Thanks Thanks:  2
Likes Likes:  3
Thread: How-to Install Brake Duct and Oil Cooler Mesh In Place
    Jul 2024
    BC, Canada
    How are you guys bonding these brake duct and oil cooler mesh pieces in place?
    I bought the Finish Line sets and the brake ducts look like I’ll need to slightly modify. The oil cooler mesh came as a flat piece that I guess I have to cut and form myself?
    I’ve seen guys use silicon but understand it’ll let go over time.
    Maybe that’s a good thing for ease of removal?
    Got any pics?
    Senior Member Norm B's Avatar
    Exterior grade silicone. The car has been on the road ten years, driven in most conditions (no snow yet) and they are still stuck tight.
    For the oil cooler, I stuck a board behind the opening, traced the inside of the hole with a sharpie and cut the board out 1/4 inch outside that line. Used the board to shape the flat sheet to fit around the opening.
    Norm
    Jul 2024
    BC, Canada
    Fantastic
    Thanks Norm
    Very much appreciated
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    Agree with Norm, exterior grade silicone works well. For my oil cooler opening, I cut an oversized rectangle piece of the mesh and press fit it in place from the inside, bending it around the lip. I then trimmed off the excess mesh and glued in place with silicone. The mesh provides a good lattice structure for the silicone to bond to.
  5. Thanks Doc76 thanked for this post
    Likes Doc76 liked this post
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Ken Pike recommended I use Permatex Ultra Black. It's basically oil-resistant RTV silicone. Worked perfectly and blends seamlessly with the black undercoating on the backside of the body.
    Silicone. Convinced yet?
  8. Likes Doc76, Mike.Bray liked this post
  9. #7
    Silicone - installed late 2014. All three ducts
    Kevin
    MKIV #8234
  10. Thanks Doc76 thanked for this post
