Thanks Thanks:  4
Likes Likes:  4
Results 1 to 40 of 43
Thread: Trunk Prop
    Jul 2024
    BC, Canada
    Trunk Prop
    Have a janky prop on my trunk lid that makes me cringe when I let the trunk rest on it. It’s off to one side and tweaks the lid. Only a matter of time before she rips out or worse ;(
    I like the gas shock setup but appears that there are several methods to using gas shocks. I’d rather no have to replace my hinges to mount the shocks from the hinges, forward.
    Any suggestion?
    Dec 2021
    Flower Mound TX
    I have the gas shock setup from Factory Five and no complaints. They hold the trunk lid up fine with easy one handed operation.
    This isn't the best demonstration but it does show the cushion effect when closing.
    Jul 2024
    BC, Canada
    Where are your shocks?
    Are they mounted to the hinge and forward to the roll bar area?
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Doc76 View Post
    Yes.
    https://www.factoryfiveparts.com/168...gas-strut-kit/
    Jul 2024
    BC, Canada
    K thx Mike
    This has to be used in conjunction with the later "bayonet" style hinge arms. If you have the early style arms you'll have to retrofit the later ones.
    Jul 2024
    BC, Canada
    Not so sure I can make that configuration work anyways. I plan to install the Breeze Cockpit Storage cubby there in the future and looks like that’d be in conflict.
    I’ve see some online where the gas shocks mount further back inside the lid and go to brackets fit to the tube up underneath near the hinge mounts.
    I’d be interested to hear from anyone that has that setup and their thoughts.
    Perhaps a source for a kit if available.
    Dec 2021
    Flower Mound TX
    I have the Breeze cubby, you have to cut slots in the rear wall for the struts to pass through. Not a huge deal.
  9. Thanks Doc76 thanked for this post
  10. #9
    I've done struts with cubby on several cars. As Mike says, easy peasy!
  11. Thanks Doc76 thanked for this post
  12. #10
    Jul 2024
    BC, Canada
    Nice thanks for sharing.
    Where’d you source the handle on the passenger side of the dash from?
    My wife asked for one the first time she climbed out of the car
  13. #11
    I don't know, the owner found it.
    Member Sarcasticshrub's Avatar
    Dec 2021
    Mariposa, CA
    Search for "Marine Handle" wherever your wallet points you. Ebay has em:
    Marine Handle
  15. #13
    Jul 2024
    BC, Canada
    Quote Originally Posted by Sarcasticshrub View Post
    Marine Handle
    lol thanks
  16. #14
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I think it's this one. Edwardb used it on his roadster build, and several other builders (myself included) then shamelessly copied him.
  17. #15
    Jul 2024
    BC, Canada
    Nice and clean looking.
    Thx guys
  18. #16
    Master of Disaster
    Jan 2016
    Springville, NY
    Hey Jeff, have you ever installed these on a finished MKIV? No cubby, center mounded battery, not a lot of room for my old fat *** to gain access.
  19. #17
    Quote Originally Posted by JCB52 View Post
    I always do it with the body off. Not impossible with the body on but like you said not much working room to get at the front ball mounts!
    Oct 2020
    Albany, NY
    I got one from amazon. Made some custom steal brackets. It's what I told passengers to hang onto in leu of the windshield. Will put another one in my next car as well. Super useful.
  21. #19
    Jul 2024
    BC, Canada
    I’ll be in the same boat doing it body-on eventually. It’s totally doable.
  22. #20
    Jul 2024
    BC, Canada
    Thanks for sharing. The Amazon add is a little odd in description but I think that’s the 10” one correct?
    Also, you made brackets? I was wondering if the dash alone could take it. Care to share a pic underneath the dash to show what you did?
  23. #21
    May 2023
    Frisco, TX
    But consider first, whether you want people putting/pulling their weight from your relative thin dash. I’m opting out, despite the fact that it looks amazing.
    MKIV Complete Kit # 207585
    Ordered 8/19/2023. Completion date 11/11/23. Delivery date 11/27/23
    Build Thread: http://https://thefactoryfiveforum.c...577#post535577
  24. #22
    Feb 2022
    Flower Mound, TX
    I installed one too, and the steel brackets are rock solid and isolate the dash from any stress.
  25. #23
    Jul 2024
    BC, Canada
    Quote Originally Posted by OB6 View Post
    Agreed
    I had a peak under there last night. Not an issue to make it rock solid.
