Results 1 to 4 of 4
Thread: Brembo front brakes
    Sweden
    Brembo front brakes
    Which front brakes fit on a 33 hot rod? Can I fit Brembo 6-piston calipers and discs from a 2015+mustang (disregarding rim size/rim clearance)?
    Are the Brembo calipers fixed mounted to the spindle? The “standard” caliper are “floating/sliding” on pins but the Brembo are not?
    On a roll Al_C's Avatar
    Wheaton, IL
    I, too, am a fan of Brembo brakes. I can't tell you if or which model fit a hot rod, but I can tell you that the Wilwoods do fit and are quite good. I have the Wilwoods on my roadster and am very happy with them. Just my opinion.
    Sep 2022
    Colorado Springs
    The hubs are, I understand, based on the sn95 mustang platform. anything newer will probably require custom hardware. Something like this should bolt right up:
    https://lmr.com/item/M2300X/1996-04-...caArzmEALw_wcB
    I use the 'Cobra R' Brembo fronts on my Gen III Coupe - I presume our cars use the same spindles but I'm not sure.
    Gen III #17
    22,000+ miles
