Results 1 to 5 of 5
Thread: IRS Suspension Clearance
    Jun 2022
    I've done a poor man's alignment on my IRS until I can get it to a shop. Slightly toe'd in and negative camber, but the clearance for the rear suspension is really close, is that normal?
    Trying to upload a photo but not having any luck, I'll upload when able. But's less than a finger width from the tire to the spring.
    MKIV Roadster - Complete Kit - Delivery 10/12/23
    Jun 2022
    Apparently Microsoft Edge and the forum don't work well together
    Jun 2023
    Tonganoxie KS
    I have not had mine aligned but the clearances are very tight on mine also
    Many have reported tight clearance or even interference in that area. Mainly before alignment. You should be OK after it's accurately aligned. Not to worry...
    Jun 2022
    Thanks everyone, I'll proceed forward.
