Thanks Jeff, It will be on the inside of steering bracket and I plan to keep the outside of the steering shaft open, thanks for the great advice and always supporting the community!
Lance
Looks good. When you go to fire it up give me a call and I'll drive over and hold the fire extinguisher. Sounds like your getting close. I need to score some of those carbon fiber panels. I think you told me where you got'em but I forgot! I have some really great ideas for the lower switch / circuit breaker panel and want to use the carbon fiber. Give a shout if I can help in any way.
Allyn
Amazon...
My son came over this weekend and assisted with the rear Aluminum, so good to be done with that, we got the upper trunk, side walls and rear wall completed
Rear Wall.JPGPassenger Side Al rear panel.JPGDriver side Rear AL Panel.JPGTrunk Al complete.JPG
I completed the Dash final details, the under dash panels, EPAS controller and installed. I Used modern plastic fasteners for the under dash panel-to-Dash connection. They appear to be pretty good and I am happy. I bought several types to test and settled on a screw in type. The center portion is completely removable while the dash is installed to help access some of the switches and wiring. I installed the EPAS controller under the steering wheel for easy access.
But, Had 1 issue, hope I can fix without taking it back out-Center under dash light does not work, no voltage on the bulb supply wire....ARRGH!!!
As a final note, I finally got to test out my EPAS! I dropped the car on the wheels today (Garage door spring broke today and I needed to move the car back for the work) and was able to go lock to lock with my little pinky finger using the steering knuckle! I think I am going to like this!
good tip jeff. I used nutserts to be able to remove the dash supports.
Lance, the dash looks awsome. Love where you put the circuit breakers. I ordered several of those carbon fiber panels. I'll use one to drop the center of the dash down to the tunnel cover to install all the switches. One for under the right dash for all the circuit breakers and one under the left dash for the EPS switch panel. Really glad your out front blazing the trail for me!
Allyn
So, now that it is spring time almost, (had a few days of nice weather any way) my volunteer job picks up and my other household task pick up so build progress probably take a hit. Does not help when I bend installed panels.
I was jacking up to do the lower rad hose and my rubber block on the jack was not well positioned and it skidded to the side and the jack caught the bottom of the F-panel, so it got bent a little bit, enough that i want to replace it. So i ordered a new one.
I did get the radiator installed. Tested the Factory provided overflow tank-Only 30 ounces and does not fit well due to the alternator location. So, having heard all the stories about whether it is big enough or not, for my purpose I decided to go after market canton 1.75 qt with sight tube. I will post another question about clearance at that location on another post.
Obtained a 90 degree hose to do the elbow off the engine. For the corrugated hose, I added (4) 5/32 stainless rivets around 1 rib at the end of the tube. I got some bolt style clamps to install as well.
Went thru my parts and and cannot find the shoulder bolts for the hood hinges not sure if they would be in the hing parts bag or generic fastner box, but I do not remember seeing them ever and do not have a line item on the inventory. Sourced from McMaster , waiting on delivery
Slowly prepping for first start, maybe this weekend.
1) Added oil, cranked the motor for some pre-lube a few times, I just like being able to turn the key....
2) installed overflow/recovery tank and filled everything with water. Pulled a plug in the manifold to vent the block.
3) Secured the wiring harness in front to the radiator shroud with some screws and clamps
4)Installed trunk struts and started filling all the aluminum gaps so I can install the sound mat.
5)attached the side pipes, torqued the headers. I will put some hangers at the ball joint as others have done and redo some of the hardware and add gasket sealer later, I know these will be off and on a couple times before I am done and I used the kit provided supplies except the bolts to connect the header to the ball flange, could not find anything in the kit that would work so i got some.
6) i also decided to re-do rear brake line exit from driver compartment, pulled it to the inside instead of outside the front of the foot box and redid all the rear brake bleeding.
7) I also ended up re-doing the rear toe link chassis side heim and bolt. I continued to have play in the toe link on the passenger side and traced it down to a loose heim joint. I went ahead and replaced the bolt with a full length shank bolt and some good aurora rod ends. Huge difference in those compared to the kit supplied parts and makes me feel better about it. Not cheap, but worth it. I did both passenger and driver side although the passenger side did not have the same issue as the driver side did.
getting ready for starting, I will get some gas this week!
