Results 1 to 6 of 6
Thread: Hydroboost Brakes
    May 2024
    Hydroboost Brakes
    Hi, All. I’m in the planning stages of a ‘35 build and was wondering if anyone has done a Hydroboost brake application. I’m purchasing a Blueprint LS package which includes a hydraulic power steering pump. It seems a logical approach to use this power source for a Hydroboost application since there is no hydraulic PS option for this package. Any thoughts, or better yet, has anyone else taken this approach?
    Pertinent options are:
    Wilwood brake option
    F5 electric PS
    Also, I have worked with Blueprint and they have a PS delete option specifically for this truck, so no big deal if the Hydroboost isn’t a good approach.
    Mark
    If you're going to the trouble of moving the master cylinder out onto the firewall and boosting the brakes, why not vacuum power? That's what I did on my 35 truck build. Pictures and description in my build thread. Nothing additional other than tapping engine vacuum. I wouldn't run hydraulic for the brakes alone.
    Senior Member mkassab's Avatar
    Johnson City, TN
    I agree with Paul... doesn't seem practical.... i.e., running a PS pump just for brakes.
    Mark
    '35 Truck
    Build Thread: https://thefactoryfiveforum.com/show...35-Truck-Build
    Brevard, NC
    Aug 2019
    Arlington, WA
    Be aware that the chassis gets pretty narrow at the front. I too have the LS and went with the Holley front drive, it came with a PS pump that would in no way have fit. No problem for me as I got the electric PS from FFR with my kit. A couple of things I liked about the Holley drive was that it comes with a spot to hook up your steam vent, and the housing has provisions for the heater hoses to either come straight out or go down which is what I did as coming straight can hit the round frame tube that the upper control arm mounts to.
    Gary
    FFR Gen 2 35 truck, Barrett Jackson edition # 4, chassis # 81, 525HP LS3 & 4L75E, 8.8" 3 link.
    Prescott, AZ
    If you want the hydroboost, consider an electric pump. There are systems out there and, in this application, going electric makes sense for both.
    May 2024
    I haven’t even considered this option. I will take a look. I’m not even convinced I need boosted brakes, it’s just one of the 1000 things bouncing around in my head. Thanks for the input!
