Results 1 to 3 of 3
Thread: Trunk Prop
    Jul 2024
    BC, Canada
    Trunk Prop
    Have a janky prop on my trunk lid that makes me cringe when I let the trunk rest on it. It’s off to the right side and tweaks the lid. Only a matter of time before she rips out or worse ;(
    I like the gas shock setup but appears that there are several methods to using gas shocks. I’d rather not have to replace my hinges to mount the shocks from the hinges, forward.
    Any suggestion?
    Attachment 203590
    My old MkII had the old surface mount hinges. A friend w/ the same installed gas shocks w/o attaching to the hinges. A year or so later one of his hinges blew apart. They are made of crappy pot metal. Plenty strong enough when used as intended but they couldn't take the stress from a mostly compressed gas shock. I made up a fairly nice looking prop rod from 3/8 round aluminum and found a small furniture leg robber cap for the top end where it contacted the trunk lid.
  3. Thanks Doc76 thanked for this post
    Jul 2024
    BC, Canada
    Can anyone with the gas shock setup that mounts further up the trunk lid and to the lip under the front of the inner trunk tell me what shock size is used for this?
    Sorry I hope that makes sense.
    This is the mount method I like the best.
    Need to know the shock lbs, extended length and body length.
