when this one is so far from the finish line).
So basically in the last 2 weeks I have... Drum roll please... Installed the Cam, Timing Gear, and Timing Chain. I also degreed the Cam.
I got to buy this nifty sprocket that allows me to degree the cam without installing the balancer or put torque on the Crank Shaft bolt.
It slips over the crank shaft and engages with the key to turn the motor. It has a knurl bolt to tighten against the Degree wheel. Pretty cool - I recommend. I got it on Amazon - it's made by Comp Cams.
Here it is in use. I'm not as happy with my cylinder bridge. There is no way to secure it to the block so I ended up just turning the block 90 degrees.
I also inspected the heads, the lifters, push rods, rockers, oil pan, harmonic balancer and timing cover and made sure I have all the bolts I need, valve guides and rocker studs. So once I get a new spider tray and lifter retainers I should be able to get most of the engine build done. Though I should probably pull out the water pump, oil pump, and intake manifold as well.
Not sure if I have to have a Fuel Eccentric. But I decided it is probably better to install one and not use then want to use the motor with a Carb + Mechanical pump and not have it. But continuing the theme of parts that don't come in kits when building up a short block here is another to add to the list.
Yep, better to have it and not need it than visa-versa
Got a new fuel pump eccentric and installed it today, plus torqued down the cam bolt.
Then I had some help putting the lifters, dog bones, and spider tray in.
The rest of the plan today was to check the valve to head clearance and hopefully bolt the heads down and install the rocker studs, push rods, push rod guides, and rockers today... So we put some clay in the first pistons recesses. bolted the head down. Set up the studs and guides for cylinder one...
and...
The push rods are too long. It looks like I was sent 351 pushrods by the supplier. I'm thinking this happened because their tech support said I need the 351 ARP head bolts for the boss block (and they seemed to fit fine) and when I ordered just ask for the swap. My guess is they saw 351 head bolts and also swapped in the 351 push rods which are 1.5 inches longer. So again I'll be waiting for parts as this becomes a very drawn out engine build.
Last weekend my younger daughter and I visited John Ibele and he gave us a nice tutorial on home powder coating, while also doing some sample parts for us. It was as usual great to hang out and learn something knew. Plus see some of the finishing work he is doing on his car.
Thanks again John!!!
Nice looking engine so far! You're going to have to measure the pushrod length with all of those aftermarket parts. Use something like one of these.
You're looking for a particular position and pattern on the valve tip, I'll let you Google & YouTube that part so you have nice visuals. This one from Summit is okay, I've seen better.
Thanks for the information Mike. The top end kit was supposed to take that all into account. I think the guys who packed up my order saw 351 head bolts which the Boss Block needs and thought I was building a 351 and sent the push rods for that. But after watching the video I think I will confirm the length when I get the ones that are supposed to be in the kit using the technique in the video above. Then if I don't see the pattern expected like in the video I'll stop get the checker and figure out the length.
Received replacement push rods from my supplier. They didn't make any fuss just said send them back and we'll swap them. That is after I had them nearly 2 years. So I proceeded to install them on a cylinder and complete a Valve to Piston clearance check and verify the push rod length.
Here is a fun pic showing the difference in length. Also I realize I didn't send a pushrod back so I'll have to package it up and mail it back.
Here is the pushrod length test. Looks like the rockers are contacting the middle of the valve stem as expects so I'm calling this a pass.
Here is the Valve to Cylinder results. There is plenty of room so another pass.
And the heads go on..
on to the valve train
I did initially set the valve lash but felt I was over tightening so I backed everything off for now and plan to review the proper procedure and start over again next time I get out there. But it's starting to look like a engine.
I was just catching up on your build. Just thought I'd ask. Did you degree your cam off the number 5 cylinder? Ford small blocks engine firing order are Right(Passenger side) bank 1-2-3-4, left bank 5-6-7-8. Right bank closest to the front is #1. 302HO/351W Firing order is 1-3-7-2-6-5-4-8. I you try to set your dizzy up to fire #1 at the #5TDC I'm sure it won't work out.
Degreeing the cam is just measuring that cam lift happens at the correct time in the rotation of the engine and if not changing the timing by a couple degrees if necessary. It doesn't affect the firing order as far as I know. The timing is hard to mess up, in this case simply line up dot to dot on the timing gears. The timing set I had wouldn't even install until I had the gears, chain, dots, cam dowl, and chuck lined up perfectly. Additionally the hyper spark distributor I'm going to use has a tool to help set the timing when installing it. So as long as I wire the plugs correctly I should be good.
As for the Cam Degree -
Yes I did use number 5. I honestly don't know it matters as the lift/duration should be the same for each cylinder. It was also pretty much right on to what the card said it should be which gives me confidence.
I watched 1/2 dozen videos and they all used the front right cylinder. I don't remember them calling out the Number 1 cylinder but could have missed it. I mimicked the videos pretty much step for step. I guess next time I would do it on the other side but I'm not super worried that I would get a different outcome.
