Thanks Thanks:  5
Results 1 to 14 of 14
Thread: Metco saftey loop
    Member Buzzsaw's Avatar
    Jul 2023
    Belmont NC
    Metco saftey loop
    Installed my drive line safety loop today. I only have an 1/8” clearance with the drive shaft. Obviously I need a couple of spacers just wondering how much space is needed. I don’t think the short drive line moves much but would like to know what spacing other member have. Any help would be appreciated.
    Ross.
    MK4 kit delivered 11-5-2023 Forte’s Ford 302, Edelbrock Pro Flow 4 fuel injection, Tremec TKX transmission mid shift option, 355 ratio rear end, 17”wheels, 2015 Mustang IRS from FFR
    Santa Clarita, CA.
    Metco Spacers
    I think I only added about 1/4" to mine. No issues with clearance. You can see the spacers in the photo below.
  3. Thanks Buzzsaw thanked for this post
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I used grade 8 washers as spacers. I also had to go with longer bolts.
  5. Thanks Buzzsaw thanked for this post
  6. #4
    So. Bay (So. Calif.)
    If I remember correctly, I think I went 3/8 inch. Could be 1/2 inch. I would have gone a tad more, but the forward edge of the hoop was rubbing on the brake cables. I beveled that outside edge of the hoop to get rid of the sharp edge. They still touch but not enough to wear on the cables.
    There is a small, slight scratch on the drive shaft, so it looks like it may have just barely touched the the inside of the hoop. I'm pretty sure that happened before I added the spacer. It doesn't look to be a problem, since it looks only to be a one time occurrence, and the hoop has a bit of flex, so I don't see it being a problem.
  7. Thanks Buzzsaw thanked for this post
  8. #5
    Jul 2023
    New Braunfels, TX
    I had the same issue. I just used my floor jack, put it under the loop and jacked it up to "bend it" into having proper clearance. Worked like a charm.
  9. Thanks Buzzsaw thanked for this post
  10. #6
    Jul 2023
    Belmont NC
    CDXXVII, JohnK, boat737
    Guy thank you so much, you guys crawled under your cars for pictures! Forum people and their support is amazing!
    I am also going to have to cut 1/2” off the foreword side of the mounting bracket. The back side of the loop is rubbing my differential side knuckle. I am going to add 1” spacers giving me 1-1/8 inch clearance from to of drive line to bottom of the driveline loop.
  11. #7
    Oct 2020
    Albany, NY
    Looks like I didn't need any. I suppose there must be a significant height difference between the 302, 351 and Coyote.
    MK4 #10008 - Ordered 10/06/20, Delivered 03/03/21, First Start 7/22/21, First Go Kart 7/24/21, Graduated 7/20/22 - Sold 6/6/24
    Build Thread https://thefactoryfiveforum.com/show...been-delivered
    MK4 - Ordered 6/5/24
  12. Thanks Buzzsaw thanked for this post
  13. #8
    Senior Member dbo_texas's Avatar
    Feb 2018
    Austin, TX
    Originally I had washers for spacers, but didn't feel comfortable with that solution as I was worried they could move around over time due to vibration. I recently added (2x) 1/4" spacer plates to my Metco safety loop for a total of 0.5". This gives me plenty of clearance around the driveshaft. I have Gen2 Coyote + T56 so I had to make some other modifications to the safety loop for it to center over the driveshaft - basically had to shorten it and extend a few of the slots so I could slide it more towards the transmission. Details in my build thread HERE
    Darryl [dbo_texas]
  14. #9
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    In part, it depends on how many shims you have to add to the trans support to get the correct driveline angle. I had to shim it quite a bit to get the driveline angles I wanted, which raised the output shaft of the TKO600 quite a bit.
  15. #10
    Jul 2023
    Belmont NC
    Quote Originally Posted by dbo_texas View Post
    Thanks dbo_texas, I am going to have to modify the mounting bracket too. Looks like one size does not fit all!
  16. #11
    Feb 2018
    Austin, TX
    Yeah with the super short driveshaft on the Coyote+T56 it put the loop to far towards the rear so part of it was almost overlapping the U-joint vs. the actual cylindrical shaft portion. Modifying it was pretty easy as described in my build thread (Post #172).
    For your spacers, you could use washers, or just get some 1" x 1/4" aluminum bar from big box store and cut to length, then drill some holes. I cut mine with a laser cutter because I have access to one, but it is super simple to make one with basic tools.
    Darryl [dbo_texas]
  17. #12
    May 2018
    Milwaukee, WI
    I had this same issue with the TKX sub-frame since the "plate" at the rear is smaller in dimension that FFR's traditional sub-frame for the TKO. Glad to see I'm not the only one that had to trim/modify the drive shaft loop to fit.
    BUILD THREAD: The Brew City Cobra
    Current Build: MK4 Complete Kit, Delivered December 2021; First Start November 9, 2022; Go-Cart November 23, 2022; Carbureted 427W, TKX, IRS
  18. #13
    Jul 2023
    Belmont NC
    Just to give the final report to the thread I started,
    I made 4 sets of 2” long spacers out of 1” wide 1/4” thick steel.(8 spacers total) and cut off 1/2” from the front side or engine side of the bracket. That put my safety loop right in the middle of the drive shaft with 1-1/4” clearence from top of shaft to bottom of the loop. Thanks to everyone who took the time to take pictures and answer my post. Forum members are the best!
  19. #14
    So why did you do that? The drive shaft doesn't move up or down, you have IRS.
