Thanks Thanks:  16
Likes Likes:  13
Results 1 to 35 of 35
Thread: Copper-Nickel Brake Lines
    Jul 2024
    BC, Canada
    Can anyone recommend a source on this?
    I see Amazon sells it but the reviews on the material quality is questionable and when I ask the local auto parts stores they look at me like I’m speaking another language.
    Cheers
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    When I go to an auto parts store around me and the FIRST question they ask me is what make and model my car is, I smirk and tell them it's a 1965 Shelby Cobra. When the kid's eyes gloss over I just say what part I need and to go get it.
    Regarding the Ni-Co lines, I got mine at Summit Racing. Might be different for you up in BC though, I'm not sure of import fees and whatnot.
    Matt
    My build thread here
  3. Thanks Doc76 thanked for this post
    Senior Member mrglaeser's Avatar
    Jan 2020
    Twin Cities, MN
    I've ordered from two places
    4LifetimeLines 3/16" x 25'... https://www.amazon.com/dp/B07BMZ5FV2...p_mob_ap_share
    https://www.summitracing.com/parts/OPS-MLK7CNF
    Used one on the Roadster and one on a 69 Mustang. Worked great
    Mark IV, 302 Based 347, TKx, Four link w/3.55, coil overs, PS, 4wheel Willwood. Dark Blue w Black/Red stripes, Saddle Interior, Blacked out chrome.
    Kit Ordered 4/18/2022
    Kit Delivered 2/20/2023
    Engine Install 9/15/2024
  5. Thanks Doc76 thanked for this post
    Likes StangRacer liked this post
  6. #4
    Jan 2019
    Long Beach, CA
    I used The Stop Shop seller on Amazon for my rolls of ni-cop. No issues.
    Ordered 9/24/2020, Delivered 1/18/2021 MK4 Roadster, 3 Link, 15" Halibrands, Blueprint Carb 347/TKX Installed 3/13/2022, first start 10/2022, go cart 11/2022, CA SB100 Reg Complete 12/2023
  7. Thanks Doc76 thanked for this post
  8. #5
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
  9. Thanks Doc76 thanked for this post
    Likes Doc76 liked this post
  10. #6
    Senior Member robmccon's Avatar
    Apr 2021
    Fort Mill, SC
    I didn’t want to cut/flare bulk line, so I measured and bought the precut lines at Autozone. I ended up buying (4) 51” and (1) 60”. There was some confusion at the parts counter, the manager let me go in the back and select the lines myself.
    Rob
    Mk4 Complete Kit, #10465
    Ordered 11/14/21, Build School 5/20/22, Delivered 8/22/22, Engine/Transmission Delivered 3/27/23, Installed 9/3/23, First Start 2/14/24
    347FI/TKX/IRS "Street Look"-no hoodscoop or rollbar, undercar exhaust
  11. Thanks Doc76 thanked for this post
  12. #7
    Senior Member Norm B's Avatar
    I got the long line for the rear brakes from Summit Racing. You will need to get the correct tube nuts and flaring tool to make the connections. The shorter lines for the front brakes are available at Napa or Auto Value with the flares and fittings already done.
    Norm
  13. Thanks Doc76 thanked for this post
  14. #8
    Senior Member JJK's Avatar
    Jul 2022
    DFW Texas
    I had the exact same experience at oreilleys, I ended up in their back parts storage rummaging through things to find what I needed. but all local and worked out fine
  15. Thanks Doc76 thanked for this post
  16. #9
    Jul 2024
    BC, Canada
    I’m just gonna buy a bulk roll and fittings and replumb the whole car myself.
    Knowing my luck if I buy pre-bent lines I’ll end up running into something I can’t get around.
  17. #10
    +3 on pulling the stock myself at Advance Auto parts.
    Kevin
    MKIV #8234
  18. Likes Doc76 liked this post
  19. #11
    South Australia
    Are these guys near you?
    https://thelangleybrakeshop.ca/contact.html
    If they are anything like my local guys, they will have everything you need, charge bugger all, and give you great free advice. I made up my own lines and my local brake joint did the ends as needed. They also complimented me on the bends, even showing some other guys in the shop, which made my day. When you work with knowledgeable guys, they may charge a bit, but I consider it as 'paying for your education'.
    Nige
    Gen1 Coyote / TKO600 / IRS
  20. Thanks Doc76 thanked for this post
  21. #12
    South Australia
    To make templates of your brake lines, use some fencing wire as follows:
    - Cut 5 metre length.
    - put one end in bench vice, other in battery drill chuck.
    - pull wire tight, then hit trigger for 30-50 revolutions. This will 'rifle' the wire making it dead straight and stiff. Perfect for making brake and fuel line templates.
    Nige
  22. #13
    May 2018
    Chaska, Minnesota
    Copper-Nickle brake lines are an excellent choice, especially in climates subject to corrosion or rusting. They are much easier to bend than steel or stainless, and their strength is more than adequate for automotive hydraulic brakes. I believe most bad reviews you see on the bulk rolls are from the user making the flared ends correctly, not from failure of the tubing itself. Be sure to get a good quality double flaring tool, watch a few you tube videos, make a bunch of test flares, and you should have no issues at all.
  23. Thanks Doc76 thanked for this post
  24. #14
    Jun 2022
    yeah, I just asked for a brake line at my Autozone and they brought out the copper nickel ones...after they asked for a make and model and I told them it's complicated.
