Results 1 to 19 of 19
Thread: fuel filler body cut out
    Apr 2024
    Potomac, MD - Near DC
    So my kit came with the fuel filler traced in yellow, but not cut out. Did you guys cut along the traced yellow lines, or did you cut some other place? As I do the body work I'm getting closer to deciding where to make the hole and also sanding and such is washing out the FFR yellow traced lines. Any suggestions? Thanks. Fred
    Port Charlotte, FL
    Fred,
    I use the included gasket to center the hole where I want it before drilling.
    Henry
    Apr 2024
    Thanks Henry,
    I should have added my kit is a 289. Does that make a difference.
    Fred
    Norton, MA USA earth
    Both 289s that I have done, the customer wanted the gas cap "on" the body rather than mounted to the FFR supplied bracket. This eliminates the open area around the gas cap. Looks just fine and makes installation a lot easier. Consider this when you drill the hole. I had to fill one of them in and recut.
    Apr 2024
    Thanks Mike. I just went out to the garage and fished around in box 29 and found the bracket you mentioned. I think I will use that. Any down sides to using the bracket over "on" the body mounting of the gas cap? I suspect if I cut along the FFR traced lines on the body then I can adjust the bracket and the hoses to line up underneath. Flawed logic here? Thanks. Fred
    No good reason not to use it.
    mike
    Apr 2024
    Agreed, thanks.
    Fred
    Senior Member OttawaFFRer's Avatar
    Ottawa, Canada
    Quote Originally Posted by FRM View Post
    Agreed, thanks.
    Fred
    I attached mine to the body. I don't understand why anyone would choose differently. Attempting body work.
    10 years after my roadster build....
    289 FIA (pickup 28/08/20 if covid permits)
    currently building a 289 and accumulating parts needed to finish a Canadian Kit.
    Apr 2024
    That does look pretty good. Not to "flexible" being supported by the fiberglass? Maybe I should think again. I am getting my engine early so will focus on that in the near-term and come back to body work afterward and will have time to rethink.
    Ottawa, Canada
    My body has enough space to put gasket around the entire read bulkhead, not sure why. There is some "flex" but its small. The hose adds support. I used a flexible fuel hose like this.
    https://www.ebay.co.uk/itm/363329424...YAAOSwKVFlw2NP
    Apr 2024
    thanks, I'll look into it. would be less "stuff" between filler cap and gas tank. did you cut on the yellow traced line or fit the cap and cut to that?
    Ottawa, Canada
    I'm not sure if there was a yellow circle inside the outside yellow circle. It's been a while since I cut it, the yellow circle remains outside the boundaries of the filler. A view from underneath, bodywork incomplete, and fuel hose on to keep dust out so no clamp.
    Apr 2024
    So I connected up the fuel filler tubes, soft and hard lines..........was a bit of a puzzle........but now have what I think will be the fuel filler set up. Body is still off so I haven't lined up and cut anything. I may be doing an about face and mounting the cap on the body. Time will tell when I fit the body back on. Thanks for the pictures and suggestions.
    Senior Member Chainsaw's Avatar
    May 2020
    St. Johns, FL
    FFR didn't cut out my fuel filler hole , so I have to guess where it goes. I have the fuel tube mounted and I've done some measurements based upon fixed location on the car (the passenger seat headrest) but I can adjust a bit. Does anyone have any location dimensions that I can compare to the estimated location I currently have?
    Jack
    289 Roadster complete kit ordered 8/2/21. Delivered 3/14/2022. Chassis #10306. 17"x9" Halibrands, 3.55 IRS, PS, Wilwood brakes, BPE 306 with EFI and close ratio TKX. First start 7/20/2023. First Movement 9/24/2023. First go-kart 9/25/2023.
    Build thread - https://thefactoryfiveforum.com/show...rida-289-Build
    Apr 2020
    Bonney Lake, WA
    My body has a yellow circle showing the location, I'll get some measurements to give you a general location.
    Jim Phoenix
    Coupe-R delivered 8/10/2024
    289 USRRC, F5R1011063RD - delivered same day
    Coupe-R has a Ford Performance 363 mated to a TKX, 18084.
    Many details on my Coupe-R are different from a typical Coupe build because mine is not street legal, race only.
    289 has a BP 302 mated to a TKX 18084.
    "For a little more, you can do it yourself." - Ed Hollingsworth... 6-Pack forums
    Ottawa, Canada
    They have changed this forum and I can figure out how to post photos...linking to my Google Drive.
    the front edge of my cutout is 4.5 inches from the edge of the cockpit
    https://photos.app.goo.gl/rN9P9u8j1zuqV6kY7
    about 14.25 inches from the seam.
    https://photos.app.goo.gl/P7SAPJgXXiDRbSKg9
    The other seams can also help reference.
    Apr 2020
    Bonney Lake, WA
    Longitudinally it's 12.75" from the trunk cutout to the center of the filler circle. Transversely, it's 26.4" from the edge of the right wheel well cutout. You can see how I positioned the tape measure so you can duplicate the measurements. No guarantee these measurements are accurate, some things FFR has done have not been very accurate, but close enough :-)
    Jim Phoenix
  18. Thanks Chainsaw thanked for this post
  19. #18
    May 2020
    St. Johns, FL
    Quote Originally Posted by Jphoenix View Post
    Excellent. Thanks!
    Jack
  20. Likes Jphoenix liked this post
  21. #19
    Apr 2024
    I think I'll put the body on and then align the filler below the body, mark it and cut after. Originally was thinking I'd use the supplied metal mounts, but then comments here have me rethinking that strategy and I plan to mount the filler cap to the body. Seems there is some latitude to move it some and cutting along the yellow lines may not be the best approach. Also the yellow circle is quite large.
