Thanks Thanks:  3
Likes Likes:  12
Page 2 of 2 FirstFirst 12
Results 41 to 79 of 79
Thread: Brent's Ford 351 Cleveland Coupe Build
    Mar 2021
    Ohio
    Sheetmetal Updates
    I have been working on putting a second skin of sheetmetal on the frame. The plan is to spray in urethane foam to help with noise and heat. This will give me at least an inch thickness. This also gives me a decent amount of addition space below the console to route and mount things.
    I also have been working on closing off the underside of the back end and closing off the rear wheel wheels.
    Once everything is fit, I will spray it with Upol under coating. Hopefully this is worth the investment in time, it takes a while to do all this.
  2. Likes rhk118 liked this post
  3. #42
    Senior Member rhk118's Avatar
    Nov 2021
    Portland, Maine
    Brent - that is an impressive amount of work and looks great!
  4. #43
    Mar 2021
    Ohio
    Quote Originally Posted by rhk118 View Post
    Thanks. I am hoping that closing off the rear end doesn't cause any issues at speed. I was doing some research on the spray foam and it apparently causes the sheetmetal to warp, so I may have to put some sort of flexible barrier on the sheetmetal before spraying it in.
  5. Likes rhk118 liked this post
  6. #44
    Mar 2021
    Ohio
    Forte Accelerator Pedal Mod
    I was asked how I modified the Forte gas pedal to use the FFR supplied pedal pad. Here are some pictures of it. I cut off the pedal pad, drilled a hole for the pivot, and used the arm to support the return spring. This will get painted black when I am done with fabricating everthing. I also bent the arm some to get the angle right.
  7. Likes rhk118 liked this post
  8. #45
    Mar 2021
    Ohio
    Sheetmetal Continues
    The never ending project of sheetmetal continues. I got the back wall of the cockpit closed in and the underside of the trunk. Also made a new firewall that is better fitting. Kind of hard to see.
  9. #46
    Mar 2021
    Ohio
    Driveshaft Safety Hoop
    I picked up this driveshaft safety hoop from Summit, it is really beefy, and well made. Comes with grade 8 hardware and bolts right to the TKX. No need for any welding or drilling more holes in the frame. It does add some thickness to the mount, but I have to make a spacer anyways.
    Stifflers Suspension Driveshaft Safety Loops DSL-M02
  10. Likes rhk118 liked this post
  11. #47
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Being canatlevered off the transmission mount, I wonder how much vibration there will be and how much clearance with the crossmembers. I am very interested with this setup so keep us updated!
    Scott Pregont
    My Albums
  12. #48
    Mar 2021
    Ohio
    More Sheet Metal and Brake Bias Cable
    I got some more time in the garage and was able to get the inside skin done on the drivers footbox. This will give me 1-1.5 inches of air gap from the engine bay. I also added a pocket for a foot rest on the outside wall. All of this will get covered with capet when done and I plan to seal any gaps with seam sealer.
    In preparation for powder coating the frame, I modifed the frame so that I could run my brake bias cable out the right side of the pedal box, through the engine bay, and back into the car.
    I found these universal rubber grommets on that jungle website. They fit really well around the cable and should provide a fair amount of room for play.
    Next up is the passager side, it is mostly done, but I need to finish trimming out the pocket for the foot rest.
  13. #49
    Mar 2021
    Ohio
    Center Console and Dash Updates
    I made some more progress on interior stuff this weekend. I constructed some panels to close off under the dash in front of the foot boxes and made a one piece cover for the top of the transmission tunnel. I plan on using some sentra to cap the edges of the transmission tunnel and to cover the sides of the transmission tunnel. All of these panels will be covered with leather when done.
    I have also done some layout work on the lower dash section for the efi screen and toggle switches. The text and temp controls will be backlit through white translucent acrylic. The housing will be 3D printed out of glass filled nylon and then painted black with Gunkote.
