Results 1 to 11 of 11
Thread: SOLD: FFR Cobra MK3.1 - I hate to see it go, but it's time to move on.
    Bill_VA's Avatar
    Manassas, VA
    Well, it’s been a blast, but it’s time to let the Cobra go. The car was finished the summer of 2006 and it’s been rock-solid reliable ever since. I’ve run it at 130mph down the front straight at Summit Point, and just a tad over the legal limit on the Tail of the Dragon (https://www.youtube.com/watch?v=RpOv10Thd78). The car performs incredibly well and looks good doing it.
    When I built it, my goal was to do it right the first time, and to build it well. I probably spent as much time planning and pondering as I did turning wrenches and popping rivets. All wire connections were soldered and heat shrunk, not a single electrical issue in 18 years. The engine is a 351W build using a 1974 block that was modified to use roller lifters. I ran that engine at redline down the front straight at Summit Point during all four 25-minute sessions (I had a lot going on during my first time on track, LOL).
    The car is in terrific condition. Paint looks almost as good as it did 18 years ago, except for a bit of typical road rash in the front – hey, I drive this thing!
    I’ve been told by several people who know Cobras that mine is one of the finest examples out there. Scott Harrison, the president of the Capital Area Cobra Club, stated “Your car is exceptional!” Who am I to argue?
    When I completed the car in 2006, I had about $55k in it. I’ve done a fair amount to it since then to improve and/or maintain it’s performance and handling. Easily another $15k+ in improvements since then. I have receipts for everything.
    Price is $60,000.
    PM or Call/Text: 703-517-8316
    Ordered: 9/2005
    Titled: 3/2006 as 1965 Factory Five Racing 2D Conv, I have Virginia antique tags and no personal property taxes!
    Completed: 6/2006
    Milage: 44,383
    Color: Viper Steel Gray Pearl body and Cyber Gray stripes
    Located in Manassas, VA
    FFR Options:
    • Koni single adjustable shocks
    • 3-link rear – solid rod end attachment points
    • Autometer Ultralite gauges
    • Windshield wipers with auto-park
    • FFR Carbon fiber dash
    • Powdercoated chassis
    • Carbon fiber inner door panels
    • Dual roll bars, custom chromed, blind mounts
    • Wind wings and visors
    • American Autowire wiring harness
    • Chromed quick jacks
    Other Options
    • 351W, 425hp, 1974 block, roller cam conversion
      • Originally built by Engine Factory
      • Edelbrock RPM Performer intake and heads
      • Holley Terminator X Stealth fuel injection system – done in 2022
      • Holley Hyperspark distributor and ignition box
      • March pulleys
      • March billet alternator
      • Intake, timing cover, and oil pan are ceramic coated
      • Customized Roush spark plug looms
      • Taylor 10mm wires
      • Fabricated aluminum valve covers
      • Quality Roadster (Canton) road race 8qt oil pan
      • Custom aluminum upper radiator tube
    • Tremec TKO 500 w/ midshift mod
    • King Cobra clutch set
    • 3.73 rear diff
    • Mustang Cobra brakes with 13” front and 11.6” rear
    • Forte’s pedal box with Wilwood m/c’s
    • Hydraulic clutch
    • CNC triple reservoir
    • Pro50 shifter
    • Upgraded loop carpet
    • Finish Line side louvers
    • Finish Line SS bumper sleeves
    • Custom Cobra Valley switch guards
    • Cool-It heat insulation
    • Fat Mat sound deadening
    • Mike’s seat belt, windshield, and rollbar trim
    • Hidden body mounts
    • Russ Thompson turn signal
    • Whitby’s stainless windshield mount inserts
    • Kirkey 17” Intermediate Road Race seat w/ custom padding
    • G-Force racing 5-point harness w/ camlocks
    • CobraHeat waterproof seat heaters for both seats
    • Convex rear view and side mirrors
    • Carbon fiber shift knob
    • Carbon fiber wheel spats
    • Lokar e-brake mounted on top of trans tunnel with cantilever
    • FFmetal Firewall Forward kit with expanded passenger footbox
    • FFmetal no-hole passenger f-panel
    • FFmetal battery box with Optima RedTop
    • FFmetal transmission tunnel top
    • FFmetal fan shroud
    • Southern States heater w/defroster
    • Billet aluminum door hinges
    • Gas-N-Performance polished stainless pipes with matching heat shields
    • Gas-N-Performance 4 into 4 headers with header wrap
    • KRC aluminum racing power steering pump and pulley
    • AGR Cobra-replica specific power steering rack
    • SAI front suspension mod
    • Forte’s bump steer kit
    • Forte’s mechanical throttle linkage
    • Custom engineered lower control arms with rod ends
    • QA1 racing ball joints
    • New upper control arms with delrin bushings
    • Levy billet lower rear control arms
    • VPM front and rear sway bars
    • VPM 3-link frame brace
    • Dark Water Customs aluminum door sill trim
    • LED tail lights
    • Custom PiggyBack cockpit cover with “COBRA” letters
    • Body professionally finished and painted by NCPainter
    • FR-500 chrome wheels
    • Nitto NT05 315/35/17 and 255/40/17
    Built with all new parts, no donor parts.
    IMG_7174.jpg IMG_7175.jpg IMG_7176.jpg IMG_7177.jpg IMG_7178.jpg IMG_7179.jpg IMG_7180.jpg IMG_7181.jpg IMG_7182.jpg IMG_7183.jpg
    Owner of FFmetal.com
    Bill_VA's Avatar
    Manassas, VA
    Jul 2021
    Tonganoxie, KS
    Good luck with your sale, Bill! I remember this build from the ffcobra.com days....awesome job, for sure! I sold my MkIII around the same time you started your build. It was hard to let go, so I can appreciate the emotions you're feeling. Someone will get an awesome car, for sure!
    Greg
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
    Bill_VA's Avatar
    Manassas, VA
    FYI, the president of the Capital Area Cobra Club in the DC area said this today on my classified post there:
    "Bill was beyond anal when he built this. It is THE best built FFR I have ever seen. The level of detail is incomparable.
    I can't believe it has 44k miles on it. Not sure how he got Antique tags, since the car is only 18 years old, but it's a bonus to any VA buyer."
    Bill_VA's Avatar
    Manassas, VA
    SOLD! A nice gentleman in Pittsburg just purchased the car. FYI, the car was sold for almost near asking price.
    Congrats Bill! Mine went this week also...full asking price, sight unseen in 2 hours!
    Don't know what's up for you but it's on to the next one for me. Since I complete my Mk3 over 16 years ago I've done a bunch of cars for others and it'll be fun to do one for myself again
    Jul 2021
    Tonganoxie, KS
    Congrats, Bill! Glad you got near asking price!
    Jax Beach, FL
    Bill and Jeff, Did they sell from the forum? If not, where did you list your cars? I am going to be moving overseas and am going to be letting mine go soon.
    I put it on the forum and 4 of the Facebook FFR owner/builder pages. First response was due to one of the FB group posts and resulted in a sight unseen full price sale with a wire transfer to my account within 2 hours of posting. In total I had over 20 inquiries (this all tells me that I probably could have pushed the price up a bit but I don't have any regrets).
    The bubble that we saw about 2 years ago has deflated a bit and has stabilized but if you price it realistically it'll go. Good luck!
    Jax Beach, FL
    Jeff, Thanks or the info. What a dream sale.
    I can't wait to see what you are going to do next.
    Bill_VA's Avatar
    Manassas, VA
    Yes, the buyer found it here.
