Likes Likes:  6
Results 1 to 15 of 15
Thread: Show me your car show board
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Hey all, I'm taking the roadster to her first car show in a month and I wanted to make a show board for the show. I'm thinking of using this place, but open to other suggestions if someone has had great success with another vendor:
    https://showcarsign.com/
    I'd love to see any examples you have of show boards you've made for your car.
    I used Adobe Illustrator, made my own converted it to a PDF and went to Staples to have it printed on hard board
  3. Likes FF33rod, JimLev liked this post
    Did mine myself as well with Microsoft Publisher. Not as fancy as the much more artistic vendor options. But $39.95 to print on foam board at FedEx Kinkos.
  5. Likes wrp, JimLev liked this post
  6. #4
    Jun 2024
    Knoxville, TN
    I love the KISS approach for boards. Ive made a few for myself over the years (but lost the clear shots when my last computer died). This was, and still is, what I use as inspiration for the ones I build for my rides. I would be happy to lend a hand if you need some help with the design side of things.
  7. Likes wrp liked this post
  8. #5
    Big advantage is if you changes something or add to something it is easier to get it changed.
  9. Thanks edwardb thanked for this post
    Likes JimLev liked this post
  10. #6
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Patriot Graphics, Memphis, TN
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
  11. #7
    Jul 2021
    Tonganoxie, KS
    Hildebrand wheels?
  12. #8
    Hildebrand wheels?
    I wasn't going to bring it up but since you did
    I think those go along with "Wildwood breaks", "Castor" and "tow in", "Superperformance", "FF5"...
    Jul 2021
    Tonganoxie, KS
    LOL. You forgot "Elderbrock".
  14. #10
    Apr 2024
    Been making Custom Show Boards for 20 years - we do aluminum & plexiglass backing. Powder coated stands add-ons, and built on stands
    http://bestshowsigns.com
    Quick turnaround
  15. #11
    Jun 2018
    North Vancouver, BC, Canada
    Another home brew example...
    Gen 1 '33 Hot Rod #1104
  16. #12
    Senior Member DavidW's Avatar
    Stevensville, MD
    Definitely make one yourself so it can be edited if needed. I have to change a couple things, I just installed a Holley Sniper 2 EFI, and some other things.
  17. #13
    Hildebrand wheels?
    Factory Five 18" Halibrand style replica wheels. https://www.factoryfiveparts.com/158...eplica-wheels/
  18. #14
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I thought I'd post a quick update to the thread. I worked with Gary at Showcarsigns.com to make a show board for the roadster, and it turned out great. Gary was very friendly and easy to work with, and we went through several versions of the board before settling on the final design. He had it printed and shipped within a day after finalizing the design. It came printed on foam board with a nice plastic trim and an easel leg so it stands on its own.
  19. #15
    Jul 2021
    Tonganoxie, KS
    I was being snarky at 'Hildebrand' vs 'Halibrand'.
