Thanks Thanks:  30
Likes Likes:  196
Page 16 of 16 FirstFirst ... 6141516
Results 601 to 623 of 623
Thread: What did you do on your roadster today?
  1. #601
    Folsom, CA
    Todd
  2. Likes nucjd19 liked this post
  3. #602
    RJD's Avatar
    Northern Virginia
    Went for a 90 mile fall cruise.
    Came across a like-minded cruiser with car trouble, so pulled over and hung out until his tow arrived. Lost count of all the honks and thumbs-ups we received.
  4. #603
    Woodstock ,Illinois
    Eliminated the old donor multi-function switch with a couple new switches that are easier to get to.
  5. #604
    Nov 2021
    Pittsburgh, PA
    I'm looking to do this exact thing for my roadster, the stock FFR headlights are not good. But when I look for the Hella Vision Plus 7" Conversion Headlights on say Summit Racing, there are multiple PNs that I cannot tell the difference between.
    Is this one the correct one?
    https://www.summitracing.com/parts/hla-002395071
    Don
    Quote Originally Posted by RJD View Post
    I upgraded to LED headlights today.
    The Hella Vision Plus 7" H4 Conversion Headlight is a little flatter than the original sealed bulb and comes with a halogen bulb.
    Attachment 154940
    I replaced the Hella halogen bulbs with LED bulbs that I saw Fman use in his build. The bulbs have built-in fans and drivers. (Thanks Fman)
    Attachment 154941
    The LED bulbs are the same size as the halogen bulbs that came with the Hellas.
    Attachment 154942
    Here's a profile with the flatter Hellas installed.
    Attachment 155735
    While the halogens weren't bad, the LEDs were brighter. Both the halogens and LEDs were superior to the sealed bulbs that came with the F5 kit. Everything was a direct fit with no modifications needed. Took less than an hour to do.
    Attachment 154943
  6. #605
    Senior Member ggunter's Avatar
    Jun 2020
    Rising Sun , Md.
    Did nothing but wipe the dust off and taking a ride today in southern Pa. Other than a few issues early on, that's all I have to do is wipe off the dust and ride. It's been done for three years and has 12k miles on it. Best, most fun vehicle I've ever owned. I'm glad I ordered the fun package.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
  7. #606
    Senior Member Jim Wehr's Avatar
    Hamilton, VA
    Consider calling Mark Reynolds at Breeze (a Forum sponsor). I just installed his LED kit. Awesome and great customer service because he is dedicated to these cars. Might be on sale now?
  8. Likes John4337, toadster liked this post
  9. #607
    Springboro, OH
    Drove it 2 hours to the London Cobra Show in 94 degrees heat.
    Roy
  10. #608
    Seat slider came early so started to put the original seats out. Had "Honey Do's" so will finish tomorrow.
    Kevin
    MKIV #8234
  11. #609
    Senior Member Rebostar's Avatar
    Jan 2024
    I finished installing the carbon fiber glove box cover and installed all the Classic Instruments "Moal Bomber Gauges" and all the switches.
  12. #610
    Dec 2023
    Eddyville, KY
    Same!
    Jim
  13. #611
    FFR MKIII builder/owner
    Nov 2012
    Danbury Ct.
    Changed my 16 year old hood support struts, they were getting weak to the point of not holding it up at times depending on the temperature.
  14. #612
    Dec 2021
    Flower Mound TX
    Did some more test & tune driving around the neighborhood.
  15. #613
    Test fit. Looks good for room. its sitting on the old sliders with a beach towel folded under it so its sitting a little high..
    Only negative is shoulder belt alignment. Would like to have the come straight out from the rear bulkhead & through the seat.
    Kevin
    MKIV #8234
  16. #614
    Sep 2019
    Bothell, WA
    Thanks for the picture with the seat Kevin. Took my gelcoat car to a local car show today here in Redmond,
  17. #615
    Quote Originally Posted by D Stand View Post
    No problem a number of the guys here helped me find these seats. Nice to be able to pass on the info. What's really good about them is they fit the cockpit with no work. Also they are fully upholstered front & rear.
    Kevin
    MKIV #8234
  18. #616
    Folsom, CA
    I picked mine up (Friday) and drove it to C&C on saturday
    Todd
  19. #617
    May 2023
    Installed my power steering mod brace and cussed out the wiring on my panel.
  20. #618
    Seat Done will start on the other side.
    Kevin
    MKIV #8234
  21. #619
    Dec 2021
    Flower Mound TX
    Got it weighed for registration.
  22. #620
    Jul 2022
    Replaced leaking TKO600 output seal, added a Forte's billet speedo block off, re-filled with Penzoil Synchromesh.
    Fingers crossed.
    Mk4 Roadster #7945, Ford Racing 427W, Quick Fuel 850, TKO600, 3 Link, One of Jeff Miller's last paint jobs.
  23. #621
    What was the weight
    Kevin
    MKIV #8234
  24. #622
    Dec 2021
    Flower Mound TX
    What was the weight
    I'm trying to figure that out! It says the gross weight was 2660 but when I look closer the certificate shows 2480 on the rear axle and 180 on the front axle. I had a friend of mine take it there since he has a nice truck and enclosed car hauler and I'm pretty sure he was standing on the front scale. He happens to weigh about 180 lol
    So I'm saying 2480lbs with half a tank of gas.
  25. Thanks BEAR-AvHistory thanked for this post
  26. #623
    Woodstock ,Illinois
    That's what I'm running... very nice!
