Thread: Need to find the steering rack bellows locally
    Senior Member colsen23153's Avatar
    Jan 2019
    Sandy Hook, Virginia
    I have a hole in my bellows on the rack and pinion and need to replace it. Dave @ FFR said they don't sell them separately.
    Has any one found out where to get them? If you could share that information with me I would greatly appreciate it.
    Thanks'
    Cliff
    '33 Hot Rod Chassis #1118, Gen 2, hard top, bike fenders, AC, electric steering. BluePrint Engines Chevy 383 Fuel Injected with the 700R4 transmission 8.8" rear 3.55.
    Simi Valley, CA
    FWIW, here is some old information I had saved. I have not verified any of it, and the part numbers may be obsolete and/or the links broken. At least it's a place to start...
    Steering rack bellows? Try J.C. Whitney #Dorman 614-020. A universal one will not work for both sides. One side of the rack has a very small diameter mounting area. I found them at Flaming River. Part number FR1501B They can be purchased through Summit with that part number. On my roadster , when I replaced mine a couple of years ago, the tech at flaming river said that the bellows were the same as a 74-78 mustang II manual rack. The replacement boot was a MOOG K8437, which will fit either side. Does not have any provision for a vent tube. Rock auto had them for cheap.
    I just replaced the steering rack bellows and this is the kit I got from Summit. https://www.summitracing.com/parts/FLA-FR1501B See this thread if rack replacement is req'd: https://thefactoryfiveforum.com/show...451#post542451
    Replacement boots for the steering racks: Moog #K150289 may fit the 33-HR Rack if the big ends are the same size. Here is my thread about finding a replacement part:
    https://thefactoryfiveforum.com/show...ght=%23K150289
    HTH Keith HR #894
  3. Thanks colsen23153 thanked for this post
    Sep 2022
    Huntington, IN
    The Flaming River from Summit are the correct ones
    Jan 2019
    Thank you all.
    I ordered the MOOG K8437. It looks like it is a universal size. Both ends can be trimmed to fit your rack and pinion.
    Port Charlotte, FL
    Another option for others with the same issue is Mark at Breeze sells replacements.
    Henry
    Sep 2022
    Huntington, IN
    Quote Originally Posted by colsen23153 View Post
    Thank you all.
    Let us know if it fits
