Results 1 to 4 of 4
Thread: Front WIndshield fitment
    Sep 2022
    Huntington, IN
    Did you sand the hardtop opening or grind the glass? Mine won't go in, and i'm not about to try to force it.
    Placitas, NM
    I had to do a lot of sanding on the hardtop opening to get the glass to fit in. Most of it was on the A pillars.
    When finished I had between a 1/16” to 1/8” gap everywhere.
    I had to do the same for the back too.
    Jun 2018
    North Vancouver, BC, Canada
    Sanded the hard top... MAKE SURE that you're fitting the glass with the hard top mounted on the body. Because the hard top twists when you mount it (actually it's more like it's twisted when it's not mounted), the fit of the glass is different...
    Gen 1 '33 Hot Rod #1104
  4. Thanks JimLev thanked for this post
    Likes Just 1 More liked this post
    Sep 2022
    Huntington, IN
    No doubt it's twisted. After the rear is bolted tight, Mine needs some encouragement to sit right on the front.