    I plan on using a linear pot for the temp control and a 4 postion linear switch for the fan speed. I will custom machine the knobs to match the other knobs in the car. I should be able to make some progress on the dash controls while waiting on the frame to be powder coated.
  14. #50
    Jul 2022
    Your dash looks great. Very nice work! Your double skin work wiht the aluminum sheeting is impressive - what a lot of work! I had wondered about doing something similar but much less extensive than what you are doing. But have chosen not to, at least for now. I've taken my own approach to the dash and made a fiberglass box to cover my fuse box - but it is all much less extensive than what your are doing. Very impressed!
  15. #51
    Mar 2021
    Ohio
    Quote Originally Posted by jgray View Post
    Thanks! The Harbor Freight box brake makes easy work of it. Had to make lots of cardboard floor protector templates before actually cutting metal. Using a track saw with a non ferrous blade makes short work of the cuts and makes them clean.
  16. #52
    Mar 2021
    Ohio
    Got one of the switches mocked up and tested the backlighting. This is 3D printed out of nylon and then I laser cut some translucent white acrylic, laser cut black vinyl for the text and put that on the white acrylic, and then there is a laser cut piece of clear acrylic to protect the vinyl. I will have some led's mounted to a plate in the back that screws on, waiting for those to come from Digikey. These will get painted black with Gunkote. I used the Carling switches that others have used on the forum. Lots of options for switch configurations and they have a collar to hide the threads. Gives it a nice finished look. The top bezel and lower bezel will form a clamshell through holes in the dash and threading the nut over the switch will hold it all in place. I will post more details as they develop.
  17. Likes Namrups liked this post
  18. #53
    Jul 2022
    Your work is impressive Brent. The 3D rendering is very cool and your use of a 3D printer and laser cut is nice work. You sure have a lot of great tools and are putting them to good use. The outcome will be quite unique with all the double skin work you are doing too
    Do you know of a source for bezels for the regular switches that FFR provides? I would like something simple to just hide the threads. I’ve also been looking at various forms of labels but with my layout of switches on my custom switch panel it could look to busy. I’ll post some pictures of the panel soon. But I do know I would like to cover the threads
  19. #54
    Mar 2021
    Ohio
    Thanks! I do product development for a living and have a lot of toys at work that I have access to. I was looking at this site before I found these switches. They have several options at a good price.
    https://lovemyswitches.com/search.ph...ry=Dress%20nut
    If you google decorative toggle switch nut you will find more. I would love to see what you have for your dash layout.
  20. #55
    Nov 2021
    Portland, Maine
    Quote Originally Posted by burchfieldb View Post
    Wow, love that site Brent, it's totally nuts! ...totally off topic but I had found this site: newwiremarine.com and they will make custom switch panels and have all marine-grade switches, distribution blocks/fuse panels and they sell stainless switch nuts. I think I like the black ones on the site you found better.
  21. #56
    Mar 2021
    Ohio
    Post
    That is a cool site. I like the custom panel configurator and the different custom switch and button options. I have been looking for different options for a fused relay holder and came across this Bussman holder that GT_Rich used. I still need to determine how many relays I am going to need. It looks like new wire has 2 relay blocks, I wonder if they have ones with more. I am open to other options if you know of other larger format ones. I think I will need at least 6. I really am not a fan of the prewired relay sockets, I have had issues in the past with the socket connections not being good.
