Likes Likes:  3
Results 1 to 18 of 18
Thread: Traverse City Mark IV Build
    Junior Member Bake813's Avatar
    Dec 2021
    Traverse City, MI
    My first post on my Factory Five Mark IV build. The details of the order are as follows
    Mark IV Complete Kit
    Powder coated Frame with cutouts
    IRS
    Halibrand Tire Package
    Driver and Passenger Rollbars
    Koni Shocks
    Wilwood brakes
    Engine is coming from Mike Forte
    427W
    Sniper EFI
    Tremec 5 speed transmission
    I took delivery on November 4 and over the past three weeks, I have gotten a frame dolly and body buck built and the body separated from the frame. Over the past week, I have been unpacking boxes and taking an inventory of everything.
    Folsom, CA
    welcome! Looks like it's gonna be a sweet setup! and a nice home where it's built!
    Todd
    Grand Rapids, MI
    Another 427 brother! Welcome from Grand Rapids.
    Jim
    Welcome from down here in Lake Orion. Congratulations on your delivery. Nice build and nice setup. Keep us updated.
    Member KayzDad's Avatar
    Jan 2018
    Pentwater MI and Chicago, IL
    I'm looking forward to following your build, as you'll be around six months ahead of me. My kit is to be delivered in April; I'll be building it in Pen****er.
    Dec 2021
    Traverse City, MI
    Additional Photos
    Some additional photos. The plan this week is to finish the inventory and get some panels drilled and sent off to powder coating. Looks like I am missing quite a few items so will probably also work on a game plan of what I can actually work on until I get some additional items
  7. Likes mladen liked this post
    Aug 2019
    Spokane, WA
    Welcome aboard, Bake. Fantastic looking shop for your build. The four-post lift will be handy.
    P.S. some nice eye candy in the background of your last photo.
    Dec 2021
    Traverse City, MI
    First body panels attached
    Over the past several weeks, I have been busy taking inventory and going through every box. I am missing a lot of items (which were noted by Factory Five) so my plan of getting the front and rear ends completed first may have to be modified (no brake or shocks yet to start with). I got the first two panels powder coated and attached yesterday and plan to work on the front end this week. I bought a pneumatic rivet gun and I can't imagine doing all the rivets with a hand held.
  10. #9
    Jun 2020
    Rising Sun , Md.
    Pneumatic riveter is the way to go. That plastic catch piece will have to go in tight areas.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
  11. #10
    Dec 2021
    Traverse City, MI
    Little progress
    I have not made a lot of progress over the Holidays with travel and other commitments but I do have the front suspension and IRS installed although still needs some work due to missing part. For the front end, I still need spindles, brakes, shocks and tie rod ends. For the rear I need the IRS fastener package (for now just held in my some temporary fasteners), brakes and shocks. Over the next week, I will probably start getting as many body panels temporarily installed (with cleco fasteners) and then look at doing wiring, brake and fuel lines. After that, I might be on hold for awhile until I get some backordered parts from Factory Five. I have had very little success in getting a response from Factory Five about potential shipping dates
  12. #11
    Aluminum panels, wiring, brake and fuel lines should keep you busy for awhile! There are other things you can do. Just ask for ideas. Slightly confused though. You say you're missing spindles. But I see them in the picture of your front suspension.
  13. #12
    Dec 2021
    Traverse City, MI
    Should have said front hubs vs. spindles. I would appreciate any thoughts anyone has on next steps once I get get through the noted items.
  14. #13
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Bake813 View Post
    There's a ton you can do with temporarily fitting all of the aluminum panels. You can run brake and fuel lines to a point. Fit the firewall. Prepare the dash. Mount the fuse panel and work on wiring. You could even mount (and remove) the radiator. Mount the gas tank.
    If you're not afraid to skip around in the manual some there is enough to keep you busy for a few weeks.
  15. #14
    Dec 2021
    Traverse City, MI
    Update
    Been traveling quite a bit since Christmas but the good news is I think I have all my parts with the exception of brakes and shocks. I have made some progress and concentrating on the rear of the car with the IRS mostly put together and currently working on the drop trunk. I got it rough fit today but needs some clean-up and to be permanently attached. Hoping to have the rear end pretty much together before I leave town again on the 15th.ff5.jpgff4.jpgff3.jpgff2.jpgFF 1.jpg
  16. #15
    Dec 2021
    Traverse City, MI
    Build Update
    I have finally been home for a few weeks and able to make some progress on the build. I have all the aluminum panels attached that I plan on until I get a running car. Leaving off the upper trunk, right hand rear quarter and transmission tunnel for now so I have access to fuel lines, etc. Also, got the electrical roughed in and some heat shield put in. I am considering heat shield in the trunk (mainly for noise and vibration), has anyone done this? Also, considering doubling up on the heat shield in the footbox area. Thoughts?
    Over the next week, my plan is to work on the dash layout, fabricate a center console for under the dash, finish up fuel and brake lines (I am changing a few things on these again) and start to put together the interior.
    Still waiting for engine and transmission from Mike Forte (hopefully by early April), brakes and shocks (no idea of time frame on these)
    It is staring to really come together and look like a car.
  17. Likes Salty Chief 35 liked this post
  18. #16
    Senior Member M22_COBRA's Avatar
    Aug 2023
    Suttons Bay, MI.
    Say hey from Suttons Bay! I'm just north of you by 20-30mins. I'm getting ready to pull the trigger on my build within the year.
    Coming together nicely. Did you get your powertrain from Forte yet?
  19. #17
    Dec 2021
    Traverse City, MI
    Roadster Update
    It has been awhile since I posted but continue to make progress on the build Just finished off the interior last week and took chassis back to the painter. The body is through the first coat of primer and should go into final paint color (classic blue with white stripes) shortly. The plan is to put everything back together in early April and have it ready for cruising this summer
  20. #18
    Dec 2021
    Traverse City, MI
    Build Complete
    Finished my build in June and got through the State of Michigan VIN and registration process (which was a lot easier than I thought). Have had it out for a couple of drives and have a few minors things to correct but it is pretty much done and looks sharpFInished4.jpgFInished1.jpgFInished2.jpgFInished3.jpg
  21. Likes M22_COBRA liked this post
