Results 1 to 4 of 4
Thread: Anyone in the group have the IRS in the MK4 that can give me a Specs on some mounting
    Sep 2022
    Anyone in the group have the IRS in the MK4 that can give me a Specs on some mounting holes??The front Upper Control Arm Mounting holes with the washer. I need the distance from left to right center to center of the hole !!
    https://thefactoryfiveforum.com/atta...&thumb=1&stc=1
    Senior Member gbranham's Avatar
    Jul 2021
    Tonganoxie, KS
    Which holes, and what specs are you looking for? I see the red 'X's in your photo, but it's unclear what you're looking for. If you're talking about the front bushings, here's a pic from the build manual. The inner sleeve is 3-1/16". Not sure the diameter of the bushing itself.
    Built an early MkIII years ago, sold years ago.
    Got Corvettes out of my system, and now back after 18 years to build a MkIV.
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Edelbrock Pro Flow 4, TKX, IRS, Wilwood Big Brakes
    Here to learn, contribute, and have fun!
    Sep 2022
    The front upper mounts of the IRS center to center of the bolt holes, the holes with the washer !!
    Jul 2021
    Tonganoxie, KS
    I took a rough measurement with a tape measure, and it's pretty darn close to 14" center to center.
