Thanks Thanks:  2
Likes Likes:  3
Results 1 to 4 of 4
Thread: AC Hose Ends
    AC Hose Ends
    Anyone have a source for some hose ends that would fit the C5 condenser and accumulator like these? On the GTM that I'm working on, I can't mount the accumulator in its normal position, and the AC condenser has some "other" stuff going on around it to where I can't get the FFR provided hoses to fit.....so wondering if anyone sells just the hose ends so I can make hoses from scratch?
    Shane Vacek
    www.vraptorspeedworks.com
    Have you tried contacting coldhose.com?
  3. Likes VRaptor SpeedWorks, LLC liked this post
    Senior Member beeman's Avatar
    Indiana
    I built a c5 road course car and pulled out the entire ac system. I then decided to put ac back in for the drives to and from the track. I went with an aftermarket lightweight unit under the dash with standard fittings. I looked everywhere for adapters from the gm c5 stuff to standard fittings and eventually gave up, didn't keep a single c5 ac part. If you are wanting to keep the C5 stuff, I'd find a tig professional to tig the aluminum fittings the way you want.
    GTM #304 LPE 525hp LS3
  5. Likes VRaptor SpeedWorks, LLC liked this post
  6. #4
    Quote Originally Posted by BobbyB View Post
    Thanks!! They came thru!
    https://coldhose.com/collections/con...43853302628607
    https://coldhose.com/collections/acc...43853699776767
    Shane Vacek
  7. Thanks rolfer thanked for this post
    Likes rolfer liked this post