    MKIV Roadster - Complete Kit - Delivery 10/12/23
    Jul 2024
    BC, Canada
    Nige
    Wow…They are thanks
    I’ll call them today. Not sure why they didn’t come up on my Google search
  26. #16
    Senior Member nuhale's Avatar
    Jun 2019
    Gurnee, IL
    Stop Shop on Amazon is good quality line.
    Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Covid
    Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55 [/B]
  27. Likes Doc76, toadster liked this post
  28. #17
    Senior Member MaxVmo's Avatar
    May 2023
    Bought the line from Summit and a flare tool recommended on this forum. It was a learning curve and I used all the line LOL. No leaks! I had a lot of apprehension about it but it turned out to be a good experience.
  29. #18
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    I have used nicopp line from Amazon for both brake and fuel lines - no issues, no leaks, good flare ends using the Eastwood tool. I believe the brand name was 4 LifeTimeLines. I have also used nicopp line from O'Reilys - same experience. With regards to purchasing nicopp from local auto parts stores - go online and order what you need as store pickup. It saves the hassle of trying to deal with the parts counter kid who can't move past the make and model of your car.
  30. Thanks Doc76 thanked for this post
  31. #19
    Senior Member jrcuz's Avatar
    Stafford Virginia
    I put off doing my brake lines for a long time and then one day I decided to do them and when I was finished I wondered why I waited so long. I have the Eastwood tool.
    JR
  32. Likes Doc76, phileas_fogg liked this post
  33. #20
    cv2065's Avatar
    Pre-flared lengths from O’Reillys worked great. Takes a little more planning but work perfectly. If you buy from Autozone, review the sticks as the tube nuts are different.
  34. Likes Doc76 liked this post
  35. #21
    Folsom, CA
    Loved doing no-copp lines - I used the Eastwood flaring tool. Pricey but excellent!!
    Stop Shop lines were excellent
    Todd
  36. Thanks Doc76 thanked for this post
  37. #22
    May 2023
    Seconded! Great tool and easy to learn.
  38. Thanks Doc76 thanked for this post
  39. #23
    Jan 2020
    Twin Cities, MN
    If you only need to flare 3/16 line and don't want to spend the money on the Easton or similar tools I picked this one up from Oreilly's works great and small enough to use on a finished car for repairs. Much better than the cheap clamp style kits.
    https://www.oreillyauto.com/detail/c...n0/51535?pos=6
  40. Thanks Doc76 thanked for this post
  41. #24
    Aug 2024
    Quote Originally Posted by Doc76 View Post
    Cheers
    Not sure of your time line but NAPA has the brake line in 25 foot rolls and cost about 32.00.
  42. Likes Doc76 liked this post
  43. #25
    Senior Member BRRT's Avatar
    Sep 2020
    Quote Originally Posted by Ronc116 View Post
    NAPA also sells 3/16" and 3/8" NiCopp in 6' pieces.
    I purchased a coil of 3/16" from Federal Hill Trading for my brake lines (https://store.fedhillusa.com/)
    British made tube, top quality, nice people at a small business.
    Roadster delivered 8/27/23
    Chevrolet Performance LS3
  44. Likes Doc76 liked this post
  45. #26
    Jul 2021
    Tonganoxie, KS
    You don't need to spend $250 on the Eastwood flare tool. I bought this one on Amazon for $45, and it made perfect double flares first time, and every time. I have zero leaks. Never had an easier time flaring brake line.
  46. #27
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by mrglaeser View Post
    Yep, agreed. I used Eastwood's version of that, and it's great.
  47. Thanks Doc76 thanked for this post
  48. #28
    Jul 2024
    BC, Canada
    $80 in my neck of the woods
    Ended up with the Stop Shop on Amazon. $30 for 25’
  49. #29
    Edmonton Alberta
    In canada you will find pre-flare lengths of brake line at Napa along with many fittings and adaptors. Also Canadian Tire (my local small town store) have them as well.
    David W
    Mkll 4874 built in 2004
  50. Thanks Doc76 thanked for this post
    Likes narly1 liked this post
  51. #30
    cv2065's Avatar
    +1 on the pre-flared lengths. Takes a little planning, but they work great.
  52. Thanks Doc76 thanked for this post
  53. #31
    Jul 2024
    BC, Canada
    Never run brake lines before so kinda learning as I go.
    Per recommendations here got a good flaring tool.
    Hoping for some feedback before I get too carried away.
    In this disc conversion I am using a nicop lines and this is what I came up with for the rear.
    The Stop Shop kit came with plated steel fittings.
    The original steel lines I am pulling out from the OB were leaking at most connections which were 7 years old and low miles.
    Does this routing look ok?
    Should I use stainless fittings on the new lines for longevity or will the steel fittings last for years when properly sealed with little bad weather exposure?
    Attachment 208816Attachment 208817Attachment 208818
  54. #32
    Jul 2024
    BC, Canada
    Thanks guys
    I tried a couple types of flaring tools before finding one I was happy with. Settled on the tool producing flares on the left sample
    Think I have the hang of it. Just need to know SS fittings or just use the plated steel ones that came with the kit.
  55. #33
    Jax Beach, FL
    The local parts stores are going to need to know if you have air conditioning....LOL.
  56. #34
    I would be suspicious of that flare, doesn't look quite right?
  57. #35
    Jul 2024
    BC, Canada
    Thanks for the feedback Rich
    I’ll revisit that one.