    https://racespeconline.com/products/...BoCYDEQAvD_BwE
  22. #57
    Sep 2020
    If it helps, I am using GEP Power Products Relay holders which are very similar to the Eaton Bussmann unit you are considering. I have used the Eaton Bussmann RTMR series on other projects and they are fine units. The covers on them are very tall (designed to allow the tall ISO 280 (mini blade) style circuit breakers. For me the major limitations of the Bussman are 1) the cover height and 2) while the numbering is really nice, they don't really provide a "compact" solution as there is a lot of space between fuses and relays and you are limited that 5 relay 10 fuse configuration (note there is a much larger Bussman unit that allows 10 relays and 40 fuses - but previous experience wiring other vehicles is I like to add the relay holder closer to where it will be used versus a central "single" power distribution - the wiring bundles become more of a pain to route with the centralized approach). I like the GEP PDMs as they come in 12/24/48/72/96 cavity variants (though only 48/72/96 variants have the through panel mounting style. the 12/24 variants the mount is in the cap which can be both good and bad depending on where you want to locate them). I would also recommend looking at using ISO280 ultra micro relays (shown in the picture below). They only use 4 cavities (the normal micro 280 relays use 6) and come in 20A and 30A variants. With the more flexible configuration in the GEP sockets, you can quickly get more relays into the same space (which I have found is normally more the problem over total amperage capacity). Both the Eaton Bussman and the GEP use Metri Pak 280 hardware though the Bussman use tangless 280 terminals and the GEP are tanged IIRC (be careful when buying to get the right style). The connector seals are the same. GEP does offer Terminal Position Assurance (TPA's) that guarantee that the terminals won't come out - I have never used these as I have found the already supplied latches in the 280 terminals good enough. 280 terminals are very easy to de-pin if you ever want to change the contact (or like me, made a few mistakes with the pin positions the first time you wired them )
    I am planning on using a 72 position unit for the engine related fuse/relays and a 96 position unit for everything else on my coupe build (and I have a leftover 24 position that I may end up using if necessary)
    -Thomas
  23. #58
    Sep 2020
    Loving the custom work on the dash - it looks fantastic! The switch lights are very clean! One other comment on the above, LittelFuse also makes a larger format PDMs (18 and 60 cavity) that you may want to look at for options (I have never used them, but they seem very similar to GEP/Bussman)
  24. #59
    Mar 2021
    Ohio
    Quote Originally Posted by GT77 View Post
    Thanks, this is super helpful. Where do you usually buy them from? How far are you on your build?
    - Brent
  25. #60
    Sep 2020
    Waytek, I will PM you with more details. My build is a bit behind yours at this point - you have been making solid progress (well done!). It would help if I stopped modifying everything. However, my build thread is very out of date. Perhaps soon I will take some time to update with some of the various diversions. Keep up the good work!
    -Thomas
  26. #61
    Mar 2021
    Ohio
    I decided to address the side bars of the roll cage. It was just too close to my head when sitting in the car. So I decided to cut them out, make new ones with a slight arc bending outward to give more head clearance, and then moved them up some.
    View of the arc.
  27. #62
    Mar 2021
    Ohio
    Made some more progress today. Mounted the sun visors that I made using some Scott Drake visor rods, some hard board, a piece of stainless that I bent around the rod, and binding post to hold the hardboard to the stainless.
    Screenshot_20240121_202017_Amazon Shopping.jpg20240121_101005.jpg20240121_095417.jpg
    I will finish welding out the visor frame mount brackets tomorrow. I plan on 3D printing some covers to go over the visor mount brackets. I also closed off the ends of all the open frame tubes. There were 14 in all.
    Need to weld and grind the seams on the hinges and then drop everything off to the powder coater tomorrow afternoon.
  28. #63
    Mar 2021
    Ohio
    Got the frame back from powder coating today. It turned out really nice. For anyone in the Columbus Ohio area, Columbus Powder Coat does really good work.
  29. #64
    Mar 2021
    Ohio
    Started tackling the body this weekend and decided to build a body buck that moves up and down with a strap wench. This should make it easier to access different areas at a good standing height.
  30. #65
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Cant view pics.
    Scott Pregont
    My Albums
  31. #66
    Mar 2021
    Ohio
    That was odd, see if you can see them now.
  32. #67
    May 2021
    Fort Worth, Texas
    Nice buck.
  33. Thanks burchfieldb thanked for this post
  34. #68
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    good to go.
