Results 1 to 3 of 3
Thread: Gen 2 Coyote install with Gen 3 kit?
    May 2023
    Frisco, TX
    Hello Gurus.
    I’ve searched the forums for the answer, and I may be the only one dumb enough to need to ask:can I install a Gen 2 Coyote in my roadster with the install kit/headers/mounts/etc that came with my kit last year, which I understand to be designed for the Gen 3?
    I’m considering a change of direction on which engine I’m going to use, and now leaning toward a Gen 2 with Holley Terminator X Max and some Inglese EFI “Weber” stacks. But I think I’ll only go this route if I don’t have to replace my install kit/components.
    Thank you!
    MKIV Complete Kit # 207585
    Ordered 8/19/2023. Completion date 11/11/23. Delivery date 11/27/23
    Build Thread: http://https://thefactoryfiveforum.c...577#post535577
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    I installed a Gen 2 Coyote using the FFR Gen 3 install kit, including headers with catalytic converters and engine mounts. For the most part, everything was there that I needed as well as some additional parts that I didn't need. There were no major items that I needed to purchase, maybe just a few plumbing parts.
  3. Thanks Mbufford thanked for this post
    May 2023
    Frisco, TX
    Fantastic, then that’s the way I will be going as well. Thanks for the reply!