All of that said now I just did a search on videos to degree a cam including Ford and the three I found do show it on the #1 Cylinder. Wish they had been higher in the list I didn't think made a difference what engine the procedure is done on.
If anyone out there knows for sure that using the number 5 cylinder would give me a bad reading please let me know. It's not too late to start over, just a set of new gaskets.
If you are using the #5 cylinder and setting the degree wheel to #5 TDC then you need to be sure you are using the #5 intake lobe for Intake Centerline, Intake Open Angle and Intake Close Angle.
BUDFIVE
Complete kit order 8/28/2023
347 Ford Dyno 10/12/2023
Kit Delivery 11/28/2023
First Start 7/4/2024
Go Cart 8/31/2024
I’m trying to paste the right picture from my 347 build last summer to show #5 intake is the fourth lobe.IMG_0918.jpg
BUDFIVE
Go Cart 8/31/2024
I'm sure the cam timing will be just fine.
Just looking at the picture, my mind goes to setting the pointer on the balancer at TDC off the #1. Plug wire location doesn't matter too much (as long as they are in the correct order) however different EFI setups use various pick ups to fire the injectors at the right time (some being in the dizzy). I have confidence that you'll have it sorted just right at the time of the first start.
Continuing the fun adventure of learning as I go I attempted to install the Timing Cover a couple weeks ago only to find out that Ford Performance changed the bolt size for the lower 4 bolt's on the Boss Block. So the ARP kit I purchased from LMR didn't cover everything I needed. This was mentioned in the Bock's documentation but just barely. Nearly fine print. So i purchased a lot of different 3/8-16 in various lengths. If this happens to anyone else I think (2) 2 and 1/8 and 2 2 inch bolts will do the trick. I ended up using 2 1/4 bolts, 1 2 inch bolt, and one 1 3/4 bolt. They engaged with plenty of threads, and should work fine but "next" I'll have bolts that match a little better.
And yes I know the block is not the same 'Ford' blue as the timing cover, water pump, and oil pan. I painted them at home instead of at the shop. Had I realized I need to paint the block too I would have sprayed it all together. But a little brush on paint will make it all match.
The water pump went on pretty Easy next.
On to the fuel pump. Though I'm going to post this pick of the bottom end. Looks like who ever put the short block together took their time.
Looks like good clearance.
Finally having checking the clearance to for the crank, rods, and pick up I put on the oil pan. Everything seems to fit well, I turned the engine over and didn't here anything run or feel additional friction anywhere. I pulled the pan and looked at the interior none of the baffles were scuffed or scratched.
Not bad for a days work. I did have to chase some threads for the bigger oil pan bolts. But other than that this was a smooth day.
Smooth except when I was fitting the intake I found another bolt that needs the hole's threads dealt with. That will have to wait till later this week. Also the valve covers are really just on to keep junk out of the motor. I want to take them off when I prime the engine to make sure I see oil come up on both sides.
Not sure if this is a normal milestone but I'm calling engine assembly done after this weekend.
First I brush painted the block in the correct blue to match the tins. Then I clear coated the aluminum and bare steel parts. I know things won't look new forever but the longer the better.
I know on anther project this bit of steel was a bit problematic.
Then I did a little baking. Pretty Simple Recipe, 1 Harmonic Balancer for 30 min at 225 f:
Pressed on/installed the balancer, installed the intake manifold and a finished motor. Here is the Glamor Shot (my friend said I should take the photo in portrait mode for affect what do you think).
While cooking the Balancer we decided to install the bracket and press on the pulley for the Power Steering. This took WAY longer than I expected. It went smoothly it just took forever.
Used a kit from Harbor Freight and off the vehicle it was a little hard to secure everything. Next week I'm hoping to get the engine off the engine stand and then install the flywheel, start to mock up the accessories, and fit the Bellhousing.
Looks Great! Awesome work!
Matt, that just looks like an awesome motor and great progress. Wish I had your skills! Someday maybe I'll take the dive and build one up, at least from a short block. Until then I'll enjoy keeping tabs on your progress. Would like to be there when you fire it up!
Ufffda it's been a month since my last post. I've been out of town a lot for work and spring break and the kids have had a lot of spring hockey. So one month later I finally got an evening in the garage. No major changes. But it was nice to get out there.
First I picked up the wheels from the powder coater. Can't wait to get tire's mounted.
I put the frost plug in the dipstick hole as the oil pan has one.
Temporarily installed the flywheel and steel separation plate.
Next I installed the bellhousing and measured it to confirm alignment.
Sure enough I need the offset dowels. So that's as far as I'm getting on that this week. If I can get back to the shop the list is still pretty long to get me to first start.
Thanks John. You will be welcome to come by and I'll let you know when. It's going to be mid summer I think at this point. I just paid the Tax man and it will be at least a month before I can order the transmission. Also I'm sure you have the skills to assemble a motor. You already did something as complicated as a rear end and some of you fabrication is really nice.
