Thanks Thanks:  4
Results 1 to 11 of 11
Thread: Wheel Well Liner
    Jul 2024
    BC, Canada
    Wheel Well Liner
    Anyone use the gator grip or similar undercoat product on the inner fenders (fiberglass areas) and under the nose cone to dampen rock impacts and clean up the look?
    The chap that built my car left it all exposed in gel coat so I am hoping to clean it up.
    I realize there are plastic insert wheel well liners we can buy however I personally am not a fan of the look, the fit, how they mount nor the access/visual access lost by what it covers. The liners also don’t address the portion under the nose cone (directly above the radiator)
    Appreciate the input and product info.
    Cheers
    Dublin, OH
    Truck bed liner (rolled or sprayed on) is what most people use. I used a duplicolor water based brush on product but hurculiner and raptor liner has been popular from other builders. Triple layered in the wheel wells for added protection from star cracks in the paint from rocks
  3. Thanks Doc76, Oshkosh Rob thanked for this post
    Folsom, CA
    like Chewy said - Raptor Liner is pretty popular and has several application styles
    I got a few rattle cans of it to darken up the aluminum in the rear wheel wells
    Todd
  5. Thanks Doc76 thanked for this post
  6. #4
    Jul 2024
    BC, Canada
    Anyone willing to share some pictures of the finished results?
  7. #5
    Southern Ontario/Cape Coral FL
    Quote Originally Posted by Doc76 View Post
    Do you have Princess Auto near you?
    https://www.princessauto.com/en/blac...t/PA0008829129
    I know you have Candian Tire
    https://www.canadiantire.ca/en/pdp/r...1_rr&rrec=true
    These both work. The one from CT also comes in a 4L can which you can brush on. I use that to do the whole underside of the body.
    This is not a great pic but you can see the rear wheel well panel(princess spray) and the underside of the body(CT spray) in that area.
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24
    MK4 #10616 picked up 4/10/23 SOLD
    MK4 #9759 picked up 4/3/19 SOLD
  8. #6
    Jul 2024
    BC, Canada
    Quote Originally Posted by Higgybulin View Post
    Yes I have both.
    In fact I have a can of that CT spray in my shop but wasn’t sure of its longevity. (Used it on an enclosed trailer).
    How long have you had it on?
    Did it go one with a decent thickness? (I found it to be quite thin regardless of coats.)
  9. #7
    I spray it on the underbody with a shutz gun
    Higgy
  10. #8
    Dec 2023
    Eddyville, KY
    This video shows how I did mine. https://www.youtube.com/watch?v=rmjjZcr5RJ8&t=31s
    Jim
  11. Thanks Doc76 thanked for this post
    Likes Doc76 liked this post
  12. #9
    Jul 2024
    BC, Canada
    Quote Originally Posted by Wingman06 View Post
    Great video. Thanks for taking the time to make and share this as well as responding to my question
    Cheers
  13. #10
    Jul 2021
    Big Canoe, GA
    I purchased a set of wheel well liners specifically designed to fit the Mk4 Roadster from Raptor Speedworks. Easy to install, they lend a very nice finished look to the wheel wells and absolutely protect the under body from road bits. I got the recommendation from a fellow in the Atlanta Cobra Club who pointed out a spider crack on the top of the front DS fender. Although he installed the guards after the fact, he is happy there will be no additional stone strikes. Luckily, I installed a set early on before any impact issues.
    Art Shand, Big Canoe GA
    BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
  14. #11
    Jul 2024
    BC, Canada
    Quote Originally Posted by Theshandman View Post
    I’ll check them out. I too have one of those cracks.
    Can anyone tell me what size the bulb seal is on the inner fender well rear panel?
    Guy that built my car cut it way short.
