Results 1 to 5 of 5
Thread: Shocks over extending
    Senior Member Guardm16's Avatar
    Prescott, AZ
    How do you keep this from happening?
    To get the front suspension ride height set right, I had to lower the spring seat on the adjustment sleeve. Now, when I jack the front of the truck up, the shock extends beyond the length of the spring. Do I need limiting straps?
    Additionally the 35 truck manual says the front shock extended length should be 15.15 inches. (that was how I determined which shock body to use up front) This is exactly what I have. It also say that the front shocks are 2.5 inches shorter than the Rear shocks, My rear shocks are about 1/2 inch shorter than the front. Should I put the shorter shocks in the front?
    Search for helper springs on Jegs or similar. It’s an easy fix (I had the same issue)
    Prescott, AZ
    Quote Originally Posted by RoadRacer View Post
    At this point I am also concerned about the sag in the back. With the rear shocks fully extended the rear is level or just lower than the front. I really want a slightly higher rear. So, something is just not right.
    Yes, it does sound like you need to check everything
    I think this part is the key.. call FFR. It sounds like you got wrong parts.. the manual could be out of date, but I would expect the rears to be longer, not shorter.
    > It also says that the front shocks are 2.5 inches shorter than the Rear shocks; my rear shocks are about 1/2 inch shorter than the front. Should I put the shorter shocks in the front?
