08-21-2024, 04:33 PM
#481
Thanks for the pics!
First pic is your upper coolant reservoir, and that's not an OEM one.
3 and 4 pics are your Intake cam ACVS solenoid (variable valve/cam timing) and that banjo bolt is connecting to an oil line/gallery. Don't think the leak is from that, as it'd be an oil leak not a water leak.
I'd focus on checking the clamps, hoses and barbs of the upper reservoir.
Also, how is the tube plumbed into the overflow bottle?
08-22-2024, 01:12 AM
#482
Check the turbo cooling hose. The one that has the heat shield on it. The lower end is very close to the hot turbo. It's hard to see a leak unless you look from under the car. I carry a spare of that hose to the track.
08-28-2024, 05:46 AM
#483
Found the leak....after I pressurized the system. Here is the orienting picture..
Here is where the leak was....
Mounting bracket on the back of the aluminum collection box. Bad news was that it was a bugger to find. Good news is that it never would have failed catastrophically....opted for a JB weld solution first, before trying to weld the aluminum with its inherent challenges (for me). I am going to slot one of the mounting holes to allow a little movement and try to keep some of the stress down. Leak is visible on the far right of the mounting bracket. A hairline crack at the weld edge.
09-07-2024, 05:13 AM
#484
Track day yesterday at CMP. 8 cars in my run group, so basically an open track. Car ran great. No coolant leaks. Temps in the 70's. More data to follow.
10-18-2024, 06:08 AM
#485
Track day at CMP on 10/17. 9 cars in my run group. It was cold. About 40F for the first session, with 55 by the third session. Took about 3 laps to get the tires up to temp. The turbo loves the cool air. Coolant temp was 163F and IAT was 87F max.
10-18-2024, 03:52 PM
#486
Rob T
What's on the post track day to-do list? I've yet to have a track day without some item that needs attention before the next track day. Curious what others are experiencing. My new clutch arrived yesterday and I'll start the installation a bit later today.
10-19-2024, 05:51 AM
#487
Good Question. I only really had one issue. My push lock button that holds the hood on the driver's side in the back was jammed and I didn't realize it. That caused the hood to lift and cut my first session short. I am going to put a bit of oil on all of those to make sure they don't stick. I also plan to see how the repair to my coolant tank collection box is holding up. Other than that, a quick run-through of fasteners, brake pads, etc. I generally run only three sessions per outing of 20 minute duration.
10-19-2024, 06:16 PM
#488
Rob T
Rob, Is your IAT sensor before of after the AWIC?
10-20-2024, 05:30 AM
#489
After. I also have a sensor in the water feed to the AWIC. Generally, I get Ambient +15 degree water temperature to the AWIC heat exchanger and +10 degrees above that For the air going to the engine after the AWIC. My car has a separate radiator in front of the engine radiator (coldest air) for the AWIC water loop. I have also T'd into the AWIC water line after the intercooler and bypass a small amount of water through a tube in shell heat exchanger that cools the 6 spd transmission. With the low flow to the tube in shell, it did not have a negative impact on the AWIC water loop temp.
10-20-2024, 06:04 AM
#490
As an additional point, I have only seen one track session where timing was pulled (indicated on the COBB Accessport I have on the dash). It was 95F ambient with higher temps on the track. Other than that, full timing has always been available with this set up. This is also a speed density tune, running 93 Octane gas.
Rob T
Thanks for the numbers.
I only have 2 spare ECU inputs so I use them for oil pressure and temperature. (kinda important)
My air intake is snorkeled to the right side vent so my MAP/AIT sensor gives me track air temp. I can wire that temperature sensor wiring to a sensor right before the throttle body. That may affect my tune.
Here's a picture of the Sirrocco radiator I use for the AWIC.
My air intake is at the wheel vent. Speed Density (intake temp at throttle body). AWIC. 91 octane gas. No knock detected.
107 degree day, 100% throttle, 4,771 rpm: Intake temp 196, 13.7 psi boost, timing 4.5.
54 degree day, 100% throttle, 4,786 rpm: Intake temp 122, 17.4 psi boost, timing 11.5.
I've asked my tuner at what intake temp should I limp mode. Oddly, he won't give me a hard answer. The ECU deals with it.
