I'm running a 2014 Mustang GT rear axle in my HRT with a Yukon diff cover. When the suspension is compressed, the panhard bar support is hitting the diff cover. I was aware that this might be a problem, so I specifically looked for an aftermarket diff cover that was shallow. When comparing to the stock diff cover, it appears that it may still contact the support bar as well. I'm wondering if anyone has found a diff cover that avoids this problem or a solution to modify the panhard bar support to allow aftermarket covers? Thanks
