So, not as much time to work on things, but whittling away a couple items and waiting parts.
Got the ball joint support completed, (No battle plan ever survives first contact), used Jeff K. recommendation. Sourced some hooks and turn buckles from McMaster and an extra set of exhaust hangers from Amazon.
1) Had to modify the hooks and open them up to fit the rubber
2) had to cut 1/4 inch off each end of the turn buckle to be able to really tension the whole set up.
3) Put some black BBQ high temp paint (Note after this I noticed ACE Hardware had some black ones on the rack, could have saved me some shipping and black paint!)
4) Fully functional!
I completed my redo of the F panels, no drama there.
Adjusted the forte Throttle link to give a little more pedal play to full open.
Moved the Radiator support to the rear of the breeze hinge assembly, gave me enough clearance for the radiator to the front 3/4 tube.
Current hold up
1)Got me 3 new Tilton M/C, but the outlet is 3-AN instead of 1/8 NPT, so more hardware and hope it will not have to much impact on my plumbing, I will cover that when done. They also have 5/16 instead of 1/4 reservoir hose, so some rework on that will be coming up.
2)Got my new boot covers for the ball joints. Part number in the picture, but I was really UN-satisfied with the lower boot, would not cover the ball joint when it was skewed, top was great. I ended up ordering another part I found on the forum and waiting for that to arrive. Used a pickle fork and no issues separating the joints.
Post Thanks / Like - 1 Thanks, 1 Likes
