Results 1 to 2 of 2
Thread: Unfinished Cobra Daytona GEN III Coupe Project - Vero Beach, FL - $60K -SOLD
    May 2021
    Two car projects, one garage, something has to go.
    Factory Five Daytona Complete Kit – Not Donor Parts.
    Independent Rear Suspension, Shelby GT350 Diff 3.73 gears and Torsen LSD, Wilwood Brake Upgrade, Wilwood Electronic Parking Brake, Koni Double Adjustable Shock Absorbers, Howe Racing 22023S Upper Ball Joints, Moog 2150RL Tie Rod Ends, Front & Rear Swaybars, Halibrand Replica 18” Wheels, Heater & Air-Con kit, Vintage Gauges with GPS Speedo, Kirkey Racing Seats, Carpet Kit, Insulation Kit, Windshield Wiper Kit.
    Factory Five A.T. Gen 3 Coyote w/Control Pack
    Quicktime Steel Bellhousing, Tremec T56 6-speed Transmission, Hydraulic Throwout Bearing, Complete Boig Quiet Pipes Exhaust System (plus Factory Five stainless-steel exhaust system for noisemaking), Moroso Aluminum Coolant Tank, Aeromotive Fuel Pressure Regulator.
    Miscellaneous Stuff You’ll Want To Have
    New Vintage toggle switch panel, Lucas L400 Taillights (Amber, Red, White), Whitby Motorcars Hood Roller Kit, Breeze Fan Shroud, Breeze Big Bore Fuel Tank Vent. Boig Upper & Lower Cool Tubes, Brock Racing Enterprises Outside Mirrors, Tilton 3-in-1 Hydraulic Reservoir, Trickflow Cannister Fuel Filter, Pro-M Fuel Pump Hangar, Eibach 25mm Wheel Spacers, Treadstone 4” MAF Adapter w/Flow Straightener.
    Senior Member Hoschton Hotrod Haus's Avatar
    Sep 2019
    Hoschton, GA
    Quote Originally Posted by herkybird View Post
    Sent you a PM
    2005 MkIII Roadster 4.6 DOHC / T56 ... SOLD
    2020 Gen 3 Type 65 Coupe 5.0 Coyote Gen 2/TKO600 - F5R1000181DC ... SOLD
    2021 MKIV "Street Roadster" BPE 347/TKX - F5R1010085RD ... Finished 6/11/2022
    2022 Gen 3 Type 65 Coupe 5.0 Coyote Gen 3/TKX - F5R1000404DC ... Finished 10/6/2023 ... SOLD
    2021 MKIV Roadster BPE347/TKX F5R1010078RD ... Driver in Gelcoat 1/7/2024
