Mike, I might do that to keep air from catching the bodywork from underneath. Would you use 060 aluminum?
GTM #304 LPE 525hp LS3
I'll try and get a picture tonight if I remember.
I used pretty thin material and then bent an edge on it to make it stronger.
It looks like .030.
Now that's some fancy welding. I wish I was half that good .
Me too, that's why I had this guy do it .
Measure twice, cut once. Then undo the changes you made
Going back to the original door length will allow access to "cubbies" behind the seats.
Side skirts widened by about 50mm. Aluminum sheet support plus a small welded plate at the rear for additional stability at the rear intake.
20240918_113709_copy_1600x901.jpg20240918_120258_copy_1600x901.jpg20240920_122633_copy_507x901.jpg
Mounting door outer panel to door frame. Had the fiberglass shop that did my hood and rear spoiler throw together some fiberglass "angle iron". Bonded to door skin, rivets to the door frame.
20241005_161429_copy_507x901.jpg20241005_164819_copy_1600x901.jpg20241005_171028_copy_1600x901.jpg20241015_173327_copy_1280x721.jpg
More fiberglass work to match the window seal contour at the rear of the door, aluminum template for layup.
Fitting the door card, donor upper but will require fabbing lower part to clear the cage/side bars.
20241018_105454_copy_1280x721.jpg20241018_110036_copy_1280x721.jpg20241021_175644_copy_1280x721.jpg
Boxing in the side coolant pipes. Made 2 temples. Started with a flush top which looked really nice. Then I figured I would incorporate the door seal into the piece.
20241021_181615_copy_1280x721.jpg20241021_182826_copy_1280x721.jpg20241021_182922_copy_406x721.jpg20241021_182927_copy_1280x721.jpg
Final design, should be a nice door seal with the weatherstrip.
20241021_185513_copy_1280x721.jpg20241021_185953_copy_1280x721.jpg20241021_190047_copy_1280x721.jpg
I love your attention to detail, as well as the patience that you have building this car. I haven't even had mine a year, and I struggle at times with how long I foresee it taking to complete my car.
Sal Mennella
Unfinished GTM #30 FFR - in progress!
Roadster 5132 - sold
Wow.....what an incredible amount of work you've put into that! Looks like it's coming along pretty nicely!
Shane Vacek
VRaptor SpeedWorks, LLC
www.vraptorspeedworks.com
Passenger side was the prototype, made great progress on the driver's side last night and today. Symmetry is the ultimate challenge here, especially starting with the asymmetric GTM body.20241213_123221.jpg20241213_123242.jpg20241214_143411.jpg
Cut... Paste... Cut... Paste
Why is the site posting my photos rotated all of a sudden?
This is such a cool build, Dave. I love seeing the progress.
Sal Mennella
