Any and all advice/experience/confirmation with this set up will be greatly appreciated. I'm (still) installing a GenI Coyote with TKO 600 in my M4. Since I didn't get the Ford Racing Speed Dial before they discontinued it, I'm now trying to use the DD 100BT in it's place. I think I have most of what I need but would very much like the GenI ECU connector pin outs - specifically the T connector with pins 14 and 38. I've talked with DD Tech and they say that if those pins are the VSS speed sensors for the ECU, I should be in business. Thanks in advance
