Thread: Grill Mounting Angle
    Junior Member FatherAndSon's Avatar
    May 2023
    Wake Forest, NC
    For builds that don't have a hood or sides, is the angle at which you mount the grill variable or is it supposed to be mounted such that the supports rest on the arms? I'm working on my coolant hoses and want to make sure I cut them to the correct lengths. I would also like to have my grill not be at such a sharp angle.
    Matthew and Noah
    '35 Hot Rod Truck - 5.0L 302
    Wake Forest, NC
    @father.and.son.35
    Senior Member mkassab's Avatar
    Johnson City, TN
    The tabs do not rest on the suspension arms (i.e., the pic is 2D) as the arm of the suspension moves up and down. You can set the radiator to any angle you want. The tab is to mount the headlight to since you won't have fenders.
    Mark
    Mark
    '35 Truck
    Build Thread: https://thefactoryfiveforum.com/show...35-Truck-Build
    Brevard, NC
    May 2018
    Chaska, Minnesota
    The most common grill angle is one that parallels the front door to body angle, around 35 degrees. There is a lot of angle adjustment available, but whatever you feel looks the best is the correct angle for you. I believe the original 1933/34 grill sat much more upright that any of these F5 hot rods do.
    20240616_173227.jpgImage - 2023-08-10T173040.583.jpegImage - 2023-11-27T214627.432.jpegImage - 2023-11-27T214637.172.jpegImage - 2024-03-02T164730.152.jpeg
    Senior Member Guardm16's Avatar
    Prescott, AZ
    Well said to mkassab and DanQ. One thing to keep in mind the lower radiator hose inlet changes angle also as you lean the radiator back. You can easily get to the point where you will have to raise the entire radiator in the mount at the upper control arm.
    If you don't raise the entire assembly you will not get the lower hose on. There is a steel support plate for the lower suspension in the way.
    Prescott, AZ
    Quote Originally Posted by FatherAndSon View Post
    The grill angle is determined by these two bolts with the slots in the grill mount. The tab that extends out over the suspension does not move regardless of the grill angle.
    Jul 2022
    Wellsboro, PA
    On my build, if I had adjusted the grill to be more upright the lower portion of the radiator hits a cross bar on the frame. Where I have my radiator set right now, I have maybe 3/8 inch of clearance at this point. The amount of clearance might also be affected by having an A/C Condenser.
    1990 Mustang 5.0 5sp, 2021 Bronco Sport Badlands, 1935 Extended Cab Build, 347 & 4R70W
    Prescott, AZ
    You had sent me a PM about the lower radiator hose. Here are some pictures to help explain the text I sent.
    As you can see I had to alter my X brace to fit the large oil pan. This does not alter the hose location.
    I am fabricating a skid plate from Stainless to protect the lower hose from road debris. I will post pictures when done.
  8. Likes FatherAndSon liked this post
