Likes Likes:  7
Thread: We Took the 5.2L Predator-Powered Mk4 to the Dyno
    Webmaster, FFR
    Middleboro, MA
    We built this Mk4 Roadster with the crew at Hot Rod Brothers the other year, and it features the 5.2L Predator supercharged motor along with Tremec 5-speed transmission, IRS, and 17″ Halibrand wheels. Factory Five tech Dan G. took the Roadster up to Cohesion Motorsports in Lawrence, MA to tune the engine and see what it would do on the dyno. Check out his report in this video.
    The results were 654.4 HP and 533.8 trq which is right about where it should be for the stock Predator engine. And remember, this is in a car that weighs right around 2,400 lbs.
    Check out more photos of this Roadster build here.
    Thanks to the crew at Cohension Motorsports for their help at the dyno!
    Dave Lindsey
    FFR's Mad Dog
  2. Likes JohnK liked this post
    Folsom, CA
    WOWSERS! That's a panty dropper!!
    Todd
  4. Likes Mad Dog liked this post
  5. #3
    Aug 2012
    Grand Rapids, MI
    That'll be fun.
    Jim
  6. Likes Mad Dog liked this post
  7. #4
    Oct 2020
    Albany, NY
    Registered in Montana... lol
    Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
    Build 2 MK4 #11061- Delivered 08/24/24
    Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
  8. Likes fauxbra5.0, Mike.Bray, Mad Dog liked this post
  9. #5
    Member fauxbra5.0's Avatar
    Jul 2024
    Oak Ridge, TN
    That's damn impressive, although Dan's messaging seems like they were a bit disappointed at the result. Regardless, 650hp in a 2400lb car would give a similar power/weight ratio as a McLaren Senna! That kind of power (if you can go 10/10ths) must absolutely scramble your brain...
    Future FFR builder/owner. Currently in planning & discovery stages for a MkIV Roadster, the "Fauxbra".
    Part village idiot, part caveman.
    Build website & more - fauxbra.com
    Instagram
  10. Likes Mad Dog liked this post
  11. #6
    Nov 2023
    I watched the video and would like to point out that it produces 654 horsepower AT THE REAR WHEELS. I can only imagine what it produces at the flywheel.
    My second observation: During the video Dan talks about engine cooling and says the weather was "humid". What difference does "humidity" make? PEOPLE cool less efficiently because we perspire and the evaporation of that is what cools us. Cars and engines don't "sweat" so humidity is not a factor in cooling.
  12. #7
    Senior Member JJK's Avatar
    Jul 2022
    DFW Texas
    I thought the same thing about the humidity comment. Even though it is called a radiator, the cars cooling is based predominantly on conduction heat transfer, not convection or radiation. Given that water conducts heat much more effectively than air, I would argue that higher humidity results in more efficient cooling. Now, higher humidity also affects the amount of usable oxygen in a predefined volume, so I would expect less power with higher humidity, even more so with a forced induction system. With higher humidity there is less air to mix with fuel compared to lower humidity, thus less bang in the cylinders. While this theory is sound, I have no idea the actual power loss from higher humidity , it could be negligible.
  13. #8
    Folsom, CA
    btw - watch to the end, the gopro is hilarious
    Todd
  14. #9
    Nov 2023
    Quote Originally Posted by JJK View Post
    JJK....I couldn't agree with you more. I actually thought about this, including the oxygen content of the air for combustion, and even the possible "anti-detonation" effect of the water content of the air (sort of like water injection). But what I think is that while humidity has a MAJOR effect on the cooling of human beings....the effect of relative air humidity is probably so small as to be negligable. Air temperature, on the other hand, does have an impact....both in cooling and producing power.