    Scott Pregont
    My Albums
  35. Thanks burchfieldb thanked for this post
  36. #69
    Mar 2021
    Ohio
    Ceramic Coating of Parts
    My OCD kicked in and I spent the last 4 days grinding off the parting lines from the castings, deburring sheet metal brackets, masking, sand blasting, unmasking, degreasing, masking again for paint, degreasing, and then painting. I painted all of the bushings and hood alignment plates with a silver metallic Gun-Kote from KG Industries. It is a hard abrasion and corrosion resistant ceramic coating, it is about a .0003 to .0004 of an inch thick coating, and you can apply it directly to metal without a primer. It won't scratch and is resistant to brake fluid and other chemicals.
    I coated the other castings and sheet metal brackets with Cerakote's black velvet ceramic coating and it matches the color and sheen of the FFR black powder coating on the control arms. This is an air cure coating, where as the Gun-Kote needs to be baked at 180 deg for 1 hour. Both are one part coatings, so you do not need to add a hardener. For the Gun-Kote you do have to add a temperature lowering additive for the Gun-Kote to get it down to 180 degs, or you have to cure at 300 deg. Here are some photos of the painted parts in the booth.
  37. #70
    Mar 2021
    Ohio
    Cont.
    The other benefit to the coating is that it acts as a lubricant and allows metal parts to slide easily against other coated parts. So this should help with the emergency brake parts.
    I sand blasted off the black zinc and black oxide coatings that was on any of the parts and recoated them with the ceramic coating, since it is super corrosion resistant and can withstand 500-1000 hours of salt spray, versus the 120 hours max for the black zinc.
    I have plans for doing more ceramic coating on all of the sheet metal in the engine bay and will post pictures once I get those done, these will be done in a black chrome Gun-Kote. Next up is to fiberglass in flanges to mount the wheel well liners and some body work.
  38. #71
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    That's an interesting coating. Kind of sounds like the perfect coating actually, especially if you don't need to bake it.
    I'm powder coating smaller items in an old kitchen oven, but no way could I fit any body panels.
    Do you have experience with this coating previously? How does it hold up?
  39. #72
    Mar 2021
    Ohio
    Quote Originally Posted by JimStone View Post
    Yeah, it is what people use on guns to protect the surface and make parts slide together without actual lubricant. This is from the Gun Kote site and Cerakote has similar information:
    "Gun Kote has a pencil hardness of 9H, will provide a 180-degree bend without fracturing and exhibits excellent impact resistance, lubricity (meets military dry firing specifications), heat dissipation, chemical resistance, corrosion protection, durability, scratch resistance and will not attract dirt or dust."
    You do need to make sure to follow all of the surface prep and application instructions or the coating will not perform. You can also use it on plastic parts to give them a good protective coating. Cerakote has a high gloss clear as well, that I am going to try on the polished aluminum parts of the car. I talked with them on the phone and they said you can apply it directly to polished aluminum.
    https://www.cerakote.com/shop/cerako...clear-aluminum
    My coworkers have used these coatings for years on stuff and have not seen any issues. It is not completely bullet proof, but is extremely durable.
  40. Thanks JimStone thanked for this post
  41. #73
    Mar 2021
    Ohio
    Raptor Liner
    Making some more headway coating the aluminum panels that I made to make a second skin on the underside of the car and for the rear wheel well liners. I decided to coat all of them with Raptor liner to help with noise deadening and protecting the panels. I blasted all of the panels with 100 grit aluminum oxide, cleaned them in a bath of Simple Green, and then wiped them down with wax and grease remover. The photo below shows them hanging in the booth afterwards and before priming.
    I then primed everything with Raptor Primer, this is what U-pol recommends for surface prep. It is a 2 part primer and is really easy to apply with an HVLP gun. This photo is after the primer is applied.
    If I had to do it over, I would use a reducer when mixing the Raptor Liner, and spray it out of an HVLP gun. The finish out of the schultz spray gun is pretty rough, doesn't spray real consistent, and goes everywhere. Below is the final finished product. I will do this for the front wheel well liners that you will see, the others are all hidden under the car.
