04-07-2024, 10:48 AM
#1161
Fat Larrys Garage
Paul on your interior is that carpet from FFR or your interior shop
Yes, the standard kit supplied Coupe carpet kit. I've used it on all my builds. Sometimes doesn't get a lot of love, but I've found it works fine. I always use floor mats and a pad by the accelerator. Will wear in the those areas but everywhere else seems to hold up fine. I tried a recommended alternative (Bentley) for one of my builds. But ended up putting it in the trunk as still used the kit carpet.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
04-10-2024, 02:13 PM
#1162
Hola Paul,
I'm not good at these posts and maybe I shouldn't have put this post here but thought it might be close.
I've completed my Daytona. My builder said it was easy. All I had to do was follow edwardb's posts and it all came out fine.
Now I am fine tuning the setup for the track. I just did my first day with a professional driver in the left seat. He is a brave man to take out an unknown quantity and try and make it work on a race track, ECR (Eagles Canyon Raceway ten miles away).
My car had terrible oversteer. I have installed the FFR front and rear sway bars. My drive buddy says we need to loosen up the back and tighten up the front. After our session we put the car on the lift and tried to move the rear sway bar back a couple notches but the supplied rod ends don't appear to be adjustable to reach. The front sway bar presently also does not appear to be vertical and the rod ends are also slanted a bit. The spacer appears to be too big.
I know you don't track your car but your familiarity with all things Daytona I thought you might give me some direction on who to ask for set up issues with the sway bars.
I did get a trophy in the car show at SVRA weekend at ECR thanks to your input.
Best,
Lou Garvin
04-10-2024, 02:30 PM
#1163
Lougarvin
Hola Paul,
Best,
Lou Garvin
Hello Lou. Congrats on your completed Coupe and award. Glad my build thread may have been of some use. You're right, I don't track my Coupe. Only on the street and the standard Factory Five sway bar setup isn't limiting me at all. (Or at least if it is, I don't know it. ) I can't give you any specific recommendations. I'd suggest you make a new post describing your situation. There are others on here with track experience and I'm sure could offer some advice. Good luck.
Build Thread and
Video.
Build Thread and
Video
04-10-2024, 05:22 PM
#1164
Lots of Autocross and track days between Dave and myself and we will both tell you to ditch the rear bar.
04-19-2024, 04:39 AM
#1165
Paul good morning I am looking into rims for the car more than likely going with Forgstar F14 I have been looking to do 18 inch front and 19 inch rear I see that you went 18 inch all the way around and your car sits nice does the 18 fill the rear wheel well and I believe you also used wheel spacers on the rear any reason for the spacers you you just wanted to push the wheel to the outside to look better
04-19-2024, 05:16 AM
#1166
Fat Larrys Garage
I have Factory Five rims. They don't offer 19's. So yes, 18's all around. The rear spacers are to push the wheels out into the openings for better appearance as you describe. The Coupe uses the same rear suspension setup(s) as the Roadster but the body is wider.
Build Thread and
Video.
Build Thread and
Video
04-20-2024, 03:27 PM
#1167
Paul do you remember if you got the oil filter new threaded adapter piece once you remove the oil cooler piece
04-20-2024, 11:25 PM
#1168
Fat Larrys Garage
When you remove the oil cooler, the long adapter must be replaced with a Ford AL3Z-6890-A Oil filter adapter (short). Got mine from Tasca Parts. But available from multiple sources.
https://www.tascaparts.com/oem-parts...sert-al3z6890a
Build Thread and
Video.
Build Thread and
Video
04-21-2024, 06:52 AM
#1169
04-23-2024, 01:10 PM
#1170
Hello Paul,
Many thanks for your response and suggestion to figure out these sway bars and how to adjust them. It's a work in progress and I'm taking my time.
Best regards,
Lou
04-24-2024, 10:07 PM
#1171
Hey Paul, got another question for you. I have been reading a thread where a Gen 3 Coupe owner is struggling with oversteer on his car newly finished car at the track. He is running both front and rear sway bars and struggling to come up with a configuration that is not tail happy. What did you do on you build, no bars, front only, or both? I checked the options box for both front and rear sway bars with the rear being the 2015 and up IRS. I have time to finalize my kit order, but it would sure be nice to eliminate the rear bar, or both, if they are truly unnecessary on a high performance street car.