Was hoping to do first start this weekend, but I could not get the pump to pump. I was able to suck fuel thru to the pump using my lips...., but the pump would not pump. I did not dis-assemble, just ordered a new pump that will get here next week. A little baffled, only thought that comes to my mind is it sitting for a year and the diaphragms wont seal now. I continued on other items.
Started my interior insulation, but I ran out so, on order...Finished the Passenger foot box, started the driver foot box and mostly done with the trunk.
Made my clutch stop, although not sure if it is important or how to set it up to prevent the throw out bearing from over travel as I can not measure it when installed.
Used a piece of square tube, welded a nut on back side the welded it to the foot box 3/4 tube. Added a rubber end and second nut to lock it after adjusting. Will post on the forum for some input
You don't have in and out reversed on the pump do ya'? I ask because I've been there
Thanks, I did check that early on even thought it came 1/2 plumbed from BPE. I also received an Edelbrock pump today, put it right back in the box and submitted a return, the threads were @#$! and the casting looks like it came from a 3rd world country just now learning to make things, not what I expected for a "Made In USA" label.
Lance. I had the exact same thing happen to me when I bought a new Holley mechanical pump. It looked like it was made in Pakistan...in a mud hut! I sent it back to Summit and got a Carter. The offer still stands if you want my new Carter pump. If you like it, just keep it and get me a replacement.
Allyn
Are you certain that the engine was set up for mechanical vs. electric fuel pump? I see the mechanical fuel pump in previous pictures, but how do you test to see if a eccentric was installed on the camshaft? BPE starts all engines (right?), but not necessary using the delivered fuel delivery system.
There is rub marks on the lever arm and although I am not completely familiar with these, there does appear to be a disk like item that has marks similar to the pump lever that go around it.
hope the Video Link works, but got a running beast today. Big thanks to Rebostar for coming over and helping, he knows his way around these engines way more than me! Had a few issues, some simple water leaks, a bit af questioning about the choke operation, but in the end it seemed to be working OK. Tested the temperature of the fan and thermostat, all worked as expected. Oil pressure and water temperature looked OK.
I wanted to relay my findings on the fuel pump that did not work, got curious and tore it apart and I found that 1 of the suction side diaphragms did not seem to have enough tension to seat, way different than the other one of the pair, so that was my failure analysis...
Issues that will need to address
1) Tach is wonky. Seems to work ok at idle, although I did break out another RPM measuring device and the dash seemed to be about 100-200 high at 900 on my other instrument reading, but was really wonky was revving the motor, it would jump all over the place, up over 5K for a maybe 2-3K Rev, a lot of noise there.
2) The volt meter in the dash was reading 12 volts and my voltmeter on the battery was reading 14.5 with the motor idling. I do have a low volt indicator light in the dash, not sure if that could be impacting the volt meter since it is located at the supply to the volt meter
3) Bottom pulley looked like the wheel of a clown car, so we checked run out, then pulled the pulley and checked the run out on the harmonic balancer, which was good, so will need to get some different bolts and remove the plastic piece that is used to center the pulley, it really does not work well to center the pulley.
4) First Stab at the clutch stop was not enough throw, so I removed my stop to shift the transmission so I could roll the car forward and back, will have to dial that in.
If anyone has had similar issues with solutions, please post. I will contact Speed Hut In the next week or 2. Got the body out of its secure storage location so I can start that.
Next Up alignment, lock down the steering wheel, but in the belts and drive it!
Lance
Was great seeing your car again. I hope mine has as few "initial start" issues as you did. Lots of good work done to only have a few issues, none of which were attrutable to your work. A stuck choke, a wonky Tach, and the crank pully improperly installed by Blueprint. I'll be a happy camper if I have a similar 1st run. Also great to meet your son and your freinds.
Slow progress lately, but progress any way! Working on interior insulation, Dead Pedal and details from first start.
