London Cobra Show
Thanks Thanks:  2
Results 1 to 4 of 4
Thread: Transmission Cooler
    Junior Member FatherAndSon's Avatar
    May 2023
    Wake Forest, NC
    Transmission Cooler
    I've been looking around at the various posts here on what has been used for a transmission cooler. Most guys have gone with a Derale powered one (DonImbimbo, Edwardb & Stillwater35). Has anyone been able to use a small plate and fin one somewhere in the front? I found a post where it looked like 'Just 1 More' was able to get it to fit on the 33 Coupe: https://thefactoryfiveforum.com/show...l=1#post539867
    I'm running a very mild 302 with an AOD transmission but I don't have room in front of the radiator due to the AC condenser. The truck won't be towing anything, racing or any other heavy duty use.
    Matthew and Noah
    '35 Hot Rod Truck - 5.0L 302
    Wake Forest, NC
    @father.and.son.35
    Prescott, AZ
    Quote Originally Posted by FatherAndSon View Post
    Yes...kind of, I also have the A/C condenser. I bought an AOD from Monster Transmission it came with a cooler about 9x11 inches. I located the cooler to the horizontal frame supports just ahead of the fuel tank. It mounts easy with inexpensive angle...the kind with all the holes and slots pre-drilled. I bought a 9" electric fan and mounted to the front of the cooler. The entire unit sits just above the Panhard bar. I will get some pictures for you this weekend.
  3. Likes FatherAndSon liked this post
    Sep 2022
    Huntington, IN
    33 Hot Rod, I put one where the horns go.
  5. Thanks FatherAndSon thanked for this post
  6. #4
    Prescott, AZ
    Quote Originally Posted by Guardm16 View Post
    I think this shows how it went in
  7. Thanks FatherAndSon thanked for this post