As always, thanks in advance.
Alan
04-25-2024, 06:06 AM
#1172
Alan_C
Alan
My Coupe has the Factory Five bars on both front and back. For my driving, 100% street, I can't say I've noticed anything positive or negative about them. The car handles great and I wouldn't change a thing. But I'm a relatively conservative driver and zero track experience. So take that for what it's worth. One comment, and maybe you know this, but the front bars can be mounted after the fact. Easy. The rear requires two brackets that are bolted in as you build up the suspension. Even if you don't install the rear bar initially, you may want to get those brackets and install during the build. Saves taking things apart later.
Build Thread and
Video.
Build Thread and
Video
05-18-2024, 12:26 PM
#1173
Paul getting ready to start wiring the car any advice since you been thru it already do’s and don’t I always like to ask so I don’t make the same mistake seems pretty straight forward and after doing almost 15 different cars this one maybe the easiest
05-18-2024, 10:50 PM
#1174
Fat Larrys Garage
There's no one way to wire these cars. Everyone tends to put their on spin on it. I start each build with an electrical plan identifying the power requirements, fuse/breaker requirements (for circuits outside the Ron Francis harness), wire sizes, etc. I typically mock up the location of all the components first. In this case, including the Coyote specific components as well. Then start laying in the wiring. Because space was so limited behind the dash because of the A/C and the glove box, I significantly dieted the Ron Francis harness, e.g. shortened wires, removed connectors, etc. That's not for everyone though. If in doubt, leave it stock. I also try to think about future maintenance if required. I specifically wired and mounted the gauge cluster so that it could be removed. Which also provides access behind the dash and the components mounted on the tunnel. That's all I can think of at the moment. Lots more words and pictures earlier in this build thread of the wiring.
Build Thread and
Video.
Build Thread and
Video
05-19-2024, 08:52 AM
#1175
Thanks Paul I will just get into it and see how it flows
05-21-2024, 07:08 PM
#1176
Paul when you replaced the Gen 3 Coyote oil pan did you purchase a new oil pan pickup it looks like you tried to make a pickup yourself I assume maybe they have a new pickup for the Morosso oil pan by now
05-21-2024, 08:42 PM
#1177
Fat Larrys Garage
I was very early in the Gen 3 Coyote timeline. Moroso didn't have a pickup for the Gen 3 so I had to make one. A couple failed attempts as described in the build thread. Then success. Much later Moroso did release a Gen 3 version. The Moroso pan used with the Coyote in these builds is their standard offering part #20570. You'll also need: Part #24577 oil pickup for the Gen 3, part #22738 low warning sensor plug since we don't typically use that sensor with the crate motor, and a BR3Z-6710-A oil pan gasket/windage tray since the Gen 3 has a composite oil pan with integrated gasket/windage tray.
Note these same part numbers are listed in the Factory Five Gen 3 Coyote installation instructions at: https://www.factoryfive.com/wp-conte...ter-rev-1i.pdf.
Build Thread and
Video.
Build Thread and
Video
05-31-2024, 03:52 AM
#1178
Paul good morning wondering what color you picked for your car I was thinking of Brandywine Cherry over black for mine of all my builds I don’t think I ever had a red series car, also the factory five window setup is it good enough to hold some of the AC in the car or does it leak alot
05-31-2024, 05:16 AM
#1179
Fat Larrys Garage
Paint color is mentioned a couple times in the build thread including here: https://thefactoryfiveforum.com/show...l=1#post391649
The Factory Five window kit seals OK around the perimeter if you take the time with gaskets. The sliding windows aren't wind or water proof. But they are adequate. I don't hear anything from them over the rest of the sound in the car. They definitely help to keep the A/C (and heat) inside. I've only driven the car without them once and don't plan to do that again.
Build Thread and
Video.
Build Thread and
Video
Paul good morning since you seem to be the man with all answers I posted a question yesterday about the clutch safety switch I have two identical switches and brackets that came with the kit I would assume one is for the brakes and the other for the clutch depending on where you attach the wires just let me know your thoughts the reason I ask is the switch doesn’t look like the one you used.