    I will say the Raptor Liner is easy to mix and spray.
  42. #74
    Maybe you know UPOL sells a "professional" gun (#UP4880) that's an upgrade over their standard schutz spray gun. After having similar experience as yours with the schutz, I picked up their professional gun for my most recent build. With some reducer definitely sprays out to a better finish and is more adjustable. I'm a little concerned about the thickness you're adding to those parts. Hope they go together OK for you. A little late, but I see multiple builds where guys are adding coatings on the bottom of their builds for protection, etc. My Coupe has been driven multiple seasons and 7,000 miles now. The powder coating on the bottom still looks like brand new when cleaned. I have a couple scratches from a speed bump incident (grrr) but nothing is going to help that. I count on the insulation and carpet on the inside to provide the necessary sound and heat protection. Which it does.
  43. #75
    Mar 2021
    Ohio
    Thanks Paul. I was unaware of the upgraded gun. This one came with the kit. We will see how things end up fitting. Worst case, I may have to do a little sanding. This is more for reducing heat and sound, and less about frame protection.
  44. #76
    Mar 2021
    Ohio
    Do you have any photos of the pattern you were able to achieve with the pro gun?
  45. #77
    Mar 2021
    Ohio
    Life and Dash Update
    It has been a while since my last update. My wife was diagnosed with breast cancer, so I needed to divert my attention to making sure she has the support she needs. Fortunately they caught it early and it had not spread too far. Couple of surgeries later and now waiting to get all of the pieces lined up for radiation. The little bit of time I have to work is a good diversion to keep my mind off of things.
    I have been working on the dash for a while and got the center console assembled with the painted parts and toggle switches. The dash panel is made out of black acrylic right now until I get everything finalize on it and then it will get cut out of aluminum.
    This is the console panel on the bench with it lit up. I am waiting to put the EFI screen in the middle until I get the console sheet metal part painted.
    The vents in the dash are not painted yet, but the ones on the side console are painted with Cerakote and work well. They are fully adjustable by rotating the ball and have a friction mechanism behind the ball to keep them at the adjusted angle. Eventually they will be screwed in with some 4-40s, once I work through the side panel skins. All of these parts are 3D printed out of nylon, so they won't have any issues with the heat.
    I have also been working through the electrical and decided to abandon the FFR provided fuse panel. Some of the wires are undersized, need to be a larger gauge, and I wanted to clean up the harness. The main ones for me are the power supply for the in-tank Holley electric fuel pump and I wanted to increase the gauge for the cooling fan incase I want to upgrade it in the future. I also need to add several more relays and fuses. With space at a premium in the dash, I decided to move to a GEP PDM, which was recommended by another user, GT77. In doing so I had to relocate the flashers, so I 3D printed a new holder for those and will connect the wires with quick disconnects. These will be located in a pocket hidden up under the dash, so that they are still accessible.
    I will also have the PDM mounted flush under the dash so that it is hidden, but still accessible. This will be located on the passenger side.
    Next up will be tackling the sound deadening and insulation.
  46. #78
    Nov 2022
    Niles, MI
    I'm sorry to hear about your wife's health scare. Best wishes to her for a successful treatment and speedy recovery.
    I love all the custom touches on your car. Very unique and cool
    Gen 3 Coupe #576 - "Project Deimos"
    Ordered: 2/14/2024
    Received: 5/24/2024
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
  47. #79
    Mar 2021
    Ohio
    I was wanting to add some indicator lights so that I don't have to watch the gauges as closely. I ended up making one that matches my set of Nisonger gauges. I purchased the trim ring and glass from Nisonger. I 3D printed the housing and made the indicator inserts with the same process that I used for the toggle switch controls. I will use a voltage comparator for the alternator and fuel level monitoring and use switch senders for the temp and pressure. The cross bar will be painted black to match the other guages.
