Thanks Thanks:  31
Likes Likes:  210
Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 601 to 640 of 645
Thread: What did you do on your roadster today?
  1. #601
    Folsom, CA
    Todd
  2. Likes nucjd19 liked this post
  3. #602
    RJD's Avatar
    Northern Virginia
    Went for a 90 mile fall cruise.
    Came across a like-minded cruiser with car trouble, so pulled over and hung out until his tow arrived. Lost count of all the honks and thumbs-ups we received.
  4. #603
    Woodstock ,Illinois
    Eliminated the old donor multi-function switch with a couple new switches that are easier to get to.
  5. #604
    Nov 2021
    Pittsburgh, PA
    I'm looking to do this exact thing for my roadster, the stock FFR headlights are not good. But when I look for the Hella Vision Plus 7" Conversion Headlights on say Summit Racing, there are multiple PNs that I cannot tell the difference between.
    Is this one the correct one?
    https://www.summitracing.com/parts/hla-002395071
    Don
    Quote Originally Posted by RJD View Post
    I upgraded to LED headlights today.
    The Hella Vision Plus 7" H4 Conversion Headlight is a little flatter than the original sealed bulb and comes with a halogen bulb.
    Attachment 154940
    I replaced the Hella halogen bulbs with LED bulbs that I saw Fman use in his build. The bulbs have built-in fans and drivers. (Thanks Fman)
    Attachment 154941
    The LED bulbs are the same size as the halogen bulbs that came with the Hellas.
    Attachment 154942
    Here's a profile with the flatter Hellas installed.
    Attachment 155735
    While the halogens weren't bad, the LEDs were brighter. Both the halogens and LEDs were superior to the sealed bulbs that came with the F5 kit. Everything was a direct fit with no modifications needed. Took less than an hour to do.
    Attachment 154943
  6. #605
    Senior Member ggunter's Avatar
    Jun 2020
    Rising Sun , Md.
    Did nothing but wipe the dust off and taking a ride today in southern Pa. Other than a few issues early on, that's all I have to do is wipe off the dust and ride. It's been done for three years and has 12k miles on it. Best, most fun vehicle I've ever owned. I'm glad I ordered the fun package.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
  7. #606
    Senior Member Jim Wehr's Avatar
    Hamilton, VA
    Consider calling Mark Reynolds at Breeze (a Forum sponsor). I just installed his LED kit. Awesome and great customer service because he is dedicated to these cars. Might be on sale now?
  8. Likes John4337, toadster liked this post
  9. #607
    Springboro, OH
    Drove it 2 hours to the London Cobra Show in 94 degrees heat.
    Roy
  10. #608
    Seat slider came early so started to put the original seats out. Had "Honey Do's" so will finish tomorrow.
    Kevin
    MKIV #8234
  11. #609
    Senior Member Rebostar's Avatar
    Jan 2024
    I finished installing the carbon fiber glove box cover and installed all the Classic Instruments "Moal Bomber Gauges" and all the switches.
  12. #610
    Dec 2023
    Eddyville, KY
    Same!
    Jim
  13. #611
    FFR MKIII builder/owner
    Nov 2012
    Danbury Ct.
    Changed my 16 year old hood support struts, they were getting weak to the point of not holding it up at times depending on the temperature.
  14. #612
    Dec 2021
    Flower Mound TX
    Did some more test & tune driving around the neighborhood.
  15. #613
    Test fit. Looks good for room. its sitting on the old sliders with a beach towel folded under it so its sitting a little high..
    Only negative is shoulder belt alignment. Would like to have the come straight out from the rear bulkhead & through the seat.
    Kevin
    MKIV #8234
  16. #614
    Sep 2019
    Bothell, WA
    Thanks for the picture with the seat Kevin. Took my gelcoat car to a local car show today here in Redmond,
  17. #615
    Quote Originally Posted by D Stand View Post
    No problem a number of the guys here helped me find these seats. Nice to be able to pass on the info. What's really good about them is they fit the cockpit with no work. Also they are fully upholstered front & rear.
    Kevin
    MKIV #8234
  18. #616
    Folsom, CA
    I picked mine up (Friday) and drove it to C&C on saturday
    Todd
  19. #617
    Member MaxVmo's Avatar
    May 2023
    Installed my power steering mod brace and cussed out the wiring on my panel.
  20. #618
    Seat Done will start on the other side.
