Results 1 to 4 of 4
Thread: Forte hyd clutch alignment?
    Jul 2024
    Attachment 203715Attachment 203716
    I wish this was straighter. Looks like 10-15 degrees of misalignment. Thoughts?
    Lilburn, GA
    Your link doesn't work
    Jul 2024
    You can mill out the bottom of the slot where the rod end connects and fill in the extra gap with washers.
    I do not think there is enough angle to hurt. Might check with Mike.
