Likes Likes:  4
Results 1 to 15 of 15
Thread: Cant beleive it. Finally painted Cut and buffed.
    Aug 2017
    We, my build has taken 5 years to get to this point. I am finally beginning final assembly.
    The body work, sand able primer Primer, sealer and paint, all the sanding. Just crazy. I did it all myself in my garage. One step at a time. One painful step sometimes at a time.
    When i started painting, it took almost 30 hrs. straight by the time i finished. I thought that i wasn't going to make it.
    Here are the pics of my journey. Would love your feed back.
  2. Likes microbionic, NotDrivingTrains liked this post
    Aug 2017
    Aug 2017
  5. Likes David Williamson, 460.465USMC liked this post
  6. #4
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    Looks great. As someone that is going to do similar. Body on too, what did you do about the edges of the body? The areas that are hard to spray? Namely underneath, hood lower edges, wheel wells etc.
  7. #5
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    Wow, great work!
    I keep thinking I'd like to do my bodywork/paint but I just don't have the confidence in myself to do a satisfactory job.
    Have you done this before? What would you estimate your total hours of work were for body/paint?
    Gen 3 Coupe #576 - "Project Deimos"
    Ordered: 2/14/2024
    Received: 5/24/2024
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
  8. #6
    Aug 2017
    Quote Originally Posted by Kbl7td View Post
    I rounded them slightly and masked with tape still exposing the rounded edge. Im not sure the thickness of the primer or paint and clear but it did wrap around it.
  9. #7
    Aug 2017
    No, ive never done this at all body work wise. But honestly lol, a ton of YouTube videos lololol, all by hand, no power sanders. i found better control block sanding everything including the clear.
    The painting, Well i worked for Toyota motor manufacturing. When i first started out, i worked in the bumper paint shop. I sprayed primer, base clear on front and rear bumpers for the Corolla and Matrix. So its a skill that was taught and i did well over 200,000 bumpers lol. but that was 25 years ago. The skill came back quickly but thee key points, angles, overlapping still required YouTube to remember. I have a little imperfections here and there.
    Hours, body work, 500 -600 hours. 2k Primer sanding going through 4 levels of grit. all block sanding. Then spraying sealer with the wrong atomizing air pressure made my car feel like an orange. So sanding the car all over again. Learned as i went.
  10. Thanks JimStone thanked for this post
  11. #8
    Senior Member DamnYankee's Avatar
    Port St Lucie, FL
    Awesome job !
    Roadster Mk4 - 347 - T5 (Sold)
    35 Truck - LS3 - T56 (Sold)
    Type 65 - Delivered Oct 7, 2024.
  12. #9
    Oct 2020
    It looks aawesome! Congratulations! Looks like your in the home stretch
  13. #10
    Mar 2020
    Very nice. Congratulations!
  14. #11
    Senior Member Nigel Allen's Avatar
    South Australia
    not many can say they painted their Roadsters, even less can say they painted their coupe. You have just joined an elite club. Truly a great job.
    Gen1 Coyote / TKO600 / IRS
  15. #12
    Sep 2022
    Very nice!
    What sort of prep did you need for your garage (venting, lighting, etc)?
    Craig C
  16. #13
    Aug 2017
    Thankyou Nigel!! Really appreciate kind words
  17. #14
    Aug 2017
    Prep, alot. Cleaning and wiping to try and get as much dirt off the floors walls and ceiling. Then i masked everything. I knew i would get dirt specs but surprisingly not near as much as i was expecting. The biggest was the dried Wimbleden White flaking off of the wrap around the front window and hatch covers during the clear application. Air pressure from the gun knocked some little flecks onto the clear. I cut and buffed most but some sadly stayed. Didn't want to sand through the clear. so i would replace the front and rea masking with new before clear next time. I had a heater which allowed me to adjust temp with the help of a barbecue Weber temperature sensor lol. I had a window so i had it opened but with filter covering. Nothing else. I would create something else if i had to do it again. A box, with filter and a fan mounted to push air outside. The clear was the toughest. I always stepped out between coats and allowed to flash off and breath lololol. But after 3 coats of clear, i was done lol because of the venting.
    So the car is Guardsman blue and Wimbledon White. Number were just a dark black
  18. #15
    Aug 2017
