Results 1 to 8 of 8
Thread: Breeze Big Bore Vent
    Mar 2021
    Ohio
    I am curious if the Breeze Big Bore Vent is worth it or does the stock one work just fine? I wasn't sure if people were ordering one since they saw it in someone else's build thread or if it is an actual problem with filling the tank.
    Dublin, OH
    I've had no issues w/ the factory provided vent.
    I would recommend getting an OEM filler neck gasket however. The FF provide one is known to split/leak over time.
    I’ve used the OEM valve on every car I have built. Some have had the cut & spliced Mustang fill tube and others have the FFR tube and hose. None of them have a problem with filling.
    Mar 2021
    Ohio
    Sounds good, looks like OEM it is! Thanks for the heads up on the gasket, I did already do that one based on reading build threads.
    Aug 2023
    Braselton, GA
    Is the Ford fuel tank filler neck seal grommet F4ZZ-9072-DA?
    Mar 2021
    Ohio
    Yeah, that is the correct one.
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    I considered using the Breeze big bore vent when I was building my MK4. When I spoke with Mark he told me that the current FFR vent was bigger than previous versions and that I probably didn't need to upgrade it. As usual, he was spot on. Mark's knowledge, honesty and professionalism is a rare combination in this day and age.
    Mar 2021
    Ohio
    Quote Originally Posted by Lidodrip View Post
    It is truly a rare personality trait these days.