    Kevin
    MKIV #8234
  21. #619
    Dec 2021
    Flower Mound TX
    Got it weighed for registration.
  22. #620
    Jul 2022
    Ventura County, CA
    Replaced leaking TKO600 output seal, added a Forte's billet speedo block off, re-filled with Penzoil Synchromesh.
    Fingers crossed.
    Mk4 Roadster #7945, Ford Racing 427W, Quick Fuel 850, TKO600, 3 Link, One of Jeff Miller's last paint jobs. California SB100 completed June 2024
  23. #621
    What was the weight
    Kevin
    MKIV #8234
  24. #622
    Dec 2021
    Flower Mound TX
    What was the weight
    I'm trying to figure that out! It says the gross weight was 2660 but when I look closer the certificate shows 2480 on the rear axle and 180 on the front axle. I had a friend of mine take it there since he has a nice truck and enclosed car hauler and I'm pretty sure he was standing on the front scale. He happens to weigh about 180 lol
    So I'm saying 2480lbs with half a tank of gas.
  25. Thanks BEAR-AvHistory thanked for this post
  26. #623
    Woodstock ,Illinois
    That's what I'm running... very nice!
  27. #624
    Jul 2022
    Ventura County, CA
    Installed rear wheel well filler panels from Whitby.
    It looks much better, "finished" instead of big gaps.Whitby rear filler panel pass.jpg
  28. #625
    Member cdurbin328's Avatar
    Feb 2023
    NW Florida
    I designed and 3D printed an emblem for my Gen 2 Intake Cover. Turned out pretty decent I think.
    428704588_10228853341832793_4500345249989239274_n.jpg[ATTACH=CONFIG]201238
    MKIV Roadster Complete Kit
    2016 Coyote | MT82 6-SPD | 3-Link 3:55 Rear
    Delivered 7/3/2023 Completed 11/13/2023
  29. Likes rustyrim, GrooveM liked this post
  30. #626
    Copperhill, TN
    Oil Pan Replacement
    Right after I got on the road over 10 years ago, I kissed an unpainted speed bump with my oil drain plug. It didn't cause any problems, so I let it ride. Last year after my annual oil change, it started weeping. This year, the weep turned into a stream, so off with the old, in with the new. I used a Fel-Pro one piece gasket. Those plastic alignment pins are genius.
    At least there were no shiny things in the bottom of the pan.
    The drip
    Looks clean
    Damage close up
    Old and New
    Gasket and Pins
    Alignment Pins
    All good
  31. Thanks Joel Hauser thanked for this post
  32. #627
    Jan 2024
    Finished the rolling chassis!!!! YAY!!
  33. #628
    Sep 2019
    Bothell, WA
    Removed my failed sniper pressure regulator and installed an adjustable external one. Also replaced the oil temperature gauge with a fuel pressure gauge, so now I can monitor it in the future..
  34. #629
    May 2023
    About to install a driveshaft safety loop.
  35. #630
    Dec 2021
    Flower Mound TX
    Now that we're legal we put some more miles on it today although somewhat limited by the temperature here in Texas in August. But, a good chance to test the cooling system and happy to report it never got above 190. Oil pressure was always good, tach spot on, GPS speedo spot on, and the alternator is doing it's thing. Steering is very tight, takes a little getting used to compared to my 100K Tacoma, but it tracks nice and true going down the road.
    We've been doing quite a bit of driving around the neighborhood and today was the first time out legal with plates. Barely a half mile from the house we run into a policeman coming out of a side street. He just sat there watching us go by and then went the other way. Ha!
  36. #631
    Jan 2020
    Twin Cities, MN
    Yeah my 100k Taco wiggles a bit and also I warp rotors like crazy. But I have done nothing but abuse it and with regular maint. so far so good.
    As for what I did today on the Roadster - Married the Engine and Transmission, made some transmission spacers, broke a couple of banjo parts, fixed a zerk fitting, powder coated 1 of the headlight trim rings, powder coated the dead pedal, and fixed the sound deadening/heat shielding in the drivers footbox. Pretty good day on the Roadster.
    Mark IV, 302 Based 347, TKx, Four link w/3.55, coil overs, PS, 4wheel Willwood. Dark Blue w Black/Red stripes, Saddle Interior, Blacked out chrome.
