Results 1 to 12 of 12
Thread: inner door panels
    Sep 2022
    Huntington, IN
    inner door panels
    Who's come up with a way to attach the door panels without screw heads showing?
    Jun 2018
    North Vancouver, BC, Canada
    I didn't use the FFR panels, I built my own using Hagan's panels, clips, etc.... They have some useful videos too.
    https://www.haganauto.com/category_s/167.htm
    There's no reason that with a bit of work you couldn't use their clips on the FFR panels I imagine.
    https://www.haganauto.com/product_p/dobptkf.htm
    Gen 1 '33 Hot Rod #1104
  3. Thanks Just 1 More thanked for this post
    Likes Just 1 More liked this post
    Mar 2021
    SE WI Kettle Moraine
    You might consider plastic panel push-rivets. Lots of head sizes and surface texture but black and a few whites are all I find.
    jim
    Dublin, OH
    3M dual lock tape.
    Sep 2022
    Huntington, IN
    Looks to me that they made an inner panel with the clips then glued that panel to the outer panel.. gives me some ideas. Thank you
    Sep 2015
    Hamersville, Ohio
    Velcro?
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
    May 2018
    Pinckney, MI
    I put rivnuts into the door in 4 places and then used button head screws to attach the panels. I've uses button head all over, so it fit right in. Has worked just fine and is subtle as well.
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
    Sep 2022
    Huntington, IN
    I ended up cutting my own out of PVC foam board and attaching with screws for now. Not sure which way i'll go once I get them covered.
  10. #9
    Oct 2022
    I used #6 rivnuts with black oxide finished stainless button head screws and black oxide finish washers.
  11. #10
    What a lot of people making suggestions probably don't realize is the door cards provided for the truck are heavy. They have a sheet aluminum core and are quite large. Plus a nice pouch to put stuff in. That is if they are the same as the ones I received. Something substantial is required. I've always used hidden fasteners on my builds. But resorted to black oxide interior trim screws on my truck build. They blend in OK and not a big deal.
  12. #11
    Oct 2022
    This thread is in relation to the 33 Hot Rod but the door panels are also backed by thick aluminum sheet. The 33 inner door is not flat which requires the door panels to be formed to fit which is no small task. IMHO, screws and rivnuts are the most secure way of holding them on and taking up the last little bit gap between the door and door panels.
    The other alternative is to make all new door panels that have a more playable backing.
  13. #12
    Quote Originally Posted by Dgc333 View Post
    Oops, Missed this was for the Hot Rod vs. the Truck. Good to confirm the Hot Rod door cards are similar to the Truck, so my advice wasn't completely ill-advised.
