Results 1 to 10 of 10
Thread: Anyone Using These To Suppert Th Chassis?
    Member Carography's Avatar
    Marysville, WA
    I was thinking of using these (4) to support the chassis before its a roller.
    Anyone know if all 4 casters are the swivel type? I want to be able to push the kit side to side periodically. As well as back and aft.
    Harbor Freight
    18x12 1000lbs capacity
    Marysville, WA
    302, GT40 heads, 5speed, 3.55:1 Solid Axle.
    Kit ordered 7/8/2024 - Completion date 8/17/2024
    Feb 2024
    Outside Boise Idaho
    I have one of these and all 4 wheels swivel. I am following namrups example and clamping jack stands to wheel dollies for the initial stage of the build to give me more height for my kit that is due to arrive this week.
    Andrew
    Jun 2023
    Tonganoxie KS
    I have used them to move my car (with motor and trans installed) under the wheels. They are definitely strong enough but not the perfect solution
    Senior Member dstelter's Avatar
    Jan 2019
    Paige TX
    yep used 4 of them when i built my coupe. but only without the engine and trans. Was worried they might not hold up to the extra weight.
    Doug
    Oct 2019
    Erin, Ontario CANADA
    I've been shifting the bare frame around my garage and beyond on two wheel dollies without issue.
    Mar 2014
    Crossville, TN & Punta Gorda, FL
    I used one of them to hold my engine and transmission with no problem. 460 ford, aluminum heads
    and TKO transmission. moved very easy.
    I have some of those and use them for light duty work. Probably would be OK for the chassis only. But not with the driveline installed. And I sure wouldn't get under it with those. For about $100 more, you can invest in some real wheel dollies that you can trust and will work much better. I have a set of four and use them a lot.
    https://www.harborfreight.com/2500-l...ece-58394.html
    Nov 2023
    Can't remember where I got them now, but they make a triangular piece of metal (about 10 inches per side) with a steel roller ball at each corner. I originally bought them to put under a couple of snowmobiles to jockey around to different areas of my shop , depending on where in the shop I was working at the time. Later, I had placed one under each corner of a fully built TR6 (about the same weight as a Cobra). Worked like a charm.
    Oct 2020
    Albany, NY
    You mean these?
    Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
    Build 2 MK4 #11061- Delivered 08/24/24
    Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
  10. Thanks Carography thanked for this post
  11. #10
    Marysville, WA
    Blitzboy54; that's awesome, thanks
    Marysville, WA