1) Insulation work-Hard part is done, finished the trunk, rear wall and driver and passenger foot boxes. A bit more tedious than anticipated. Will finish the main floor and tunnel after seat install. Note to self, when making a template make sure you don't make a mirror image-it wont stick! I used carpet pieces for some of my templates and that worked great.
Driver foot box with dead Pedal.JPGPassenger side.JPGRear Wall.JPGTrunck.JPG
2)Clutch adjustment-Well all great intentions and plans meet reality. I got lucky and ended up with a non-adjustable clutch stop, had to use the full stroke and remove my rubber bumper to get enough throw on the clutch, but it is about perfect so hope it does not change later.
3)Wonky tachometer-Speed hut sent me a filter that I just wired in. Will be testing later today.
4) Volt meter test-It appears that the volt meter is reading accurately at just above 12 volts at dash power when the alternator and battery is 14.5. I believe the "low Voltage" indicator light sets voltage due to the circuit. I do not think I need to run another separate wire to get the full voltage-but maybe if I take the dash back off I will look at that to separate out the feed to the indicator and the dash power supply. As is everything works so why mess with it.
5) front Pulley-going to run with it, looks much better after we messed with it so I will not concern myself.
6) Installed the dead pedal, did a little mod to Breeze item-drilled some holes to attempt to match the pedals, looks good and feels correct, changed location a couple times to get it correct.
I did reposition the car in my garage to give better access for alignment, so will start that next week.
I have a bit of a conundrum for seats, I asked the question before about time to drill and was recommended to wait for body positioning, but I have a lot of leg room and can not get a solid seat positioning with out mounting. Wanted that for some good pedal evaluation when I go cart. Since I am using sliders, I decided to use the measurements from the F5 installation guide and will be pre-mounting the seats before go-cart.
completed the alignment this last week. Went OK, except my dyslectic toe reading for the front, had to redo that one! I finished up in a hurry and had to run somewhere. The next day I was looking at the front end, something was not right...put the toe plates back on and said what was I thinking? Re-adjust and check camber and all was good. Front end took some time, but only setting up the caster and keeping camber in in a happy place, also the toe is not exactly where I wanted, seems 1 turn on the tie rod makes a big change, so a little extra toe instead a a little less for hopefully better stability. Hardest part is the rear toe-Trying to ensure there is no side thrust and getting both tires centered.
I use a combination of string, lasers, toe plates and angle measuring device. for my turn plate, a couple floor tiles with some grease between them and my angles marked on the floor. A little ghetto, but works fine.
Also, before the alignment I was able to set ride height and then adjust corner weight. I think I may like a bit more rear weight, and I only had about 1/2 driver simulated weight in the seat (about 85 pounds).
Next up finish insulation and evaluating seat mounting, I just can not do a proper test drive until I feel good about not sliding around in the seat.
Hey Lance
Where did you score those scales? Are they yours? If so can I borrow them in a few months?Thanks for stopping by on Tuesday, enjoyed the chat.
Allyn
Numbers look good but 2,200 pounds for the go cart alone is kinda' chubby!
You can use them, no problem.
Its just a, baby no diet yet. Not much more to go on, so Will weight again at adult hood!
Went and dropped the body on for the first time, couple areas of concern but still have some manipulating to do with forum information before I cry UNCLE. I needed body position for my seat mount. Got some great info from Dave about lining up the sliders, best not to use the FF slider measurements for the standard seat, they will leave you out of bounds on the outside of the seat. Not sure, maybe they were meant for the Kirkey seats. I did drill one set of holes in my seat bottum per the FF measurements, then went to see how it sat in the car and it was to far to the outside. Used Dave's measurements and swapped the seat to the passenger side and looks better, will post some pictures after I drill into the floor.
As seems to be recent, hood drops in, some gaps look over sized with out trimming.
Install the sliders so that they're parallel to the trans tunnel and set the seats so that they are "skewed" on the sliders and point straight ahead. This way the seats will remain equidistant from the tunnel as they move forward and back...if you install the sliders parallel to the chassis tubes as you move the seat forward the front inside corner will hit the tunnel.
