Results 1 to 4 of 4
Thread: Panhard support clearance of the rear axle
    Oct 2023
    I'm running a 2014 Mustang GT rear axle in my HRT with a Yukon diff cover. When the suspension is compressed, the panhard bar support is hitting the diff cover. I was aware that this might be a problem, so I specifically looked for an aftermarket diff cover that was shallow. When comparing to the stock diff cover, it appears that it may still contact the support bar as well. I'm wondering if anyone has found a diff cover that avoids this problem or a solution to modify the panhard bar support to allow aftermarket covers? Thanks
    Santa Clarita, CA.
    Just asking, have you adjusted your pinion angle yet? This may impact your clearance issue.
    F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
    Sep 2015
    Hamersville, Ohio
    I’d go with a Watts link.
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
    Oct 2023
    Yes, I've adjusted the pinion angle. It's currently at -2 degrees.