I guess 3 weeks between posts is better than a month. Lots keeping me away from the shop, but finally got some time in.
I got the Offset dowels. Installed them facing opposite from where I was off. But I had a time getting the factory dowels out. A friend showed me a cool trick though. Apparently you can take the adjusting bolt out of a vise grip and slide hammers have an adapter that replaces it.
Now with the new pins in, the Fly Wheel installed and torqued, and the bell housing installed and torqued I could take readings again. To my surprise the new readings didn't make any sense. I was actually more out of alignment than before. It was very strange. I remeasured 1/2 dozen times. I purchased a different magnetic base to get a better angle. But still got the weird readings.
So I decided to start over. I took everything apart again and replaced the stock dowels. I started to recheck the mating surface on the block, looked good. Rechecked the mating service on the bell housing that looked good. So I went to recheck the separator plate and I noticed a perfect circle pressed in.
So I looked at the block and found a screw in freeze plug that sticks out past the mating surfaces. It was pushing on the separator plate. Not the best photo but you can see the straight edge cannot lay flat.
As I was getting super frustrated I took a little break. I Just wanted some forward progress so i did a couple other tasks. I repaired the treads on a wheel stud that had gotten cross treaded. Then I decided to put the pilot bearing in. I had seen a neat trick online to use a steering wheel puller as a press. Worked perfectly.
Next I thought about the separator plate. I tried screwing the frost plug in more with no luck. I pulled it out checked and there was noting in the treads and they were in good shape so that is as far in as it will go. I talked to a friend and he said to face the frost plug, but I didn't think this was a good idea because it seemed it would be too thin to hold the o-ring in place. Looking at the Summit and Ford Racing Plate and they have holes right where the indent is.
So I cut a whole in mine.
I put everything back together and torqued the bolts. Setup the dial indicator and remeasured. Sure enough everything is in line now; .00225 off less than 1/2 the .005 tolerance.
So the bell housing and separator plate are sorted out. It all has to come apart at least one more time to install the clutch. I also need to re-install the flywheel bolts with some sealer.
I'm really glad I took the time to go by the book though and do this check because in the future either the transmission would not have gone in or it would have and then wear out in a couple thousand miles.
Nice find, albeit very frustrating for you.
Now that the Bellhousing centerline has been checked it was time to do final install on the Flywheel.
I recleaned all the surfaces, threads on the bolts, and bolt holes. Then I pressed in the clutch locating dowels.
Then I lined up the holes in the flywheel to the crank, dabbed some sealer on the bolts, and torqued them down for hopefully the last time.
Next I used the locating tool that came with the clutch to set the disk. Making sure the side that said toward the fly wheel - was toward the flywheel.
Next I set the clutch over the disk. Then started to bolt down the clutch while holding the centering tool in place. It seems to wiggle a little and I didn't like that. And there we go an installed clutch.
After that I installed my coil to the bracket and did a quick mock up of what that might look like.
it might be a little low and rub the power steering pump. We'll see later this week when I try to mock up the power steering pump. This bracket is not exactly for the Holly Hyper spark coil. So I might have to order a newer version specific to that coil that didn't exist 2 years ago when I ordered this one. But fingers crossed I don't have to.
I also was going to test out my powder coating kit, but need some connectors. So it's mostly setup but will have to wait.
Got the powder coating setup running. It's a lot of fun. Tested a piece of scrap with minimal prep. It came out ok.
Then I moved on to some switch guards.
They came out perfect thought the phono doesn't show detail
https://mattglaeser.smugmug.com/Home...er/i-R3x6RLg/A
Received my TKX this week. Got it to the shop today and un-boxed it. I thought about making an unboxing video for all the kids but didn't have the time. Only really did a quick visual inspection I'll double check it goes through all the gears next time I'm out there per the instructions.
First thing in the box... a Warning Label - test your transmission prior to install
Lots of good packing
and there she is in all her new transmission goodness
It was a bit of a nesting doll type of situation with boxes within boxes
Out of the box and ready to be tested and installed
It was basically Christmas morning for me.
Question:
When you checked your p-v clearance, what did you do to ensure your hydraulic lifters didn't compress? I'm nearly at this stage with my 427 BOSS. I have a short block and valvetrain combo set from summit, so I'm sure the pushrods, hydraulic lifters, roller rockers and heads that came in the combo kit will play nice together, but I want to make sure. Haven't sorted out the best way to ensure my lifter doesn't compress when I check, and I don't really want to remove the pre-installed valve springs on my TFS heads.
Greg
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Edelbrock Pro Flow 4, TKX, IRS, Wilwood Big Brakes
I used valvetrain checking springs like these.
This is pretty similar to a photo I posted before but I finally got all of the switches, gauges, switch guards, oh **** handle, etc into the dash. Nothing is connected on the back side but I really wanted to see what it looks like. Pretty much exactly how I planned it. I could not be happier with how it came out.
