Thanks Thanks:  3
Results 1 to 4 of 4
Thread: Brake Reservoir Mount
    Apr 2024
    How important is it to have the reservoir above the master cylinder, Can't seem to find a place to mount it high enough? Any photos? The most of the reservoir is above the master cylinder, but the fitting is below and causes the hose to be above the master cylinders. Not sure what effect that would cause or even work.
    Anywhere I put it the fitting is still below the master cylinders.
    Jul 2022
    Wellsboro, PA
    It doesn't seem to be too important. Mine seems to be working just fine. Make sure all your connections are tight. I think the design is just the masters "suck" the fluid they need through the top cap connections.
    Here is how I mounted mine.
    1990 Mustang 5.0 5sp, 2021 Bronco Sport Badlands, 1935 Extended Cab Build, 347 & 4R70W
  3. Thanks scspeedster thanked for this post
    Senior Member rthomas98's Avatar
    Aug 2012
    Ypsilanti, MI
    It is only important if you plan to gravity bleed the brakes. If you use a power bleeder no worries at all.
  5. Thanks scspeedster thanked for this post
  6. #4
    Dec 2020
    Washington, MO.
    As long as the fluid level in the reservoir is higher that the m/c you are actually above the needed level.
  7. Thanks scspeedster thanked for this post
