Did you sand the hardtop opening or grind the glass? Mine won't go in, and i'm not about to try to force it.
I had to do a lot of sanding on the hardtop opening to get the glass to fit in. Most of it was on the A pillars.
When finished I had between a 1/16” to 1/8” gap everywhere.
I had to do the same for the back too.
Sanded the hard top... MAKE SURE that you're fitting the glass with the hard top mounted on the body. Because the hard top twists when you mount it (actually it's more like it's twisted when it's not mounted), the fit of the glass is different...
Gen 1 '33 Hot Rod #1104
