Thread: Bad Camshaft broken cam guide
    Aug 2024
    Well I purchased FFR cobra MKIII with a 347 only 8K miles. This engine has EFI with Mass Air Flo ECU.The lifter guide broke don’t know where the piece is.
    Can I drop the oil pan or where can I look for piece
    How do I know which Camshaft should I order
    How can I be reassured there isn’t something that would make this reoccur
    Do I need to pull the engine or can I install new cam with engine installed. Concerned with front cross bar maybe blocking.
    How do I determine Camshaft
    Please help see photos
    Jul 2021
    Tonganoxie, KS
    I'd start by dropping the oil pan and looking for the broken piece of the dog bone, yes. Yes, you can swap the camshaft with the engine in the car. I've done it on a MkIII with a 408. Plenty of room. Can't tell you what cam to purchase. Not enough info. Need more info on heads, rotating assembly, pushrods, rocker ratio, etc.
    Greg
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
    bobl's Avatar
    Spicewood, Texas
    It looks like that lifter is dropped down way too low. I'm guessing it broke and dropped below the guide bar and then broke it when it came back up. Most likely the cam is ruined and you'll need to replace all the lifters, guides and retainer. Then you need to figure out what other carnage occurred.
    Did the lifter retainer plate back out or loosen allowing the dog bone retainer pop up and get hung on the lifter?
    bobl's Avatar
    Spicewood, Texas
    I.ve seen them break because a rocker nut backed off or broke, or possibly a pushrod failure and the lifter just hammers away with no load. It's hard to tell the cause sometimes. Which failed first. A picture of all the parts would help.
    Aug 2024
    No the retainer was in place it appears the the dog bone broke cheap metal than the lifter turned and seized. It dropped only becuase it turned it back in place to pull it out but it slid down.
    Can anyone help me determine the cam to replace like for like or select a better option.
    How do I determine.
    My springs are good it was just a lifter seized the screwed the cam probably wore it down.
    Current Head AFR 1420
    Manufacturer's Part Number:
    1420
    Part Type:
    Cylinder Heads
    Product Line:
    AFR 185cc SBF Renegade 20 Degree Street Heads
    Summit Racing Part Number:
    AFR-1420
    Combustion Chamber Volume (cc):
    72
    Intake Runner Volume (cc):
    185cc
    Exhaust Runner Volume (cc):
    68cc
    Cylinder Head Style:
    Assembled
    Cylinder Head Material:
    Cast aluminum
    Camshaft Style:
    Hydraulic roller
    Intake Port Shape:
    Rectangular
    Intake Valve Diameter (in.):
    2.020 in.
    CNC-Machined Combustion Chamber:
    Yes
    CNC-Machined Intake Runner:
    Yes
    CNC-Machined Exhaust Runner:
    Yes
    Combustion Chamber Style:
    Heart
    Intake Port Location:
    Standard
    Aug 2024
    Need help for Cam selection
    How do I determine.
    1420
    Part Type:
    Cylinder Heads
    Product Line:
    AFR-1420
    72
    185cc
    68cc
    Assembled
    Cast aluminum
    Camshaft Style:
    Hydraulic roller
    Intake Port Shape:
    Rectangular
    2.020 in.
    Yes
    Yes
    Yes
    Heart
    Standard
