Thanks Thanks:  3
Likes Likes:  11
Results 1 to 20 of 20
Thread: oh ye electrical gremlin... go away (please) - RESOLVED! bad LED!
    Folsom, CA
    ok - the car is (was) fully working IMHO before paint - two electrical gremlins bugging me
    1. high beams on by default - already chasing this one https://thefactoryfiveforum.com/show...-on-by-default wiring looks good, but still digging
    2. right turn signal flashes all the dash lights - yes, you read that correctly...
    using the left turn signal is just perfect, left lights blink on/off or hi/low (if lights are on), and the left indicator blinks in the speedhut speedo
    setup:
    RT Turn Signal setup
    IDIDIT relay for high/low beam on the stalk
    RF wire harness
    Speedhut wire harness
    locking hazard button
    we've pulled the lower dash/stereo out to get more room - trying 'not' to pull the dash if we don't really have to
    also took the speedometer out of the dash to see inside a bit more
    somehow we're determining that the right turn flasher is somehow tied into the dash lights - trying to trace everything
    here's the testing (over testing IMHO) on the wiring
    as would be expected if you hook up a white dash light wire to pink flash wire
    all 4 lights flash on/off - but so does the dash
    hazard light activity:
    turn the light switch on - dash lights turn on - press hazard, 4 hazards flash as expected, dash is lit (no flashing)
    turn the lights off - dash lights turn off - press hazard, 4 hazards flash and the dash flashes
    turn signal activity:
    key on, activate left turn signal, left turn signals blink, left turn signal blinks in speedo
    key on, activate rt turn signal, rt turn signals blink, rt turn signal blinks in speedo, AND all dash lights blink
    connect green left turn to pink hazard, left blinks as hazard, front right parking light goes out
    blue hzd rt connect to pink hzd flash - all 4 blink
    light switch turned on green left side turn - connect to pink hzd
    left front blinks low/hi flash, right front blinks on/off flash
    left rear blinks low/hi flash, right rear stays on low light, no flash
    light switch turned on blue right side turn - connect to pink hzd
    left front stays at low light no flash, right front does low/hi flash
    left rear stays at low light no flash, right rear does low/hi flash
    light switch turned off green left side turn - connect to pink hzd
    left front blinks on/off, right front is off
    left rear blinks on/off, right rear is off
    light switch turned off blue right side turn - connect to pink hzd
    dash flashes with lights
    very odd how some of the corner lights flash differently depending on wire connections - obviously not fully wired as expected as the hazards are wired in pairs (front/rear, left/right) so that may be the odd blinking modes
    really perplexed that when the right turn signal is used, the dash flashes...
    I know it's a matter of tracing wires, but any first thoughts? very odd!!
    Todd
    South Australia
    G'day Todd,
    Most of these, if not all will be grounding issues. This is particularly the case when unrelated lamps glow. It is a case of positive voltages unable to flow directly to ground, and instead finding their way to ground through other lamps, in turn causing them to glow. Check all grounding to chassis of head, tail and indicator lamps at vehicle corners. Take time to think of what might have been disturbed during prep for paint. Don't hesitate to reach out.
    Best of luck,
    Nige
    Gen1 Coyote / TKO600 / IRS
  3. Likes toadster, J R Jones liked this post
    South Australia
    Take the front right hand indicator lamp out of its socket and see if the dash light/ front right indicator issue goes away. From your description it would appear that right indicator and parking light circuit are shorted together. One obvious place for this to happen is in the lamp holder.
    Nige
  5. Likes toadster, J R Jones liked this post
  6. #4
    Wacky behavior like this is often one of two things...either a weak ground at one of the lamps which will allow current to backflow as it seeks ground OR a bulb that is clocked incorrectly in it's socket and which will allow both terminals of the bulb to touch the contacts in the socket. I'd start with the easiest path by taking bulbs out of the parking light sockets and see if that cures it.
    EDIT: After reading Nigel's comments it looks like he and I are both on the same page
  7. Likes nucjd19 liked this post
  8. #5
    Folsom, CA
    thanks guys! hopefully that will be some quick testing
    Todd
  9. #6
    Dec 2021
    Flower Mound TX
    Groundliness is next to Godliness.
  10. Thanks toadster thanked for this post
    Likes toadster, Nigel Allen liked this post
  11. #7
    Folsom, CA
    LOL yeah
    Todd
  12. #8
    Oct 2020
    Albany, NY
    Seriously, I over grounded everything. Can’t have too many (maybe you can but I have not yet found the limit)
  13. Likes toadster, cv2065 liked this post
  14. #9
    Also look at grounding bolts threaded in to the frame that may have been removed and then that area was painted. Or a light socket pulled from the body, left hanging, and got some paint into it.
  15. #10
    Seriously, I over grounded everything. Can have too many (maybe you can but I have not yet found the limit)
    I agree, decades ago I was a Lexus tech and we had a car w/ very weird auto trans shifting. Tried this and that and finally ordered a trans to be replaced under warranty. Still shifted weird. Finally found that a ground wire that bolted to the back of the intake plenum (cross wise V6 so plenum to firewall clearance was about 3/4inch) was attached but the bolt was not tight. History showed that about 4 months prior a brake line had been replaced which required removing that ground wire to get it out of the car. We were pretty sure that the bolt had been installed finger tight but the final wrench tightening (maybe one full turn) had been overlooked.
  16. Thanks toadster thanked for this post
  17. #11
    Nov 2018
    CT
    I chased a wacky turn signal issue I was having for over a month. It ended up being the bulb like Nigel and Jeff said. Lesson learned-always start with the easiest solution first.
  18. #12
    Folsom, CA
    pulled the front right led bulb, dash flashing goes away - doing more testing
    thanks guys!
    Todd
  19. #13
    South Australia
    Try putting the left hand lamp in there, as it had been working okay.
  20. #14
    thanks guys!
    Put it back in clcoked correctly.
    Dec 2021
    Flower Mound TX
  22. #16
    Folsom, CA
    ok - looks to be one bad LED 'upgrade' bulb that I have - one of them works, the bad one replicates issues side to side and on the dash - SO weird!
    so back to incandescent until I get a replacement...
    it's simply unbelievable - one bad bulb caused the dash to flash (depending on what side it was on), it caused my hazard light itself NOT to flash, AND it killed my horn! WTH??!
    swapped out to good bulbs and everything works perfectly!
    WOWSERS! Thanks all for your help!
    Todd
  23. Likes Fman liked this post
  24. #17
    South Australia
    Wow, great outcome. The horn fault has me beat.
  25. #18
    Folsom, CA
    totally agree! no clue why the horn quit at the same time!
    Todd
  26. #19
    Nov 2018
    CT
    Glad you figured it out. I was having similar strange issues and after a month of testing and researching it ended up being an LED turn signal bulb that was not turned all the way to the left. It's so frustrating when you are that close to being finished and something so minor sets you back.
  27. Thanks toadster thanked for this post
    Likes toadster liked this post
  28. #20
    Senior Member BRRT's Avatar
    Sep 2020
    That is insane! Glad you found it.
    Nigel and Kleiner have super powers.
    Roadster delivered 8/27/23
    Chevrolet Performance LS3