    Kit Ordered 4/18/2022
    Kit Delivered 2/20/2023
  37. Likes Mike.Bray liked this post
  38. #632
    Senior Member john42's Avatar
    Aug 2020
    Hollis, NH
    Well.... yesterday I raced the piss out of it at Palmer:
    So today, I'm doing an oil change, brake bleed and all around check everything.
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
  39. #633
    Feb 2022
    Flower Mound, TX
    This morning we got the first start done. A great feeling.
    https://www.youtube.com/shorts/1GEP8Us2VCA
    https://www.youtube.com/shorts/5xKEotfrAAs
  40. #634
    Sep 2011
    Minneapolis, MN
    Saturday, took the car to its first car show in gel coat ... didn't matter, all eyes on the roadster when I drove in and plenty of folks ready to chat once I got out. The kind of friendly neighborhood thing where plenty of non-owners want to talk ... and lean on the windshield, and try to open the doors. No problem, just a little education involved. And lots of good stories to swap. Met my son there, along with his good friend Shelby ... yep, her Dad's a car guy, and had to take in the show via Facetime.
    Handed my son the keys and let him get behind the wheel for the first time. He did fine and had a blast. I think his car has a dent in the floor from him operating his own clutch right after driving the roadster.
    Sunday, was driving on the freeway and heard / felt my first detonation through all of the 15+ Sniper tune revisions I've done. Not my best moment. Checked the handheld ... O2 sensor says 35.6 AFR, clearly I have a bad O2 sensor. So detonation makes sense, air / fuel mix was likely far richer than the AFR table called for, and therefore burning faster.
    Ordered a new O2 Bosch 17025 sensor from EFI System Pro. I likely heat-shocked the sensor with moisture in the pipe during warmup (NOT from orientation of the bung placement), or from running rich during initial tuning. Just to be safe, ordered an HBX-1 Bung Extender from Innovate Motorsports to pull the sensor back from the direct exhaust stream.
    Back up and running next week, and happy to run open loop until then with a fairly refined fuel table already in place.
  41. #635
    Dec 2021
    Flagstaff, AZ
    Tidied up the wiring behind the dash and cut the shifter hole in the new transmission tunnel cover from FFMetals.
    Getting to the look I wanted!
  42. Likes John4337 liked this post
  43. #636
    Senior Member JMD's Avatar
    Mar 2024
    Kansas City, MO
    Installed a power steering cooler. Used 1 3/4" angle aluminum to span the space between the steering rack mounting tabs and mounted a 12" Derale fluid cooler to it. It's a great location as it's tucked up so not to be in harms way from road debris but also behind the radiator fan so it gets a lot of airflow.
    Before:
    After:
    Build thread: https://thefactoryfiveforum.com/show...809#post556809
    MKIV received 5/15/24
    Blueprint 302 tuned by Mike Forte, TKX midshift, IRS, PS, Wilwoods
  44. #637
    Apr 2023
    Painted the brackets on my custom hydraulic clutch master cylinder actuator. SN95 pedal box with Wilwood master cylinder. I will write a post on the whole setup soon. IMG_3598.jpg
  45. #638
    Senior Member flyboyjy's Avatar
    Dec 2020
    Centennial, CO
    So my oldest son and I took it to a car show in all it's gel coat and parting lines glory. We are part of the Mile High Cobra Club and went in as a small group. Despite the upper 90 degree temperatures we had a good time. Lots of questions about the car. Only bad thing is the windshield in the upper drivers side cracked. Just sitting there. The start of the crack does not align with any screws or any defects I can visibly see. So I will order a new one from FFR and check the mounting frame to make sure there's no sharp spots or defects that will cause another one to crack.
  46. #639
    Jun 2020
    Rising Sun , Md.
    Drove it!!!
    Fun Package
  47. Likes John4337 liked this post
  48. #640
    Senior Member JJK's Avatar
    Jul 2022
    DFW Texas
    out of curiosity, I downloaded a sound level app for the phone. sitting in the backyard it registered about 40db, which is in line with what a neighborhood would typically be. I recognize it is not a calibrated instrument, but it appears to report reasonable sound levels. Anyway, the idle sound level inside the car fluctuated between 69-72 db, which is a bit lower than GasN indicates for their touring pipes (which is what I have). I also have thick sound deadening butyl all over everything. Now I want to use the same app in other cars to see the relative difference, as that will be more meaningful than the absolute (uncalibrated) reading.