    And gotta keep the wife happy
    This’ll be a good “winter project”
  26. #24
    Sep 2011
    Minneapolis, MN
    Similar setup here, made from angle iron from the local Ace. I have an extra thickness of aluminum as a backer panel for my dash, so I wasn't worried about shear forces on the dash. In / out of plane is handled well by the angle iron behind the dash. Briefly stated: it ain't movin' . Like OB6 said - rock solid, and very reassuring.
    The photo is taken before I had fabbed the second bracket, and before I had drilled and tapped into the top of the 2" square frame member for this one (hence the clamp). But it gives a pretty good idea of what you'll be facing.
    by John Ibele, on Flickr
  27. Thanks Doc76 thanked for this post
    Likes Doc76 liked this post
  28. #25
    Senior Member Rebostar's Avatar
    Jan 2024
    I could not find a handle I liked. Did not want stainless or chrome. Could not find a black one I liked, so I made one and painted it to match other minor accessories in the cockpit. If you install one. Weld in a stout bracket that will take the wieght of the largest person you think will be sitting in that seat!
  29. Likes Doc76, StangRacer, Bart Carter liked this post
  30. #26
    Jul 2024
    BC, Canada
    Quote Originally Posted by Rebostar View Post
    Agreed
    I’m still on the fence. I looked for a carbon fiber on but not much came up.
  31. #27
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    Agreed
    Check theses out - Marine grab handle: https://www.koshigroup.com/product/c...l-grab-handle/
    Current BOM
  32. #28
    Jul 2024
    BC, Canada
    I’m sold. Those are exactly what I was thinking!
  33. #29
    Jan 2019
    Mead Colorado
    I just purchased one as well as the cup holders. Feels like they should be pretty good. Sorry for hijacking the thread.
    Current BOM
  34. #30
    May 2023
    Frisco, TX
    Check out the West Marine website. They have them in various lengths for decent prices.
  35. #31
    May 2023
    Frisco, TX
    I considered getting one and powder coating it. But, really, I don’t want to encourage anyone to put their weight on my dash—they’re not made from very thick material.
  36. #32
    Jul 2024
    BC, Canada
    Where’d you get the floor mats?
    They looks like a decent fit
  37. #33
    South Australia
    Freight was going to cost me a kidney and a lung to get new hinges shipped to Oz, so modified my existing hinges with some 1/4 inch ally plate and sourced struts to suit. Result: a satisfying arvo in the garage with hand tools, and a trunk (boot) lid that works like a charm. Still plenty of room for a cubby, or battery, or in my case, seat belt retractors.
    Notes:
    - Drilled and tapped 6mm threads into hinges. Allowing ally plate to be bolted up to hinge.
    - as this was retro fitted, I couldnt rivet the strut ball mount bracket to the chassis of the car. Just got cheap and nasty with some self drilling metal-threads. To be honest, they pull up tighter than a rivet.
    Nige
    Gen1 Coyote / TKO600 / IRS
  38. #34
    South Australia
    I did mine with the body on, no-one would call me skinny. Used self drilling screws instead of rivets for the ball mounts. It's a bit easier because the lid is off. Actually, the worst part was realigning the lid, whilst fighting against the gas struts.
    Nige
  39. #35
    Jul 2024
    BC, Canada
    Anyone in the Fraser Valley BC area with a similar setup that I could see in motion?
    Curious to know what kinda of torque is applied to the connection at the fiberglass.
  40. #36
    Jul 2024
    BC, Canada
    Nige
    Any chance you can send me a picture of the writing on the gas shocks?
    Curious to know lbs of pressure and stroke or model number. I’ll fab this myself too and may already have sufficient gas shocks on the shelf in my shop.
  41. #37
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    My kit came with 20 lb. gas shocks for the trunk and they weren't strong enough to hold the lid open, so I replaced them with these 28 lb. shocks:
    They're still not strong enough to open the lid by themselves but they'll hold the lid open.
  42. #38
    When using the FFR designed hinges and struts ZERO pressure is applied to the fiberglass. The struts act against the hinges.
  43. Thanks Doc76 thanked for this post
  44. #39
    Jul 2024
    BC, Canada
    K thx
  45. #40
    Oct 2020
    Albany, NY
    Yes, I found a picture. nothing fancy but I used a tap to thread the other end right into the square tube
    10"
